vintagegamecrazy Posted March 4, 2019 Share Posted March 4, 2019 I have a really clean Intelly 1 console but the controllers quit working after a few minutes of play. Once it cools down after being turned off for a while they work again. Something is overheating. I tried replacing the AY-3-8914 audio chip since the controllers run through it but that isn't the problem. Has anyone ran into this issue and know what IC to replace or do I have to buy some freezer spray and start testing ICs? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
mr_me Posted March 4, 2019 Share Posted March 4, 2019 Does the audio still work after the controllers stop. Does the soldering between the controller connectors and the chip look okay. Did you test with one controller unplugged. Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted March 4, 2019 Author Share Posted March 4, 2019 The audio is fine the game never freezes or hiccups. I did not test with one controller unplugged although I have swapped them. It doesn't seem like a solder connection. Before they go out completely it gets to the point where you have to press any of the fire buttons to get the directional disc to respond and after a while even that will get less and less responsive. I'll have to try to do some more testing but it just seems like one of the ICs is getting too hot. Quote Link to comment Share on other sites More sharing options...
mr_me Posted March 4, 2019 Share Posted March 4, 2019 Did you test the voltages coming from the power supply board; before and after. Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted March 4, 2019 Author Share Posted March 4, 2019 No but I'll definitely give that a try I'll have to try it when I first fire it up and it's running well and then try it when it starts running badly. Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted November 3, 2019 Author Share Posted November 3, 2019 OK so I just got around to checking this system out again. I took it apart and tested all of the voltages and all check out fine. I don't get anything out of the controllers anymore though and can't get past the title screen where as before I could play for about five to ten minutes before the controllers quit. I'm stumped now. Any other suggestions? Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted November 3, 2019 Share Posted November 3, 2019 Did you try @mr_me's suggestion of having one controller disconnected? On the non-Intellivision II systems, it's super easy to reconnect the controllers incorrectly. If that happens, many games will be stuck in the way you're describing. So it's certainly worth having only one controller connected, see how things work, then flipping the connector over and trying again. There are some variations in the system boards, too. IIRC the later boards changed some circuitry around the controller inputs so a picture of the board can help, too. Quote Link to comment Share on other sites More sharing options...
mr_me Posted November 3, 2019 Share Posted November 3, 2019 (edited) Try unplugging both controllers, put in an old mattel cartridge, see if you can get passed the title screen by shorting the first two controller connector pins with a screwdriver. Edited November 3, 2019 by mr_me Quote Link to comment Share on other sites More sharing options...
HunterZero Posted November 4, 2019 Share Posted November 4, 2019 One of the membrane keypad buttons might be stuck down. When this happens, it can "lock out" the disc control and other key pad buttons. As suggested, disconnecting one or the other controller can help check this. - J Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted November 4, 2019 Share Posted November 4, 2019 @mr_me - is there visual guidance that @vintagegamecrazy can follow to know which pins are 1 and 2? I can't recall if they're labelled on the board. That said, it won't harm anything if you "the wrong" pair. Quote Link to comment Share on other sites More sharing options...
mr_me Posted November 4, 2019 Share Posted November 4, 2019 Definitely try both sides but the first pin should be towards the back of the intellivision. Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted November 4, 2019 Author Share Posted November 4, 2019 I will check these suggestions out tomorrow when I have some spare time and get back with the results. Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted November 11, 2019 Author Share Posted November 11, 2019 So I just tested this out the other night and sure enough if I unplug the second controller then either controller works find in the first port and I played it for quite a while. Something is shorting out on the second controller port and now I get to try and figure out where that is. Is there any other issue it could be besides a short somewhere? Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted November 11, 2019 Share Posted November 11, 2019 It's great to hear that the problem seems to be controller-specific. Just to be sure... did you test by swapping the working controller to the other port and trying it out? You can test the controller using an Ohmmeter to find out which pins are shorting, assuming the problem is in the controller itself (likely). Have you already disassembled the controller to inspect the mylar layers? We had similar problems even back when we were kids. In our case, the disc input would short. The "fix" I came up with then was to get some notebook paper and tear out a small circle of paper and poke a hole in the center to place it between the layers to keep them apart. IIRC you typically find a small plastic "disc" of material that provides a little separation between the layers. I'll attempt some ASCII art below to try to describe it... Top Layer: ---XXXXXXX--- ---XXXXXXXX---- << the --- indicates clear plastic, XXXX is where the conductive paint is, the gap is the hole in the center that goes around the spindle Mid Layer: -- -- << plastic "washer" that provides a little separation between layers Bottom: ---XXXXXXX--- ---XXXXXXXX---- << bottom layer... when you press plastic disc, it causes top layer 'XXXX' to touch bottom layer 'XXXX' to create the input signal So in our case, we just 'fattened up' that middle layer. Some solutions: Open up your controller and make sure things are clean - gently wipe with barely damp cloth Be sure the separator layer is correctly installed Harvest a controller from another system Use FlashBack controller with adapter Get new mylars! There are new controller mylars! You can order here. My order of new mylars from the U.K. just arrived last week. Haven't tried them out yet, though. Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted November 11, 2019 Author Share Posted November 11, 2019 Yes, I played Astrosmash with both controllers and they both functioned properly. It's definitely something wrong with port 2 on the system. Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted November 11, 2019 Share Posted November 11, 2019 19 minutes ago, vintagegamecrazy said: Yes, I played Astrosmash with both controllers and they both functioned properly. It's definitely something wrong with port 2 on the system. Do you have any pictures? Some Intellivision motherboards have different circuitry for controller inputs. Those tend to be pretty interesting. The first thing then would be to check the conductivity between the pins on the motherboard itself, and see if you can identify anything on the board that might be causing a short. What's odd though is that if the short were on the motherboard, it shouldn't make a difference -- the problem would happen regardless of having a controller attached or not. Some pictures would help a lot. Quote Link to comment Share on other sites More sharing options...
livingonwheels Posted June 17 Share Posted June 17 (edited) I've been using my Intellivision 1 console extensively for the past two weeks. I've been putting many hours into Dragons Quest (Homebrew). I've just encountered the same exact issues with my controller as the OP. But there's a difference. I'm using a Cote Gamers controller adapter (and have been for years) while using a modded Super Nintendo controller (modded for Intellivision use). I've also used this setup successfully for years, but I've never put this much time into the console before. It's also RGB modded (composite and S video too, but I never use those). Here's the adapter I'm using: https://cotegamers.com/shop/en/accueil/137-long-play-disc-controller-adapter-for-intellivision-1.html I really don't want to open this console if I can prevent it (lots of extra wiring). Has the reason for the original posters issues ever been verified and fixed? Removing the modded controller does nothing, neither does using the Intellivisions original controller. My only option is to reset the system, which is a real inconvenience when leveling up in this RPG. Edited June 17 by livingonwheels Quote Link to comment Share on other sites More sharing options...
livingonwheels Posted June 19 Share Posted June 19 It's gotten to the point that I couldn't play more than a minute or two before the controller becomes unresponsive. For anyone who may come across this issue, disconnecting the second player controller from the motherboard like the OP did "solves" the problem. I'm able to play for as long as I like without the controller malfunctioning. But I still can't find any reason for this, and have only read about two or three instances of this happening, with no real fix. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted June 19 Share Posted June 19 Based one what I'm seeing in this thread and the fact that it is isolated to port 2. I'm thinking the issue might actually the sound IC. It also handles all of the controller logic functions and I'm wondering if something is happening to cause the logic for port 2 to develop an issue within that IC? The good think is that on the model 1 units, that chips is usually in a socket and can be removed and replaced pretty easily. The hardest part is opening up the console and getting that darn RF shielding off enough that you can access the main ICs. Also would require a donor Sound IC as that was a custom chip that I'm not aware of any clones for it. Quote Link to comment Share on other sites More sharing options...
livingonwheels Posted June 20 Share Posted June 20 I have the Cote adapter installed in my Intellivision I, the Cote adapter (pictured below) now has an Intellivision II controller attached to it (using a Sega Genesis controller extension), The 2nd player original controller is disconnected from the motherboard. Everything continues to work fine. Both controllers operate normally with no issues with this setup. I wonder if the Cote board is bypassing something on the motherboard that has failed. So, the fix for this issue seems to be to install a Cote adapter, and plug controllers into that (at least the 2nd player controller - player 1 controller appears to remain functional) instead of plugging into the Intellivision motherboard. Of course you'd have to use either an Intellivision II controller or a Cote Long Play Controller. One other thing I have noticed is that Intellivision remains warm even if turned off for days. So I wonder if that was causing the problem. From now on I'll unplug the console when not in use. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted June 20 Share Posted June 20 The Cote adapter is just a passthrough device that converts the straight pin connection from the mainboard to the pin compatible 9pin used on the Sears and Intellivision 2 console. There isn't any logic in this adapter to bypass anything. And yes, even when not physically turned on, the transformer inside the console is always receiving power and will get quite warm. So I would advise unplugging the console when not in use for any extended period of time. The power switch in the console is just routing the voltages from the transformer to the actual power supply board where it then brought down to the needed voltages that the console logic actually uses. I've heard of at least on person that rewired the transformer so that they were actually switching the power to the transformer itself with the switch so they could keep it plugged in without any power draw taking place other than when in use. Quote Link to comment Share on other sites More sharing options...
livingonwheels Posted June 21 Share Posted June 21 (edited) Yesterday I played for a few hours (on port 1) while an Intellivision II controller was connected to port 2 of the Cote adapter. The original Intellivision I controller was disconnected from port 2 of the motherboard. Today I reconnected the original Intellivision I controller to the motherboard (nothing on port 2 of the Cote adapter). 25 minutes later both controllers began acting erratically before finally becoming totally unresponsive 5 minutes later. I turned off the console, disconnected from port 2 the original controller from the motherboard, and all was well again. I disassembled the original controller from port 2 and cleaned all contacts. As I expected, it didn't help. I just don't get it. Works perfectly with an Intellivision II controller connected to port 2 of the Cote adapter, but as soon as a controller is connected directly to port 2 of the motherboard (just a controller, having the Cote adapter connected to port 2 is no problem), controllers begins to malfunction 25 minutes later. It's a gradual process from malfunctioning (buttons or pad registering incorrect inputs), to being totally unresponsive minutes later. Edited June 21 by livingonwheels Quote Link to comment Share on other sites More sharing options...
mr_me Posted June 23 Share Posted June 23 On 6/19/2024 at 3:59 PM, livingonwheels said: It's gotten to the point that I couldn't play more than a minute or two before the controller becomes unresponsive. For anyone who may come across this issue, disconnecting the second player controller from the motherboard like the OP did "solves" the problem. I'm able to play for as long as I like without the controller malfunctioning. But I still can't find any reason for this, and have only read about two or three instances of this happening, with no real fix. Suggest more testing. Test without the cote adapter. Then test the right controller in the left controller port. The problem doesn’t seem to be on the main board. It seems to be the controller. Quote Link to comment Share on other sites More sharing options...
