Irgendwer Posted March 12, 2019 Share Posted March 12, 2019 (edited) If you are tired of using "Peeks and Pokes" in C source files to fiddle with OS locations, then the current build of cc65 brings relief: Just use the global structure "OS" and the usual location names to access the variables. Here a small demo program: // A simple optical illusion programm // for the Atari 8-bit computers // (c) 2019 Ch. "Irgendwer" Krüger #include <atari.h> #include <conio.h> #include <unistd.h> #include <string.h> #define ScreenMemory (void *)(0x2000) #define DisplayListMemory (void *)(0x2700) #define CharsetMemory (unsigned char *)(0x2800) #define PAL_MAGENTA HUE_ORANGE #define MIX(a,b,c,d) (((a)<<6)|((b)<<4)|((c)<<2)|(d)) unsigned char FontData[] = {MIX(0,0,0,0), MIX(0,0,0,2), MIX(0,0,2,1), MIX(0,2,1,3), MIX(0,2,1,3), MIX(0,2,1,3), MIX(0,0,2,1), MIX(0,0,0,2), MIX(0,0,0,0), MIX(2,2,0,0), MIX(1,1,2,0), MIX(3,3,1,2), MIX(3,3,1,2), MIX(3,3,1,2), MIX(1,1,2,0), MIX(2,2,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,3,3), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(3,0,0,0), MIX(3,0,0,0), MIX(3,3,3,0), MIX(3,0,0,0), MIX(3,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0), MIX(0,0,0,0) }; // Screen layout: // // 111111111122222222223333333333 // 0123456789012345678901234567890123456789 // " ab " // 0 // " ab ab " // 1 // " " // 2 // " ab ab " // 3 // " " // 4 // " ab cd ab " // 5 // " " // 6 // " ab ab " // 7 // " " // 8 // " ab ab " // 9 // " ab " // 10 unsigned char PositionsX[] = { 19, 24, 28, 29, 28, 24, 19, 14, 10, 9, 10, 14, 19, 24}; unsigned char PositionsY[] = { 0, 1, 3, 5, 7, 9, 10, 9, 7, 5, 3, 1, 0, 1}; unsigned char EmptySpace[] = "ee"; unsigned char Cross[] = "cd"; unsigned char PinkDot[] = {'a'+128, 'b'+128, 0}; unsigned char Label[] = "JUST AN ILLUSION"; void DisplayList = { DL_BLK8, DL_BLK8, DL_BLK4, DL_LMS(DL_CHR40x16x4), ScreenMemory, DL_CHR40x16x4, DL_CHR40x16x4, DL_CHR40x16x4, DL_CHR40x16x4, DL_CHR40x16x4, DL_CHR40x16x4, DL_CHR40x16x4, DL_CHR40x16x4, DL_CHR40x16x4, DL_CHR40x16x4, DL_BLK8, DL_CHR40x8x1, DL_JVB }; void wait(unsigned char fiftiesthseconds) { unsigned char goalVcount = ANTIC.vcount; do { while (ANTIC.vcount == goalVcount); while (ANTIC.vcount != goalVcount); --fiftiesthseconds; } while (fiftiesthseconds); } int main(void) { memset(ScreenMemory, 0, 11*40); // clear screen memcpy(DisplayListMemory, &DisplayList, sizeof(DisplayList)); // DL to target address memcpy(CharsetMemory, (void*)(OS.chbas<<, 1024); // copy font and memcpy(CharsetMemory + 97*8, FontData, sizeof(FontData)); // patch it (97 = 'a' internally) OS.savmsc = ScreenMemory; OS.color0 = _gtia_mkcolor(PAL_MAGENTA, 4); OS.color1 = _gtia_mkcolor(PAL_MAGENTA, 5); OS.color2 = COLOR_BLACK; OS.color3 = _gtia_mkcolor(PAL_MAGENTA, 2); OS.color4 = _gtia_mkcolor(HUE_GREY,5); // center cross cputsxy(19,5, Cross); // label... cputsxy(12,11, Label); OS.sdlst = DisplayListMemory; OS.chbas = (((unsigned int)CharsetMemory)>>; do { unsigned char index0 = 0; unsigned char index1 = 1; unsigned char index2 = 2; do { cputsxy(PositionsX[index0], PositionsY[index0], PinkDot); cputsxy(PositionsX[index1], PositionsY[index1], EmptySpace); cputsxy(PositionsX[index2], PositionsY[index2], PinkDot); wait(4); ++index0; ++index1; ++index2; } while (index2 < sizeof(PositionsX)); } while (1); return 0; } You can build the program above (if you call the code file "main.c") with: cl65 -Cl -O --start-addr 0x3000 -t atari main.c -o jaillu.xex To 'watch' this demo just focus the cross in the middle and watch how a non-existing greenish dot appears and pink dots seem to vanish. (The effect is quite popular and was already used in the demo "Optical" (http://a8.fandal.cz/detail.php?files_id=6624)). jaillu.xex Edited March 12, 2019 by Irgendwer 10 1 Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted March 19, 2019 Share Posted March 19, 2019 Thanks irgendwer, any difference in performance ? Also where can I find reference to the things I can use with the OS prefix? Quote Link to comment Share on other sites More sharing options...
sanny Posted March 19, 2019 Share Posted March 19, 2019 Also where can I find reference to the things I can use with the OS prefix? Look into include/_atarios.h. Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted March 19, 2019 Share Posted March 19, 2019 Thanks sanny Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted March 19, 2019 Author Share Posted March 19, 2019 (edited) Thanks irgendwer, any difference in performance ? No, access by structure is as fast as direct peek/poke or load/store from/to the address in assembler. Also where can I find reference to the things I can use with the OS prefix? Sanny already answered. In general all OS locations up to page 6 are available now. The names are the usual ones you find in the system reference manual/OS source code. In "Mapping the Atari" they are a little bit scattered, so in "De Re Atari" or "Atari System Reference Manual". Best source for a consecutive list of locations and their meaning in English I found is: http://www.atarimania.com/documents/The-Mastery-Memory-Map.pdf (Starting on page 32) Edited March 19, 2019 by Irgendwer Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted March 20, 2019 Share Posted March 20, 2019 Thanks irgendwer, are you part of the CC65 developers? or just a really good high end user? Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted March 20, 2019 Author Share Posted March 20, 2019 (edited) are you part of the CC65 developers? or just a really good high end user? I'm contributing (like the OS structure) from time to time to cc65. Actually this "idea" was more than 8 years old, but some things take longer... Another "not that old" change was the introduction of the keyboard codes, so that you can write: while (!kbhit()); switch (OS.ch) { case KEY_RETURN: ... case KEY_SPACE: ... case KEY_1: ... case KEY_W: ... } - you may find that useful too... Edit: I like to use the opportunity to thank "sanny" - he has the doubtful privilege to review my changes targeting the Atari. Thanks for that! Edited March 20, 2019 by Irgendwer 2 Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted March 20, 2019 Share Posted March 20, 2019 issues while compiling: main.c(14): Error: Undefined symbol: `DL_BLK8' main.c(14): Error: Constant expression expected main.c(15): Error: Constant expression expected main.c(16): Error: Undefined symbol: `DL_BLK4' main.c(16): Error: Constant expression expected main.c(17): Error: Call to undefined function `DL_LMS' main.c(17): Error: Undefined symbol: `DL_CHR40x16x4' main.c(17): Error: Constant expression expected main.c(18): Error: Undefined symbol: `ScreenMemory' main.c(18): Error: Constant expression expected main.c(19): Error: Constant expression expected main.c(19): Fatal: Too many errors i have the same includes as your demo has.... Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted March 20, 2019 Author Share Posted March 20, 2019 issues while compiling: ... The reason is the outdated version from the legacy project page: https://www.cc65.org/ Please use the active project page: https://cc65.github.io/ where Windows users can find also a "Windows Snapshot" containing binaries. Other versions have to be build on your own! (via https://github.com/cc65/cc65"Clone or download") 1 Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted March 20, 2019 Share Posted March 20, 2019 yes, i've managed to fix that. i was using legacy cc65.... Quote Link to comment Share on other sites More sharing options...
sanny Posted March 20, 2019 Share Posted March 20, 2019 Edit: I like to use the opportunity to thank "sanny" - he has the doubtful privilege to review my changes targeting the Atari. Thanks for that! Thanks :-) I'm open to any contribution which improves the Atari (and Atari5200) support. And you did a good job! regards, chris 3 Quote Link to comment Share on other sites More sharing options...
