tripletopper Posted April 21, 2019 Share Posted April 21, 2019 Here’s a way to lazily with only fussing around with the outer casing of the Astrocade controller: I’m liking to this because the technique is all the same. Make sure you read my (aka TripleTopper’s) post because most of of the other people overcomplicate things, by using needle nose plyers and further disassembling stuff when only one step of disassembly is needed http://atariage.com/forums/topic/6932-jittery-paddles/?hl=%2Bpotentiometers+%2Bfixed&do=findComment&comment=64322 I think I can make it even one step lazier method. 1. Press the joystick on any diagonal. 2. Pour isopropylhol down the joystick shaft inside the hole that’s exposed at the opposite diagona t where you’re pressing. 3. Center joystick (let do diagonal) , then repeatedly turn the knob all the way quickly back and forth 10 times or until any scraping noises are no longer heard. 4. invert controler to dump out alcohol, and play. Quote Link to comment Share on other sites More sharing options...
ballyalley Posted April 22, 2019 Share Posted April 22, 2019 Here’s a way to lazily with only fussing around with the outer casing of the Astrocade controller: This sounds like it will work in a pinch. Thanks for posting this message. Adam Quote Link to comment Share on other sites More sharing options...
tripletopper Posted April 22, 2019 Author Share Posted April 22, 2019 Glad you like @ballyalley By the way, did you read the link to the first one, or are you commenting on the zero-tool method on this forum? By the way it’s not 100% effective. If there’s something deeper or more fundamentally wrong this won’t fix it. But if it’s just everyday wear, this will smooth out the rough spots in the paddle. That’s why I call it "First Aid" Take the least drastic step. You do not do open heart surgery for a paper cut. Quote Link to comment Share on other sites More sharing options...
Allen Schweitzer Posted February 10, 2020 Share Posted February 10, 2020 I had a guy do what you said, and he ended up sending 3 controllers to me for repair. I ended up just replacing them because it ruined the "printed circuit boards" (if that's what they are). None of the directions would work on any of them, but they all had continuity. So if you use this method, please be careful. Quote Link to comment Share on other sites More sharing options...
MattPilz Posted August 23, 2021 Share Posted August 23, 2021 (edited) For paddle/fader type variable controls I have found that DeoxIT F5 works wonders and should prove less harsh than isopropyl alcohol since it is specifically formulated for such components. Almost every "pong" variant I have acquired from the 70s also including Atari paddles have had terrible corrosion and sensitivity issues. But spraying a few bursts of F5 into the controller knob (with plastic knob part removed, when possible) and then turn the knob both directions back and forth a few times... Spray one or two more shots in and rotate once more and then I let it sit a half hour before powering on. Just did this again a weekend ago and now a Wonder Wizard I saved from the dump works like new. Edit - This also is a terrific solution to mending glitchy volume controls on old CRT sets and remove the static and hard volume jumps. Edited August 23, 2021 by MattPilz Quote Link to comment Share on other sites More sharing options...
tripletopper Posted August 24, 2021 Author Share Posted August 24, 2021 1 hour ago, MattPilz said: For paddle/fader type variable controls I have found that DeoxIT F5 works wonders and should prove less harsh than isopropyl alcohol since it is specifically formulated for such components. Almost every "pong" variant I have acquired from the 70s also including Atari paddles have had terrible corrosion and sensitivity issues. But spraying a few bursts of F5 into the controller knob (with plastic knob part removed, when possible) and then turn the knob both directions back and forth a few times... Spray one or two more shots in and rotate once more and then I let it sit a half hour before powering on. Just did this again a weekend ago and now a Wonder Wizard I saved from the dump works like new. Edit - This also is a terrific solution to mending glitchy volume controls on old CRT sets and remove the static and hard volume jumps. Where can I find Detoxit F5? A chain store name or a mail order website? Quote Link to comment Share on other sites More sharing options...
MattPilz Posted August 24, 2021 Share Posted August 24, 2021 1 hour ago, tripletopper said: Where can I find Detoxit F5? A chain store name or a mail order website? Some electronic stores may carry it but I was only able to find it on Amazon. They make F5 for faders/knobs and D5 for plugs and connections. It's rather expensive but also one bottle will will last a very long time. Quote Link to comment Share on other sites More sharing options...
