+Lathe26 Posted April 24, 2019 Share Posted April 24, 2019 What documentation for the EXEC exists out there? I'm looking for info that is detailed enough for programmers to use (ex: this routine uses these registers as inputs and these registers for outputs). What I've found so far: Your Friend the EXEC - Decent documentation but does not list the addresses where in the EXEC the routines are. They had ASM include files that defined those things (I think YFtE called it SWELL.ASM) that we don't have. dis1600 - Can give friendly names to some of the raw EXEC addresses. The addresses are listed in the ASM comments as well as in dis1600's code. However, the names are not the same as in "Your Friend the EXEC". Also, there are some addresses that dis1600 doesn't recognize an will print them as just "EXEC.94C" or similar. Lastly, it's not clear whether all YFtE routines are named by dis1600. disassembling the EXEC ROM - I've been able to figure a few things this way, but this is slow. Any docs out there that either a more complete version of Your Friend the EXEC or is a "Captain Crunch Decoder Ring" for mapping YFtE routine names to EXEC ROM addresses? 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted April 24, 2019 Share Posted April 24, 2019 I've PM'd you. FWIW, the names in dis1600 purposefully mismatch YFTE, but I could change that. Quote Link to comment Share on other sites More sharing options...
Zendocon Posted July 30, 2019 Share Posted July 30, 2019 There's also the EXEC page in the IntelliWiki: http://wiki.intellivision.us/index.php?title=Executive_ROM It needs a lot more entry points added to it though, but it would probably be the best place for us to collaborate on known entry points. I can help add to the existing list. Quote Link to comment Share on other sites More sharing options...
