atari2600land's Blog - the beginning of the end.
RSS Bot
With only one hole left to design, I thought I might as well code the end. Since I had a whole bunch of spare room, I added an ending screen which displays your final score. I could even add an ending song if I wanted to.
By the way, a final score of one is impossible. I just did that because I started the game on hole 9 for testing.
I tried to design a ninth hole, but it ended up too similar to hole #5 so I threw it out and will try again. The ninth hole in there now is a test hole. At the final score screen, if you press fire, I plan to make it so it will erase your score and you'll end up at hole #1 again. It does that now, but since I made the game start at hole 9, that's where it will end up.
I got my hair cut and my head feels better but it's still hot. Or perhaps my body is in shock because it only got to 52 degrees yesterday.
Attached thumbnail(s)
http://atariage.com/forums/blog/168/entry-15914-the-beginning-of-the-end/
