ggn Posted April 9, 2019 Share Posted April 9, 2019 Hi, I did reinstall RB+ just downloaded from bitbuket [Lines In: 285] [Lines Out: 553] [statements: 194] [Time: 0.06 sec's] BCX translated F:\ATARI\Jaguar\DEVKIT\RB_~1\PROJECTS\raycaster\raycaster.bas to F:\ATARI\Jaguar\DEVKIT\RB_~1\PROJECTS\raycaster\build\raycaster.c For a C Compiler Compiling C code... F:\ATARI\Jaguar\DEVKIT\RB_~1\PROJECTS\raycaster\build\raycaster.c: In function 'void basicmain()': F:\ATARI\Jaguar\DEVKIT\RB_~1\PROJECTS\raycaster\build\raycaster.c:268:19: error: 'x' was not declared in this scope F:\ATARI\Jaguar\DEVKIT\RB_~1\PROJECTS\raycaster\build\raycaster.c: In function 'void DRAWMAZE()': F:\ATARI\Jaguar\DEVKIT\RB_~1\PROJECTS\raycaster\build\raycaster.c:421:21: error: 'y' was not declared in this scope F:\ATARI\Jaguar\DEVKIT\RB_~1\PROJECTS\raycaster\build\raycaster.c:425:21: error: 'gfxbase' was not declared in this scope Build error! <<< Process finished (PID=6168). (Exit code 0) ================ READY ================ Other examples compile without errors did not test all but shooybang for example is ok. How can I fix this issue ? Pull latest revision, this has been fixed. (Way past the point of asking people politely not to PM me about rb+ things anymore, I'm just going to post their messages here in the forum from now on) Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted April 9, 2019 Share Posted April 9, 2019 (edited) I am on Windows 7 and installed everything for scratch. Now a few code examples dont compile well but others without error's Did try with antivirus disabled no succes Did download from github and bitbucket and did try both but still the same issue's Edited April 9, 2019 by TXG/MNX Quote Link to comment Share on other sites More sharing options...
ggn Posted April 9, 2019 Author Share Posted April 9, 2019 Post which ones are failing for you and I'll have a look. (not raycaster obviously, this should work with latest head). Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted April 10, 2019 Share Posted April 10, 2019 I have tested all projects only maprunner does crash now which also did before. raycaster is fixed :-) Build started on Wed 04/10/2019 11:13:39.88 Adjusting base address for CPU depack routine Buildlink starting Checking if assets.txt is newer than any of the build folder files.... Opening - F:\DEVKIT\RB+\PROJECTS\maprunner\assets.txt... Opening - F:\DEVKIT\RB+\PROJECTS\maprunner\build\linkfile.bin... Opening - F:\DEVKIT\RB+\PROJECTS\maprunner\build\romassets.inc... Opening - F:\DEVKIT\RB+\PROJECTS\maprunner\build\romassets.h... Opening - F:\DEVKIT\RB+\PROJECTS\maprunner\build\ramassets.inc... Opening - F:\DEVKIT\RB+\PROJECTS\maprunner\build\build.log... Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Reading assets.txt line Processing ASSETS\GFX\sand.bmp Converting BMP internally into gfxdata/clut... File is 16 pixels wide, 16 pixels high and is 4 bits/pixel Adding in RAM... Reading assets.txt line Processing ASSETS\GFX\rock3.bmp Converting BMP internally into gfxdata/clut... File is 16 pixels wide, 16 pixels high and is 4 bits/pixel Adding in RAM... Reading assets.txt line Reading assets.txt line Reading assets.txt line Buildlink finished - everything went fine! Assembling raptor skeleton... Translating .bas file to C... BCX-32: BASIC to C/C++ Translator by Kevin Diggins © 1999-2009 BCX-32 Version 6.00 (2009/06/02) [Lines In: 192] [Lines Out: 434] [statements: 142] [Time: 0.16 sec's] BCX translated F:\DEVKIT\RB+\PROJECTS\maprunner\maprunner.bas to F:\DEVKIT\RB+\PROJECTS\maprunner\build\maprunner.c For a C Compiler Compiling C code... F:\DEVKIT\RB+\PROJECTS\maprunner\build\maprunner.c: In function 'void basicmain()': F:\DEVKIT\RB+\PROJECTS\maprunner\build\maprunner.c:275:14: error: 'x' was not declared in this scope F:\DEVKIT\RB+\PROJECTS\maprunner\build\maprunner.c:277:14: error: 'y' was not declared in this scope F:\DEVKIT\RB+\PROJECTS\maprunner\build\maprunner.c: In function 'void updatemap()': F:\DEVKIT\RB+\PROJECTS\maprunner\build\maprunner.c:406:16: error: 'gfxbase' was not declared in this scope Build error! Quote Link to comment Share on other sites More sharing options...
ggn Posted April 11, 2019 Author Share Posted April 11, 2019 Fixed Quote Link to comment Share on other sites More sharing options...
