Mike Harris Posted January 25, 2019 Share Posted January 25, 2019 (edited) Any ideas? I know that the Coleco Poller returns 4 directions and from what I know about Coleco physical hardware is that the original J-Sticks have only up, down, left and right.The SAC controllers actually have physical contacts for the connects to inputs at one time yet it is still only up, down, left and right.As far as a routine all I can come up with is still check one bit at a time. 0 for north 1 for west, 2 for south and 4 for east. Any thoughts, recommendations, code??? Edited January 25, 2019 by Mike Harris Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted January 25, 2019 Share Posted January 25, 2019 you can use the bit opcode to check the bits and call the code, for up/down/left/right, thats the way i usely do, quite easy actually. Quote Link to comment Share on other sites More sharing options...
Mike Harris Posted January 25, 2019 Author Share Posted January 25, 2019 Thank you, I have that straight. I am talking about the other 4 directions as in NW, SW, SE and NE Quote Link to comment Share on other sites More sharing options...
+nanochess Posted January 25, 2019 Share Posted January 25, 2019 These are combinations of the bits. NW is both N and W set to zero. You need to make your own table manually for values 0-15 (AND $0F) and index the controller value into the table. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted January 25, 2019 Share Posted January 25, 2019 Yep, multiple directions at once. Yes, the SAC has an 8-direction contactor, but the diagonals just activate 2 directions at once. So SW activates both S and W. They probably just used the 8-way contactor because the 4-way one with their "real joystick" design wasn't working as well as the standard controller did on the diagonals. So just check the bits and allow for multiple "on" bits. Quote Link to comment Share on other sites More sharing options...
Mike Harris Posted January 26, 2019 Author Share Posted January 26, 2019 These are combinations of the bits. NW is both N and W set to zero. You need to make your own table manually for values 0-15 (AND $0F) and index the controller value into the table. Do you have a quick and dirty example? So far I have been checking one bit at a time then jump to an action such as move in that direction. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted January 26, 2019 Share Posted January 26, 2019 (edited) Well, if you used a table with a nibble for the x and for the y direction, it might look like this: BITS2DIR table based on lower nibble of joystick: 00 ; 0000 All directions at once... not happening 00 ; 0001 All directions except N... also not happening 00 ; 0010 All directions except S... Also 00 ; 0011 East and west...You guessed it 00 ; 0100 All directions except W 11 ; 0101 Southeast 1F ; 0110 Northeast 10 ; 0111 East 00 ; 1000 All directions except E F1 ; 1001 Southwest FF ; 1010 Northwest F0 ; 1011 West 00 ; 1100 North and south...nah 01 ; 1101 South 0F ; 1110 North 00 ; 1111 No direction Now just separate and sign-extend the nibbles, and add them to your x and y. Edited January 26, 2019 by ChildOfCv Quote Link to comment Share on other sites More sharing options...
Mike Harris Posted January 26, 2019 Author Share Posted January 26, 2019 Cool. This is the first time ever seeing these values. Learning something new every day. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted January 26, 2019 Share Posted January 26, 2019 It's also the case that a fall-through would accomplish the same result. Pseudo-code: Bit test 0 Jump nonzero to South dec Y South: Bit test 1 Jump nonzero to West inc Y West: Bit test 2 Jump nonzero to East dec X East: Bit test 3 Jump nonzero to Done inc X Done: Since it does not restrict itself to one direction, it handles any combination correctly. Quote Link to comment Share on other sites More sharing options...
Mike Harris Posted January 27, 2019 Author Share Posted January 27, 2019 (edited) Here is the routine in Z80 I created to give you the Joystick Values for your Coleco Games. Mind you this uses subroutines and definitions from the Electric Adventure Megablast Game. I did not post those routines because they don't belong to me. You can pick them up at http://www.electricadventures.net/ TEST_JOYSTICS: CALL POLLER LD A,(CONTROLLER_BUFFER+3) CP 00 CALL Z, PRINT_ZERO CP 01 CALL Z, PRINT_ONE CP 02 CALL Z, PRINT_TWO CP 03 CALL Z, PRINT_THREE CP 04 CALL Z, PRINT_FOUR CP 05 CALL Z, PRINT_FIVE CP 06 CALL Z, PRINT_SIX CP 07 CALL Z, PRINT_SEVEN CP 08 CALL Z, PRINT_EIGHT CP 09 CALL Z, PRINT_NINE JP TEST_JOYSTICS:PRINT_ZERO: LD HL,VRAM_NAME+460 LD DE, ZERO_PAT LD BC, 1 CALL LDIRVMRET PRINT_ONE: LD HL,VRAM_NAME+460 LD DE, ONE_PAT LD BC, 1 CALL LDIRVMRET PRINT_TWO: LD HL,VRAM_NAME+460 LD DE, TWO_PAT LD BC, 1 CALL LDIRVMRET PRINT_THREE: LD HL,VRAM_NAME+460 LD DE, THREE_PAT LD BC, 1 CALL LDIRVMRET PRINT_FOUR: LD HL,VRAM_NAME+460 LD DE, FOUR_PAT LD BC, 1 CALL LDIRVMRET PRINT_FIVE: LD HL,VRAM_NAME+460 LD DE, FIVE_PAT LD BC, 1 CALL LDIRVMRET PRINT_SIX: LD HL,VRAM_NAME+460 LD DE, SIX_PAT LD BC, 1 CALL LDIRVMRET PRINT_SEVEN: LD HL,VRAM_NAME+460 LD DE, SEVEN_PAT LD BC, 1 CALL LDIRVMRET PRINT_EIGHT: LD HL,VRAM_NAME+460 LD DE, EIGHT_PAT LD BC, 1 CALL LDIRVMRET PRINT_NINE: LD HL,VRAM_NAME+460 LD DE, NINE_PAT LD BC, 1 CALL LDIRVMRET ZERO_PAT: DB 010ONE_PAT: DB 001TWO_PAT: DB 002THREE_PAT: DB 003FOUR_PAT: DB 004FIVE_PAT: DB 005SIX_PAT: DB 006SEVEN_PAT: DB 007EIGHT_PAT: DB 008NINE_PAT: DB 009 Pattern Numbers would correspond to your pattern number representing whatever you decide to represent the number. You could put Klingon Symbols if you wanted. This was just a quick routine to give numbers and may have errors but the numbers are sound. It was never meant to be optimized or professional. So for all those out there that can not find the info you need then here you are. You have 12 bytes in the buffer to check against so you can do all kinds of things with this routine to show the full spectrum of coleco controllers. Edited January 27, 2019 by Mike Harris Quote Link to comment Share on other sites More sharing options...
Mike Harris Posted January 28, 2019 Author Share Posted January 28, 2019 Finally have my 8 directions. MOVE_PLAYER: CALL POLLER LD A,(CONTROLLER_BUFFER+3) LD IY,(SPRTBL) LD IX,(SPRTBL+1) CP 01 CALL Z, NORTH CP 03 CALL Z, NORTH_EAST CP 02 CALL Z, EAST CP 06 CALL Z, SOUTH_EAST CP 04 CALL Z, SOUTH CP 12 CALL Z, SOUTH_WEST CP 08 CALL Z, WEST CP 09 CALL Z, NORTH_WESTRET If you have a better routine that saves cycles, space or whatever I am all ears. Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted February 14, 2019 Share Posted February 14, 2019 I always use the ports directly, not any bios calls. I only use bios to turn of the soundchip in the start of the code. Here is the code I used, notice the 3 nops to ensure it work on ADAM computers. JSUP: out ($c0),a nop nop nop in a,($fc) bit 0,a jr nz,JSLEFT **** CODE for JOYSTICK UP ***** JSLEFT: bit 3,a jr nz,JSRIGHT **** CODE for JOYSTICK LEFT ***** JSRIGHT:bit 1,a jr nz,JSHOME **** CODE for JOYSTICK RIGHT ***** JSHOME: bit 6,a jr nz,JSDOWN **** CODE for JOYSTICK FIRE *****JSDOWN: bit 2,a jr nz,JSUD**** CODE for JOYSTICK DOWN ***** Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted February 14, 2019 Share Posted February 14, 2019 forgot the JSUD routine. JSUD: ret Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted February 14, 2019 Share Posted February 14, 2019 The CV also needs those NOPs too. I watched it with a scope and found that the signal pins have a surprisingly large recovery time. OS7 just implements it in the polling routine by first reading the input data, then toggling, then a call to an immediate return for a small delay. Then it takes the reading and flips back and exits, relying on the fact that it won't be called for a while to stabilize the input values for the next poll. Quote Link to comment Share on other sites More sharing options...
Mike Harris Posted February 15, 2019 Author Share Posted February 15, 2019 (edited) This is what I ultimately ended up with. MOVE_PLAYER: CALL POLLER LD A, (CONTROLLER_BUFFER+3) CP 0 JP Z, NO_MOVE LD H, 0 LD L, A ADD HL, HL LD DE, JOY_DIR_TABLE ADD HL, DE LD A, (HL) INC HL LD H, (HL) LD L, A JP (HL) NO_MOVE:RETJOY_DIR_TABLE: DW DUMMY,NORTH,EAST,NORTH_EAST,SOUTH,DUMMY,SOUTH_EAST DW DUMMY,WEST,NORTH_WEST,DUMMY,DUMMY,SOUTH_WESTDUMMY: It works great. But if you guys can really help me out I need a better routine that creates a wall in the tiles that a sprite can not go through.I have a routine that checks what patterns are underneath or adjacent to the sprite but it has issues and does not work all the time. Edited February 15, 2019 by Mike Harris Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted February 15, 2019 Share Posted February 15, 2019 Do you have the NMIs enabled or disabled? Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted February 15, 2019 Share Posted February 15, 2019 This is what I ultimately ended up with. MOVE_PLAYER: CALL POLLER LD A, (CONTROLLER_BUFFER+3) CP 0 JP Z, NO_MOVE LD H, 0 LD L, A ADD HL, HL LD DE, JOY_DIR_TABLE ADD HL, DE LD A, (HL) INC HL LD H, (HL) LD L, A JP (HL) NO_MOVE: RET JOY_DIR_TABLE: DW DUMMY,NORTH,EAST,NORTH_EAST,SOUTH,DUMMY,SOUTH_EAST DW DUMMY,WEST,NORTH_WEST,DUMMY,DUMMY,SOUTH_WEST DUMMY: It works great. But if you guys can really help me out I need a better routine that creates a wall in the tiles that a sprite can not go through. I have a routine that checks what patterns are underneath or adjacent to the sprite but it has issues and does not work all the time. Thats a way to do it too, but I think this routine is slower and take up more space than mine anyway its not a problem. If you use HL besure to push and pop it, if you are sure you dont use HL before you call your joystick routine, its not a problem, else you would want to push hl just before you set the H,0, and pop it on each of the adresses in JOY_DIR_TABLE. Quote Link to comment Share on other sites More sharing options...
Mike Harris Posted February 15, 2019 Author Share Posted February 15, 2019 Thats a way to do it too, but I think this routine is slower and take up more space than mine anyway its not a problem. If you use HL besure to push and pop it, if you are sure you dont use HL before you call your joystick routine, its not a problem, else you would want to push hl just before you set the H,0, and pop it on each of the adresses in JOY_DIR_TABLE. Well, I may change some aspects based on directly accessing the ports. Of course that is faster but my concern was that your version only shows 4 directions where as I am shooting for 8. Mind you I didn't test your code but all I am ready is only 4 directions. That said, I have to have 8 pure directions because my barrier hits also go against a wall in a diagonal direction. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted February 15, 2019 Share Posted February 15, 2019 A major question in how to improve on this is: What direction-specific processing do you do that disallows the decoding of X and Y separately? If you just used the bit method to figure out destination X,Y, you only have to test 4 directions. For instance, just for the fun of it I wrote a little "not Tetris" game. The input routine looks like: ... ; joystick input is in 'a' and #0xe jr z, 7$ ld e, PIECE_ADDR(iy) ld d, PIECE_ADDR+1(iy) ld h, PIECE_X(iy) ld l, PIECE_Y(iy) bit #2, a jr z, 4$ ; Move screen address down a line push hl ld hl, #WIDTH add hl, de ex de, hl pop hl ; Increment piece Y inc l 4$: ; Check right direction bit #1, a jr z, 5$ inc e inc h 5$: ; Check left direction bit #3, a jr z, 6$ dec e dec h 6$: ; Now, is the move legal? ld c, PIECE_ORIENT(iy) push hl call check_collision pop hl jr nz, 7$ ; Yes. Update the data ld PIECE_ADDR(iy), e ld PIECE_ADDR+1(iy), d ld PIECE_X(iy), h ld PIECE_Y(iy), l 7$: ret I just figured out where the piece would end up, taking into account both the down and the directions, and then checked whether it was blocked once I knew where to check. block.zip Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted February 15, 2019 Share Posted February 15, 2019 It actually works with 8 directions. Cause it check each bit for up,down,left,right. So if your routine is doing the same for up+left as up and left, it cover that too. Normaly I use those routines to convert to another bit pattern, cause i normaly do game conversion from other systems. So i "emulate" a Sega SG-1000 game controller bit pattern or MSX joystick etc. My code work like this: is it a up then y=y-1 is it a down then y=y+1 is it a left then x=x-1 is it a right then x=x+1 is it a fire then do something so press up+left will do y=y-1 and x=x-1 Quote Link to comment Share on other sites More sharing options...
Mike Harris Posted April 6, 2019 Author Share Posted April 6, 2019 (edited) Here is a sample of my 8 bit Z80 Scrolling.Still working out some of the bugs, this is based off of KIWI'S C Code.But it does the job for a 64x64 grid MAP_XY: LD HL, 0 PUSH BC LD A, (SCROLL_Y) CP 0 JP Z, Y_WAS_ZERO LD B, A LD DE, WIDELOOP_Y: ; Scroll Y * Wide ADD HL, DEDJNZ LOOP_YY_WAS_ZERO: ;+Scroll X POP BC LD A, B CP 0 JP Z, FINISH_ADJUSTLOOP_ROW: ; Wide * ROW ADD HL, DEDJNZ LOOP_ROWFINISH_ADJUST: ; Add to Map Data put in DE for print LD BC, (SCROLL_X) ADD HL, BC LD (SCROLL), HL LD HL, NEW_MAP LD BC, (SCROLL) ADD HL, BC EX DE, HLRET When calling MAP_XY you have to pass the row in B as in LD B, Row numberThe return values tells where on the 64x64 grid map to print to the screen which prints a 32 column row of data to the screen.Do this 24 times and you can create a scrolling world in all 8 directions if done right.Now I have to create a double buffer because although it is very fast in pure z80 assemble it still looks choppy moving 8 its at a time. I am 100% certain I can modify all my code to have a 256x256 scrolling world in 8 directions with any patterns and any color in VRAM. Edited April 6, 2019 by Mike Harris Quote Link to comment Share on other sites More sharing options...
