Force Command : kinda like command.com from 1985 (no TIPI required!)
If this is the wrong thread for this query, my apologies and mods please delete
I've copied the force command bin files to my fg99 and the FC folder to my tipi (via the tipi web interface) but have a few issues
If I choose the auto version it just cycles me back to the 99 start up menu
If I choose the force version I can do things like DIR ok though
But if I try fg99 ALPINER (for instance) the screen changes colour and the 99 hangs
Likewise if I try something like load TIPI.FC.BIN.TELNET it just hangs
EDIT: sorry, load telnet (or anything else in the bin folder) just causes the 99 to return to the start screen
(I should say my 99 currently boots to the CC9900 start up screen, in case that could be an issue)
Am I just being stupid please?
Many thanks
The fg99 problem was because I was using the cart name as it appears in the menu, when fg99 actually wants the filename on the SD (so BIGFOOT should have been bigfootG). Maybe time to rename the files on my SD.
But I do notice it takes me back to the start screen and I have to select the cart from the cc9900 menu, so am wondering if this is also why the AUTOCMD just seems to loop around
Maybe this will all be resolved once I change the EPROMS on the CC9900
I've used this with a Corcomp floppy controller, but not with the Corcomp eproms... The 'auto' cartridge menu item run the GROM powerup routine to launch into the cartridge rom. Sounds like there are some conflicts with the Corcomp powerup routine and my cartridge powerup routine. ForceCommand is fully functional without the GROM, as it only provides that powerup routine to auto-run the cartridge ROM.
Be careful renaming binaries on the FinalGROM99 SD card. The filename is used to determine the emulation type for the file. Instead of renaming my files, I create list scripts in a directory on my PATH that I can run to go to the desired cartridge. Then I can name the script whatever makes more sense to me.
The other thing, the binaries in TIPI.FC.BIN. are ForceCommand executables. The LOAD command is for EA5 PROGRAMS.
To run a ForceCommand executable or script, Just enter the filename, or directory and filename if it isn't on your path or in the current directory.
Many thanks for the info & advice. Will give it all a try thanks
I decided to create an AUTOCMD which just contains PATH=TIPI.FC.BIN.
When I load Force cmd it's running the script as it's setting my path as specified (can see it with env) and I can simply type TELNET (or whatever) and it runs ok
However, since making the AUTOCMD it gives me a continuous beep on startup until I issue a tipibeeps command which then stops the noise
Would this just be because I created the file using echo PATH=TIPI.FC.BIN. > AUTOCMD from terminal on my Macbook please? (I don't have an editor on the 99 yet)
Many Thanks
Posted (edited)
The beep is a bug. I thought I fixed a while ago, but I guess I missed something.  Placing tipibeeps in the AUTOCMD script likely works around the issue.
I'll have to reinvestgate.
There is an editor built into ForceCommand, try 'help ed' and from within ED, try FCTN-7 (AID)
Apparently I forgot to add ED to the wiki documentation. Oops. (update: added ED to wiki: https://github.com/jedimatt42/fcmd/wiki/Commands#editor)
Edited by jedimatt42
added ed docs to ForceCommand wiki
Many Thanks, that's a lot easier
