+jedimatt42 Posted July 25, 2021 Author Share Posted July 25, 2021 Updated Force Command 1.25. This adds routines to read the TIPI mouse, and support a mouse pointer in 80x30 F18A text mode. For the purpose of allowing FCMENU to use these routines and support click to launch. Mouse pointer only works in F18A mode. It felt pretty slick to boot into ForceCommand, where my AUTOCMD launches FCMENU. I click on a script entry that maps DSK1 to TI-Artist, and then XB DSK1.LOAD, and then in TI-Artist the mouse also works (due to prior work) Improvements... I should probably hide the mouse pointer until it moves... and provide next and back screen elements to click on if your menu has multiple pages.... next weekend. 6 1 Quote Link to comment Share on other sites More sharing options...
SkyPilot Posted August 3, 2021 Share Posted August 3, 2021 What's next TIndows? 1 1 Quote Link to comment Share on other sites More sharing options...
+wolhess Posted August 6, 2021 Share Posted August 6, 2021 Hi @jedimatt42, today I made the update from ForceCommand 1.17 to 1.25 but my autocmd file does not work properly. It starts good and I can select the EDIT80 program, but if I select the menu item "TI System Info" or simply select "X for Quit" ForceCommand shows the message "Error, label already defined at line: 8553". And the system blocks with the tipi LED is on. After a reset all is good again. So I tried some other versions. My problem occures in version 1.24. The line number 8553 is always the same. In version 1.22 my autocmd works without a problem, the same as in version 1.17. Do I have to change something in my autocmd file? Maybe I will make a shorter autocmd file and using the new fcmenu function for my menu items. p.s. I have a F18A and a SAMS card in my system. My autocmd file is still under construction: AUTOCMD Thank you for your help! 3 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted August 6, 2021 Author Share Posted August 6, 2021 @wolhess, thanks! I will investigate what I broke, and do my best to fix it. 4 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted August 7, 2021 Author Share Posted August 7, 2021 @wolhess - just a couple tips reviewing the AUTOCMD code... A80: ... load TIPI.AUTOCMD "load" is the command for EA5 binaries... this may appear to work if the file type checking isn't there... as once I start far enough down the load code path, if it fails, the console is reset, which triggers re-entering FC and it runs your new AUTOCMD script. A better choice of command for this would be 'exit', as it resets the console on purpose, and if the GROM for force command was loaded, then FC is re-entered, and the script is picked up again. (you do this in A40: ) as well. INFO: ... AUTOCMD GOTO BEGIN would be a better choice here. While you can run scripts from the script, the calling script details (line number, file name, PAB) are on the stack so when a script completes, it can return to where it left off in the calling script. Doing this repeatedly will eventually run out of stack and corrupt environment variables, and then label data, etc... GOTO BEGIN will instead, will just reset the existing PAB to the record number that the BEGIN label is on, and resume execution. I am still looking for the root cause, more later... Some simple GOTO behavior seems to be broken as well... 2 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted August 7, 2021 Author Share Posted August 7, 2021 Update 1.26 - goto fixed, along with a couple other things. @wolhess your AUTOCMD seems to work for me as expected with these fixes. 3 1 Quote Link to comment Share on other sites More sharing options...
+wolhess Posted August 7, 2021 Share Posted August 7, 2021 11 hours ago, jedimatt42 said: @wolhess - just a couple tips reviewing the AUTOCMD code... A80: ... load TIPI.AUTOCMD "load" is the command for EA5 binaries... this may appear to work if the file type checking isn't there... as once I start far enough down the load code path, if it fails, the console is reset, which triggers re-entering FC and it runs your new AUTOCMD script. A better choice of command for this would be 'exit', as it resets the console on purpose, and if the GROM for force command was loaded, then FC is re-entered, and the script is picked up again. (you do this in A40: ) as well. INFO: ... AUTOCMD GOTO BEGIN would be a better choice here. While you can run scripts from the script, the calling script details (line number, file name, PAB) are on the stack so when a script completes, it can return to where it left off in the calling script. Doing this repeatedly will eventually run out of stack and corrupt environment variables, and then label data, etc... GOTO BEGIN will instead, will just reset the existing PAB to the record number that the BEGIN label is on, and resume execution. I am still looking for the root cause, more later... Some simple GOTO behavior seems to be broken as well... Thank You for your tips, I will change my autocmd as you recommended. Quote Link to comment Share on other sites More sharing options...
+wolhess Posted August 7, 2021 Share Posted August 7, 2021 On 8/7/2021 at 7:50 AM, jedimatt42 said: Update 1.26 - goto fixed, along with a couple other things. @wolhess your AUTOCMD seems to work for me as expected with these fixes. @jedimatt42, Yes my autocmd is workis again as before. Once again, that was a super quick fix! Many Thanks 3 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted October 3, 2021 Share Posted October 3, 2021 On 7/25/2021 at 6:24 PM, jedimatt42 said: Updated Force Command 1.25. This adds routines to read the TIPI mouse, and support a mouse pointer in 80x30 F18A text mode. For the purpose of allowing FCMENU to use these routines and support click to launch. Mouse pointer only works in F18A mode. It felt pretty slick to boot into ForceCommand, where my AUTOCMD launches FCMENU. I click on a script entry that maps DSK1 to TI-Artist, and then XB DSK1.LOAD, and then in TI-Artist the mouse also works (due to prior work) Improvements... I should probably hide the mouse pointer until it moves... and provide next and back screen elements to click on if your menu has multiple pages.... next weekend. Finally got around to trying this out. (Was waiting for all the hardware pieces to come together.). Your demo on this week's Zoom meeting and comments a while back made me jump on it. I completely missed the "FCMD.dsk" file when upgrading. Found the commands on your Github page: https://github.com/jedimatt42/fcmd/tree/master/example/gcc/fcmenu Thoughts? OK, you are a crazy, mad programmer! My TI-99/4A with the FCMENU just blows me away! A real Mouse driven menu system! Easy to set up nested menu files. What more can I say! Thanks jedimatt. 4 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 7, 2021 Author Share Posted October 7, 2021 Update 1.27 * fix wildcarding - was treating filenames without as a substring search, is now a literal match * extend copy command to allow renaming file during copy operation. * fix odd end of line behavior in ed * add line joining in ed when backspacing left from column 1 or pressing ctrl-j to join forward. * add ctrl-s and ctrl-d to jump to beginning and end of line respectively * changed ed save to ctrl-w 'write file' so ctrl-s could be used from jump to beginning of line - there is precedence for this in other software. * changed command line entry to use `ed` codebase for consistency and (horizontal) scrolling entry on 40 column displays. download in post #1 ( or you can just use the attachments list for this thread ) 5 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted October 7, 2021 Share Posted October 7, 2021 12 hours ago, jedimatt42 said: Update 1.27 * fix wildcarding - was treating filenames without as a substring search, is now a literal match * extend copy command to allow renaming file during copy operation. * fix odd end of line behavior in ed * add line joining in ed when backspacing left from column 1 or pressing ctrl-j to join forward. * add ctrl-s and ctrl-d to jump to beginning and end of line respectively * changed ed save to ctrl-w 'write file' so ctrl-s could be used from jump to beginning of line - there is precedence for this in other software. * changed command line entry to use `ed` codebase for consistency and (horizontal) scrolling entry on 40 column displays. download in post #1 ( or you can just use the attachments list for this thread ) Thanks, Matt! Tried the "copy" command! IT WORKS! Will play with the other changes later on! DG 2 Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted October 7, 2021 Share Posted October 7, 2021 A note on modifying the F18A palette using the PALETTE command for future reference of anyone else messing around with a minor change and needing a starting point for a quick tweak. Though I know most folks here would have no trouble figuring this out for themselves. The default 9918 palette values can be set as follows (or by using PALETTE /R but these are the values which would serve as the basis for small-scale changes). PALETTE 000 000 2C3 5D6 54F 76F D54 4EF F54 F76 DC3 ED6 2B2 C5C CCC FFF Where each value consists of three nibbles signifying (very straightforwardly) 12-bit RGB colour in the RGB order with a value from 0 to F. Such that the values actually specified there are the 9918 palette of Trans Black MGreen LGreen DBlue LBlue DRed Cyan MRed LRed DYellow LYellow DGreen Magenta Gray White 000 000 2C3 5D6 54F 76F D54 4EF F54 F76 DC3 ED6 2B2 C5C CCC FFF And such that the sort of minor modifications to the palette which are generally most useful (like changing Cyan to something else, or swapping Black with White and Grey, or what have you) can be achieved by modifying or swapping the relevant values in that default set. Note that the values specified must be upper case. For example, here's a really boring alternate universe TI-99 where Cyan (4EF) has been replaced with a light grey (EEE): Thanks for adding that feature, Matt! 4 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 7, 2021 Author Share Posted October 7, 2021 2 hours ago, pixelpedant said: A note on modifying the F18A palette using the PALETTE command for future reference of anyone else messing around with a minor change and needing a starting point for a quick tweak. Though I know most folks here would have no trouble figuring this out for themselves. The default 9918 palette values can be set as follows (or by using PALETTE /R but these are the values which would serve as the basis for small-scale changes). PALETTE 000 000 2C3 5D6 54F 76F D54 4EF F54 F76 DC3 ED6 2B2 C5C CCC FFF Where each value consists of three nibbles signifying (very straightforwardly) 12-bit RGB colour in the RGB order with a value from 0 to F. Such that the values actually specified there are the 9918 palette of Trans Black MGreen LGreen DBlue LBlue DRed Cyan MRed LRed DYello LYello DGreen Magent Gray White 000 000 2C3 5D6 54F 76F D54 4EF F54 F76 DC3 ED6 2B2 C5C CCC FFF And such that the sort of minor modifications to the palette which are generally most useful (like changing Cyan to something else, or swapping Black with White and Grey, or what have you) can be achieved by modifying or swapping the relevant values in that default set. Note that the values specified must be upper case. For example, here's a really boring alternative universe TI-99 where Cyan has been replaced with a light grey (EEE): Thanks for adding that feature, Matt! Can I copy this awesome info into my wiki? 1 Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted October 7, 2021 Share Posted October 7, 2021 22 minutes ago, jedimatt42 said: Can I copy this awesome info into my wiki? Yeah, of course! 1 1 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted October 20, 2021 Share Posted October 20, 2021 On 10/3/2021 at 4:18 PM, dgrissom said: Finally got around to trying this out. (Was waiting for all the hardware pieces to come together.). Your demo on this week's Zoom meeting and comments a while back made me jump on it. I completely missed the "FCMD.dsk" file when upgrading. Found the commands on your Github page: https://github.com/jedimatt42/fcmd/tree/master/example/gcc/fcmenu A question? Is there any way through a menu option to exit fcmenu? (I know "Back" will exit.) I am trying to use it to go to a specific directory to do wonderful things (load EA5 games ? ). It will do it but always return to the menu. Thanks DG Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted October 21, 2021 Share Posted October 21, 2021 It seems to me that for proper function, the FG99 command requires that any file name provided be given in upper case, regardless of the case of the file on the FinalGROM SD card. For example, given a file named (in lower case) "fbforth.bin" on the FinalGROM SD FG99 FBFORTH succeeds for me, while FG99 fbforth fails, with the FinalGROM read light left blinking and "fbforth.bin" not loaded. Probably, this is a limitation of the FinalGROM's approach to file names rather than of FC's. But perhaps a note to this effect could be added to the wiki? Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted October 21, 2021 Share Posted October 21, 2021 3 hours ago, pixelpedant said: Probably, this is a limitation of the FinalGROM's approach to file names rather than of FC's. Actually, this is a WINDOW's file-sys limitation... P.S. WINDOW's dialog-box, seems to be a little confused too(sometimes it's better to look rather than recall). Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 24, 2021 Author Share Posted October 24, 2021 On 10/20/2021 at 11:28 PM, pixelpedant said: It seems to me that for proper function, the FG99 command requires that any file name provided be given in upper case, regardless of the case of the file on the FinalGROM SD card. For example, given a file named (in lower case) "fbforth.bin" on the FinalGROM SD FG99 FBFORTH succeeds for me, while FG99 fbforth fails, with the FinalGROM read light left blinking and "fbforth.bin" not loaded. Probably, this is a limitation of the FinalGROM's approach to file names rather than of FC's. But perhaps a note to this effect could be added to the wiki? I think the protocol to talk to the FG99 requires that they are uppercase.... I should just uppercase them for you. In general though, you'll find that Force Command respects the case-sensitivity of any underlying TI things.... 2 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted October 25, 2021 Share Posted October 25, 2021 On 5/6/2019 at 8:13 PM, jedimatt42 said: Force Command - a command line OS in progress by Jedimatt42 for the TI-99/4A. You can informally call it Jedimatt42's DOS, or Matt's DOS. However its name is 'Force Command' ver 1.28 - October 24th, 2021 - forcecmd_1.28.zip - add some support for introspecting vdp memory map (as setup by ForceCommand) so executables can do discovery addresses for direct manipulation. - add VIRGIL99 ealry days GEMINI protocol browser - fix a memory allocation bug when multiple executables loaded want SAMS. Matt, I missed the first part of yesterday's Zoom Meeting demo of VIRGIL99. Screen is kind of crazy when I start it from the command line. Are there required parameters, setup, paths, etc.? What I saw yesterday looks like a powerful addition to Force Command and my TI! Thanks DG BTW. I am playing with a couple of PC based Gemini browsers to try and learn the ropes. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 25, 2021 Author Share Posted October 25, 2021 27 minutes ago, dgrissom said: Matt, I missed the first part of yesterday's Zoom Meeting demo of VIRGIL99. Screen is kind of crazy when I start it from the command line. Are there required parameters, setup, paths, etc.? What I saw yesterday looks like a powerful addition to Force Command and my TI! Thanks DG BTW. I am playing with a couple of PC based Gemini browsers to try and learn the ropes. It doesn't require anything on storage yet. Does require SAMS, TIPI and F18A. If run with no arguments, just VIRGIL99, it should show a built in page. Crazy like random garbage on the screen? I've seen that with specific page content. But I would expect it to show the built in or the pages at my server just fine. Hmmm. It's early days... I'll see if I can reproduce this. I wonder if I my heap and stack are meeting each other... Quote Link to comment Share on other sites More sharing options...
dgrissom Posted October 25, 2021 Share Posted October 25, 2021 19 minutes ago, jedimatt42 said: It doesn't require anything on storage yet. Does require SAMS, TIPI and F18A. If run with no arguments, just VIRGIL99, it should show a built in page. Crazy like random garbage on the screen? I've seen that with specific page content. But I would expect it to show the built in or the pages at my server just fine. Hmmm. It's early days... I'll see if I can reproduce this. I wonder if I my heap and stack are meeting each other... Have all required hardware. I "pathed" my FCMD directory (contents shown on pic). I ran the VIRGIL99 as a direct file within the directory at the prompt "$ VIRGIL99" Screen doesn't change much. Note the vertical letters in the photo. Computer is still responsive but commands fail (corrupted)? . DG 1 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted October 25, 2021 Share Posted October 25, 2021 40 minutes ago, dgrissom said: Have all required hardware. I "pathed" my FCMD directory (contents shown on pic). I ran the VIRGIL99 as a direct file within the directory at the prompt "$ VIRGIL99" Screen doesn't change much. Note the vertical letters in the photo. Computer is still responsive but commands fail (corrupted)? DG Got it! Used TI99Dir to open the FCMD.DSK. copied them to my FCMD directory(vs letting TIPI take care of it. The files were in V9T9 format. duh. Screen shows Virgil99 built in page. Off to the races (or crashes). DG 2 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 25, 2021 Author Share Posted October 25, 2021 Oh, that's a nice bug! I think force command tried to run the DIS/FIX file as a script... And I guess I should test my DSK... I assumed TIPI would do the right thing with it... :(. Thanks for testing @dgrissom Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted October 25, 2021 Share Posted October 25, 2021 Oh, that's a nice bug! I think force command tried to run the DIS/FIX file as a script... And I guess I should test my DSK... I assumed TIPI would do the right thing with it... . Thanks for testing [mention=66916]dgrissom[/mention]He didn't use tipi he used tidir Sent from my LM-V600 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted October 25, 2021 Share Posted October 25, 2021 Just now, arcadeshopper said: He didn't use tipi he used tidir Sent from my LM-V600 using Tapatalk Yep, was my bad ? Reinstalled the TI99Dir recently. Forgot to configure it to save as TIFILES format only. 1 Quote Link to comment Share on other sites More sharing options...
