m.o.terra kaesi Posted November 23, 2022 Share Posted November 23, 2022 Maybe I overlooked it. I can't find any information on this: Does the R77 now play also PHYSICAL Homebrews or just downloaded roms? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 23, 2022 Share Posted November 23, 2022 22 minutes ago, m.o.terra kaesi said: Does the R77 now play also PHYSICAL Homebrews or just downloaded roms? The R77 does not make a difference here. The problem is, that the cartridge slot dumper only supports a very limited number of cart types. Even many advanced original carts do not work. And even some theoretically supported carts do not work due to other incompatibilities. Overall the cartridge ports is a mediocre piece of hardware combined with lousy software. And unfortunately all this cannot be fixed. 1 Quote Link to comment Share on other sites More sharing options...
+swlovinist Posted September 2, 2023 Share Posted September 2, 2023 (I was able to fix the below issue by completely rewriting stella 6.6 to an sd card)...but is there an easier way? In the video below I now cannot use a controller to navigate the menu of the Retron 77 using Stella 6.6. Is there way to reset all the settings to default without just having to rewrite the entire SD card? Here is a video showing my issue Quote Link to comment Share on other sites More sharing options...
alex_79 Posted September 2, 2023 Share Posted September 2, 2023 I don't have a R77, but if you can select the "Event Mappings" tab of the input settings, you'll find another "Defaults" button there that might fix your issues. 1 Quote Link to comment Share on other sites More sharing options...
+swlovinist Posted September 2, 2023 Share Posted September 2, 2023 I was able to fix the above by rewriting the SD card to get default settings. 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 2, 2023 Share Posted September 2, 2023 15 minutes ago, swlovinist said: I was able to fix the above by rewriting the SD card to get default settings. Alternatively you can only delete any sqlite files on the SD cart. 1 Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted September 3, 2023 Share Posted September 3, 2023 I'm not sure how anyone can play the R77. Admittedly my version of Stella might be a couple years old, because I put it back in the box about that long ago... The R77 has input lag that makes it unbearable to me. I thought it was the TV at first. Then I realized it was the R77 as everything else I've hooked up to the same TV works flawless. 🤔 Quote Link to comment Share on other sites More sharing options...
