FocalPoint Posted May 1, 2019 Share Posted May 1, 2019 Hey guys, having trouble figuring out this little mystery. I stumbled upon an Atari Pong console which appears to be a C-100 model. The only trouble is that it's not 100% identical to the C-100 models I've seen via Google, eBay, or anywhere else listed. None of those appear to have a power on switch like mine, and a LED indicator light. Can anyone better identify this unit? Quote Link to comment Share on other sites More sharing options...
chas10e Posted May 2, 2019 Share Posted May 2, 2019 Hard to see but the power switch looks correct, I'd say the LED was a modification have you played it ? Quote Link to comment Share on other sites More sharing options...
FocalPoint Posted May 2, 2019 Author Share Posted May 2, 2019 Hard to see but the power switch looks correct, I'd say the LED was a modification have you played it ? Interesting. I played it decades ago of course. Traditional black and white pong. I don't have the coax switcher to hook it up to my modern TV for visual confirmation, but powering it on and starting it produces the typical pong "blip-bloop" sounds from the speaker. I assume it works. Odd that there would be a modification to add an LED though. Quote Link to comment Share on other sites More sharing options...
chas10e Posted May 2, 2019 Share Posted May 2, 2019 Get an RCA to coax adapter http://atariage.com/howto/connect.html for a newer TV do an analogue channel search if you can't lock down a signal Quote Link to comment Share on other sites More sharing options...
