HeadcolorsTV Posted July 11, 2019 Author Share Posted July 11, 2019 2 hours ago, emerson said: Try putting jumper wires where I put the purple ones here. THAT WAS IT. ??? Thank you so much for that tip. I just ran through an entire game of TM2 with 0 problems. (BTW: a Happ bat top stick feels really good with that game.) OshPark, here I come. ~ Fin. ~ Quote Link to comment Share on other sites More sharing options...
emerson Posted July 11, 2019 Share Posted July 11, 2019 Good, I'm glad everything works now. It's good practice to just leave those "purple jumpers" installed. It's easy to forget those power busses aren't connected in the middle. 1 Quote Link to comment Share on other sites More sharing options...
HeadcolorsTV Posted November 21, 2019 Author Share Posted November 21, 2019 On 7/11/2019 at 5:53 AM, emerson said: Good, I'm glad everything works now. It's good practice to just leave those "purple jumpers" installed. It's easy to forget those power busses aren't connected in the middle. Resurrecting this because I'm having an issue that I completely brain-farted on until now. I've had this circuit fabbed at Osh Park some time ago, assembled everything. Works! ...Yay. Can't read memory cards from the same slot. ...Booo. I read up a little bit so far on this issue with 3rd-party controllers; something about sending an 0x81 signal to ATT. Anyone know anything about this, and how I'd go about working through/around this? Quote Link to comment Share on other sites More sharing options...
emerson Posted November 21, 2019 Share Posted November 21, 2019 (edited) Quote The original PlayStation is a bit different, however, as rather than having a separate ATT pin for each device (four in total for two controllers and two memory cards) it only has two - one for controller+memory card 1 and another for controller+memory card 2. The difference here is that when the console addresses a controller the first byte it sends is 0x01, but when it addresses a memory card the first byte it sends is 0x81. A device therefore can't rely on just checking the ATT pin, it needs to also check the first byte that is sent to it and only respond if the byte sent (0x01 or 0x81) matches the type of device that it is (controller or memory card, respectively). The above excerpt from the link you posted explains exactly what needs to be done. Here is one approach. It may not be totally correct but somewhere to start none the less... Use a serial to parallel shift register (74xx164) to monitor the first byte of data, presumably on the 'command' line of the controller port. Use a binary counter (74xx90) to disable both the '164 shifting and '90 counting on the 8th clock pulse. This allows the '164 to hold the command byte. We know that the controller should only be enabled when this data byte is 0x01. We also know that the '240 only outputs signals when /1OE and /2OE are asserted low. Design a decoder circuit that enables the '240 when the '164 parallel output is 0x01 and disables the '240 with any other output. Use the 'att' line to reset the '164 and '90 for the next controller port command. Edited November 21, 2019 by emerson 1 Quote Link to comment Share on other sites More sharing options...
