+TheBF Posted October 16, 2022 Share Posted October 16, 2022 7 minutes ago, oddemann said: Hmmm, if I go this way... DATA 32,"00" DATA 1,2,128,"C038040000000000" DATA 1,2,129,"0000040202020101" DATA 2,2,130,"0101020202040000" DATA 2,2,131,"00000000000438C0" DATA 2,1 132,"0000000000201C03" DATA 2,1 133,"8080404040200000" DATA 1,1,134,"0000204040408080" DATA 1,1,135,"031C200000000000" Read Char nr., "pic" Display it in a for-next loop - LINE NR CALL HCHAR(A,B,C) Then GOSUB the time delay Maybe even not have Char 32 in DATA as it is the same... would that make it more even? Sounds like you know what to do. Give it a try. 1 Quote Link to comment Share on other sites More sharing options...
oddemann Posted October 16, 2022 Author Share Posted October 16, 2022 (edited) Ver 5 BUT but but... why dos it only do one round and then fail? Also it was way slower... Spoiler 50 CALL CLEAR 100 DATA 1,2,"C038040000000000" 200 DATA 1,2,"0000040202020101" 300 DATA 2,2,"0101020202040000" 400 DATA 2,2,"00000000000438C0" 500 DATA 2,1,"0000000000201C03" 600 DATA 2,1,"8080404040200000" 700 DATA 1,1,"0000204040408080" 800 DATA 1,1,"031C200000000000" 801 PRINT "Spinner Demo Ver. 5" 802 PRINT "press a key to stop" 803 PRINT 804 TIME=5 805 GOSUB 1000 806 CALL KEY(0,K,S) 807 IF S=0 THEN 805 808 PRINT "Spinner stopped" 809 END 900 Read A,B,C$ 1000 FOR I=128 to 135 1025 Read A,B,C$ 1050 CALL CHAR (I,C$) 1100 CALL HCHAR(A,B,I) 1200 CALL HCHAR(A,B,32) 1300 GOSUB 9010 1400 NEXT I 1500 RETURN 9000 REM delay 9010 FOR T=0 TO TIME 9020 NEXT T 9999 RETURN Edited October 16, 2022 by oddemann Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 18, 2022 Share Posted October 18, 2022 Speed: Look at what you added to the main loop. Reading the data statements takes a lot of extra time. Changing a character pattern takes a lot of extra time. This is why the original was done the way it was done. BASIC has no forgiveness. So a "rule of thumb" as we say in English is: Do all the setup code outside of the loop. Keep the inside of the loop to a minimum for maximum speed. Why it stops: Also, after you have read the data once, you need to use RESTORE to start reading it again at the beginning. add line 1450 and it runs forever 1450 RESTORE Better solution: READ the DATA and do CALL CHAR() statements for all the characters as the setup code. Inside the loop, just put characters on the screen with HCHAR. This is faster. Have fun. 2 Quote Link to comment Share on other sites More sharing options...
oddemann Posted October 18, 2022 Author Share Posted October 18, 2022 10 hours ago, TheBF said: Speed: Look at what you added to the main loop. Reading the data statements takes a lot of extra time. Changing a character pattern takes a lot of extra time. This is why the original was done the way it was done. BASIC has no forgiveness. So a "rule of thumb" as we say in English is: Do all the setup code outside of the loop. Keep the inside of the loop to a minimum for maximum speed. Why it stops: Also, after you have read the data once, you need to use RESTORE to start reading it again at the beginning. add line 1450 and it runs forever 1450 RESTORE Better solution: READ the DATA and do CALL CHAR() statements for all the characters as the setup code. Inside the loop, just put characters on the screen with HCHAR. This is faster. Have fun. OK... learned how to reset data... Made a loop outside to read and assign value to different CALL CHAR. So far so good. (Intention is to make as few lines as possible.) But I am stomped by how to add the placement of the CHAR on the screen as it is 4 different locations. 2 CHAR is in the same box at different location within that box. - Can I make it a mathematical logical thing - NO, it has a pattern, but hard to make it "add" up. - I could probeable read it all and make a DIM and then store every value in its own place and then a loop could call it up "logically". Here I need to read up. - I could add all the 16 lines to make it all work. But that is adding a lot of lines - Are there other options? Also I got an Idea for a game... Have some circles that is moving and then you have to move your "X" into the circle between all the moving "protection" of the middle. Make some circles that are moving in opposite way to the one beside itself. "Lucky Spacewalker in his TI fighter is trying to blow up the mega killer star that is getting ready to blow up his planet!" (I am so creative, I don't know where I get my ideas from hehehehe) 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 18, 2022 Share Posted October 18, 2022 5 hours ago, oddemann said: OK... learned how to reset data... Made a loop outside to read and assign value to different CALL CHAR. So far so good. (Intention is to make as few lines as possible.) But I am stomped by how to add the placement of the CHAR on the screen as it is 4 different locations. 2 CHAR is in the same box at different location within that box. - Can I make it a mathematical logical thing - NO, it has a pattern, but hard to make it "add" up. - I could probeable read it all and make a DIM and then store every value in its own place and then a loop could call it up "logically". Here I need to read up. - I could add all the 16 lines to make it all work. But that is adding a lot of lines - Are there other options? Use 8 HCHAR() statements. One for each position. This is faster than computing x,y coordinates inside the loop. 1 Quote Link to comment Share on other sites More sharing options...
