Atari 2600 color codes - HELP! ;)
lazzeri
Gentlemen!
I'm currently working on a tiny project called AHD - Atari Hacking for Dummies. It is a hacking tool / sprite editor for A2600 that allows sprited editing with a easy-to-use, dumb-proof interface. Detais can be found on the "Hacks" forum.
Anyway, i've just finished the routine that allows color changing on some sprites. I mean, with that you'll be able to change individual color of the sprite's line (in some selected sprites only, unfortunately).
The problem is that for practical reasons i'm willing to limitate the pallete that can be used by the user for a standard 16 color pallete. And i need some help with the hex codes for some colors :D
I still got 3 color with no match, one that do not seems appropriate and a few others that i would like your opinion.
With that in mind i've builded the following table:
Black &0
Dark Blue &a6
Dark Green &d6
Dark Cyan ???? HELP! :)
Dark Red &46
Violet &36
Brown &12
Light Gray &6 - SEEMS TOO DARK :ponder:
Dark Gray ???? HELP! :)
Light Blue &88
Light Green &c8
Light Cyan ???? HELP! :)
Light Red &48
Pink &5a
Yellow &1e
White &e
What do you fine gentlemen think of that colour selection?
Thanks in advance, regards,
Lazzeri
Hi there!
Unless you're programming the tool for windows 3.11, why not use the full palettes and make it even switchable between PAL/NTSC/SECAM?
You can download the z26 sources from http://www.whimsey.com/z26/z26.html and you'll find all info you'd need in the file palette.c
Greetings,
Manuel
Probably because he is using an old DOS based (BASIC?) compiler. Maybe there aren't any libraries that support 256 or more colors.
:idea: You should check [stella], e.g. here!
Wow, you just saved me... :)
I've already seen that particular table elsewere but this time it have both hex and RGB info so i guess now i'll be able to finish the job... Thanks Thomas!
Regards,
Lazzeri
Actually Thomas got it right: It is DOS based...
I can easily (using RGB) program all the 128 colors Stella can generate, and even display them on a low-res screen (320x200).
Problem is that i do use hi-res screen (640x480) and i'm stuck with the 16 simultaneous colour limitation...
I could even use 2 separate display modes, but i'll have to use one with full palette (color change) and one with reduced (sprites display / anim / edition), and the colours wouldn't match. So it do NOT seem viable to use a wider palette...
Sh*t... :x
Greetings,
  Manuel
Thanks,
Lazzeri
Unless you're programming the tool for windows 3.11, why not use the full palettes (...)
As i've stated on AHD forum, i'm not a real programmer... :lolblue:
Seriously: I'm stuck with the 16 colour pallete on 640 x 480, and if my aim is to use 256 colours i'll have to reduce resolution to 320 x 480 (impossible) OR use a dual-pallete system...
I don't thing it would be of any use... Anyway, i guess i still have lots to thing about...
Thanks again Thomas,
Lazzeri
What compiler are you using? Maybe there are extensions availably (using VESA) that add more graphic modes. You should try googleing for them.
I'm not sure which Basic you are using, but you can use the higher VESA modes in QuickBasic or QuickBasic Extended (QB 4, PDS 7.00, or VB-DOS) by calling various BIOS interrupts. There isn't a SCREEN command, but I've written replacements for SCREEN, POINT, LINE and a combo LOCATE/PRINT. Mouse stuff should work fine too. I also have the original C version I wrote if you want it.
calamari
'Graphics and line drawing routines
'Copyright (C) 2002, 2003 by Jeffry Johnston.
'Released under the GPL.  See license.txt for details
'Ported to QuickBasic from my original C source, 2003
'To load this program:
'In QBX: QBX GRAPHICS.BAS /L QBX
'In QB, it will be something like: QB GRAPHICS.BAS /L QB
DEFINT A-Z
DECLARE SUB graphicsMode ()
DECLARE SUB drawLine (X1, Y1, X2, Y2, COLR)
DECLARE SUB drawPoint (X, Y, COLR)
DECLARE SUB drawText (Y, X, S$, COLR)
DECLARE SUB textMode ()
TYPE RegType 'for CALL INTERRUPT
 ax    AS INTEGER
 bx    AS INTEGER
 cx    AS INTEGER
 dx    AS INTEGER
 bp    AS INTEGER
 si    AS INTEGER
 di    AS INTEGER
 flags AS INTEGER
END TYPE
DECLARE SUB Interrupt (intnum AS INTEGER, inregs AS RegType, outregs AS RegType)
COMMON SHARED BANKOLD
'switch to graphics mode
CALL graphicsMode
'draw some lines
FOR Y = 344 TO 599: CALL drawLine(0, Y, 799, Y, Y MOD 256): NEXT Y
FOR Y = 0 TO 9: CALL drawLine(0, 100 + 10 * Y, 799, 100 + 11 * Y, 15): NEXT Y
CALL drawLine(0, 0, 799, 599, 1)
CALL drawLine(799, 0, 0, 599, 2)
CALL drawLine(0, 0, 0, 599, 3)
CALL drawLine(0, 599, 799, 599, 4)
CALL drawLine(799, 599, 799, 0, 5)
CALL drawLine(799, 0, 0, 0, 6)
'draw some points
FOR I = 0 TO 799: CALL drawPoint(I, 100 * SIN(6.28 * I / 799) + 200, 4): NEXT I
'draw some text
CALL drawText(3, 43, "Graphics test", 15)
'pause for keypress
DO: LOOP WHILE INKEY$ = ""
'go back to text mode then exit
CALL textMode
PRINT "Back in text mode"
END
 'This routine uses a standard y=mx+b plot.
 'The axis (x or y) with the longest distance is chosen.  There are
 'two reasons:  1) Since there are only as many points plotted as on one
 'axis or the other, choosing the smaller axis would mean having small
 'gaps in the line.  2) It also makes drawing vertical lines possible.
 'Normally that is impossible because the slope would try to divide by
 'zero.  But, we can instead plot x=my+b.
 XL = ABS(X2 - X1)
 YL = ABS(Y2 - Y1)
 IF XL >= YL THEN
   IF X1 < X2 THEN
     XB = X1: YB = Y1
   ELSE
     XB = X2: YB = Y2
   END IF
   M! = (Y2 - Y1) / (X2 - X1)'slope
   FOR X = 0 TO XL
     Y = CINT(M! * X)
     CALL drawPoint(X + XB, Y + YB, COLR) 'y=mx+b
   NEXT X
 ELSE
   IF Y1 < Y2 THEN
     XB = X1: YB = Y1
   ELSE
     XB = X2: YB = Y2
   END IF
   M! = (X2 - X1) / (Y2 - Y1)'slope
   FOR Y = 0 TO YL
     X = CINT(M! * Y)
     CALL drawPoint(X + XB, Y + YB, COLR) 'x=my+b
   NEXT Y
 END IF
END SUB
 'ldiv_t location=ldiv(800*y+x,65536);
 LOCATION& = 800& * Y + X
 BANK = LOCATION&  65536
 DIM regs AS RegType
 IF BANK <> BANKOLD THEN
   regs.ax = &H4F05           'CPU VIDEO MEMORY CONTROL
   regs.bx = &H0              'BH=00h select video memory window
   regs.dx = BANK             'window address in granularity units
   Interrupt &H10, regs, regs 'call BIOS
   BANKOLD = BANK
 END IF
 POKE LOCATION& MOD 65536, COLR
END SUB
 DIM regs AS RegType
 regs.ax = &H200            'SET CURSOR POSITION
 regs.bx = &H0              'page 0
 regs.dx = 256 * Y + X      'row & column
 FOR N = 1 TO LEN(S$)
   LETTER = ASC(MID$(S$, N, 1))
   regs.ax = &HE00 + LETTER   'TELETYPE OUTPUT / character to display
   regs.bx = COLR             'page 0 / color
 NEXT N
END SUB
SUB graphicsMode
 DIM regs AS RegType
 regs.ax = &H4F02           'SET SuperVGA VIDEO MODE
 regs.bx = &H103            'VESA video mode 800x600x256 colors
 regs.ax = &H1124           'GRAPHICS MODE CHARACTER GENERATOR 8x16 CHARS
 regs.bx = &H3              '43 lines (really 37.5 but who's counting?)
 DEF SEG = &HA000: BANKOLD = 0
END SUB
SUB textMode
 DIM regs AS RegType
 regs.ax = &H3              'SET VIDEO MODE, BIOS 80x25x16 colors
 CLS : DEF SEG
END SUB
Archived
This topic is now archived and is closed to further replies.
