xucaen Posted January 19, 2005 Share Posted January 19, 2005 Thank you Andrew and Thomas, I do understand now. and to figure out where I went wrong I picked up the stella guide again for the 20+Nth time and I read the following.. Simply writing to the WSYNC causes the microprocessor to halt until the electron beam reaches the right edge of the screen, then the microprocessor resumes operation at the beginning of the 68 color clocks for horizontal blanking. For some reason I had thought it meant wsync halts the cpu until the beam reaches the left side of the screen. So you see why I was confused... it's good to know that I do have those 68 clocks (68/3=22.667 cycles) to use for game logic after all. Very cool. Jim Quote Link to comment Share on other sites More sharing options...
supercat Posted June 3, 2005 Share Posted June 3, 2005 Our 'zero point' of any scanline is the beginning of horizontal retrace. This is the point at which the TIA re-enables the 6502 if it has been halted by a WSYNC write. At the beginning of any scanline, then, we know that we have exactly 68 colour clocks (=68/3 = 22.667 cycles) before the TIA starts 'drawing' the line itself. Is that the start of horizontal RETRACE or horizontal BLANKING? My recollection is that the TIA reenables the 6507 when the electron beam hits the right-side border, which is actually a fair bit before the beam actually starts sweeping left. I fully appreciate that it's often useful to regard a scan line as starting as soon as the displayed portion of the previous one ends (indeed, that's how I've drawn timing charts when working out code) but in some goofy cases the distinction might be important. BTW, would STA $xx be suitable for use as a three-cycle NOP, where $xx is a non-existent TIA write register? I know that some registers like $3F may be used for some bank-switching carts, but I would think some should be available. Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted June 3, 2005 Share Posted June 3, 2005 Hi there! BTW, would STA $xx be suitable for use as a three-cycle NOP, where $xx is a non-existent TIA write register? I know that some registers like $3F may be used for some bank-switching carts, but I would think some should be available. 866950[/snapback] For a three cycle delay you can just use SLEEP 3 Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
its-a-feature Posted May 29, 2020 Share Posted May 29, 2020 (edited) Hi, so I'm just getting into 6502 assembly programming, and I'm having a hard time figuring out how to edit PF1 mid scanline I was wondering if anybody could explain it to me. Also I'm on PAL, so I have 242 screenlines instead of 192. Edited May 29, 2020 by its-a-feature Quote Link to comment Share on other sites More sharing options...
