Synthpopalooza Posted August 14, 2019 Author Share Posted August 14, 2019 OK, here it is ... This tune demonstrates the strengths of the SKCTLS 2-tone mode. You can reach the high notes easily without tuning errors, and by varying the pulse width, still play the normal range available in the $Ax pure tone settings. The tune is, of course, the famous opening intro music from the SNES game Super Mario World. Here is the setup: AUDCTL=$00 (no special settings) Channel 0: $Ax square wave, modulated from Channel 1 using SKCTLS=$8B 2-tone mode Channel 1: Silent - frequency setting modulates Channel 0 Channel 2: $Ax square wave, no modulation Channel 3: $Ax square wave, no modulation The 2-tone SKCTLS=$8B mode is quite similar to the SYNC function on the C=64 SID chip. The frequency on channel 1 must always be higher than 0, and when the modulation frequency gets beyond 12 semitones from channel 0, channel 0 then jumps up an octave. So basically, channel 1 mimics the melody on channel 0, but transposed up an octave plus some semitones. The counterpoint melody has channel 1 transposed lower, so as to vary the pulse width. Executables below, but a warning: This will not work correctly in the current emulation. On Prosystem and A7800 the lead will sound horribly out of tune. Real hardware only. Trebor: I have included a Pokey @$450 executable as well. Please test this on your real hardware and record it. Also included: A recording made from the Altirra emulator which demonstrates how this should sound on real hardware, assuming I ported everything correctly. marioworld.A78 marioworld.asm marioworld.bin marioworld-pokey450.A78 marioworld-pokey450.asm marioworld-pokey450.bin marioworld.mp3 2 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted August 15, 2019 Share Posted August 15, 2019 18 hours ago, Synthpopalooza said: Trebor: I have included a Pokey @$450 executable as well. Please test this on your real hardware and record it. Sounds just like the mp3 ? RealHW_Super Mario World (Opening Melody) (20190814).wav 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 15, 2019 Author Share Posted August 15, 2019 That's actually incorrect I made a typo in the listing. Will upload the corrected version tonight. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 15, 2019 Author Share Posted August 15, 2019 Found the mistake: PLAYTUNE LDA #00; normal mode STA AUDCTL LDA #139 STA $D20F $D20F should be replaced with SKCTLS. It seems I broke the #1 rule of assembly programming: NEVER reference memory locations directly, always by their label. I used $D20F because that's where SKCTLS is on an 8-bit XL/XE. On the 7800 ... nahh. ? I will post a fixed version tonight after work. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 15, 2019 Author Share Posted August 15, 2019 OK, new builds ... These should be correct. Please check ... thanks. marioworld.A78 marioworld.asm marioworld.bin marioworld-pokey450.A78 marioworld-pokey450.asm marioworld-pokey450.bin Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 15, 2019 Author Share Posted August 15, 2019 Another note table. This time we are using the SKCTLS=$8B mode, combined with AUDCTL=$40 to clock the first channel at 1.79 mhz. This is the "Save to cassette" sound setting which the old Atari XL used when saving or loading from cassette. It's a very sonorous bell type timbre. You can also get a saw wave out of this setting by varying the pulse width. Here is a rudimentary table: Bell sound AUDCTL=$40 SKCTLS=$8B AUDC0=$Ax AUDC1=$00 Note AUDF0 AUDF1 B2 253 255 C3 241 243 C# 245 230 D 251 217 D# 236 204 E 244 193 F 253 182 F# 239 172 G 250 162 G# 236 153 A 250 144 A# 236 136 B 255 128 C4 241 121 c# 227 114 D 251 108 D# 237 102 E 223 96 F 254 91 F# 238 85 G 226 81 G# 212 76 A 252 72 A# 238 68 B 224 64 C5 210 60 C# 200 57 D 249 53 D# 235 50 E 221 47 F 212 45 f# 198 42 G 188 40 The frequencies in channel 1 correspond to the standard 8-bit note table for $Ax square wave, as found in my POKEY note table. The $4x distortion also allows for some electric guitar sounds using the AUDCTL=$40 setting. This will take a lot more work to map out, but they sound terrific! Also showing promise is the $8x noise combined with AUDCTL=$C0 (1.79 mhz plus the 9-bit polycounter) for more guitar distortions. 2 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 17, 2019 Author Share Posted August 17, 2019 (edited) This is proving to be real donkey work: A partial test table for $4x distortion with AUDCTL=$40 (1.79 mhz clock) and SKCTLS=$8B (2-tone modulation) ... I have written a program that lets me step through each of the 65,536 possible settings ... and I am writing down by hand which ones produce musical notes. There are several different timbres here, many of them suitable for distorted guitars. Later, after I have gone through them all, I will have to tune them against the standard $Ax square wave settings to get a tuneable scale. This is going to be a lot of work but the results will be worth it in the end. The notes here are without octave modifiers, I will add those later. This is the beginning ... a long way to go yet. I also put in a few notes for the AUDCTL=$41 (1.79 mhz plus 15 khz, which changes the modulation frequency of channel 1). A lot of these settings sound really terrific though, just like a real electric guitar. Distorted guitar (partial frequency table without octave modifiers) AUDCTL=$41 SKCTLS=$8B $AUDC1=$4x AUDC2=$00 AUDF2 AUDF1 255 254 (d#) 253 (g#) 247 (A#) 242 (C#) 233 (e) 232 (c) 230 (c) 229 (c#) 227 (b) 225 (c) 224 (g#) 218 (b) 217 (F#) 215 (a#) 210 (c) 204 (e) 200 (a) 199 (a#) 197 (a) 194 (A#) 190 (D) 188 (b) 183 (a#) 178 (c#) 175 (a) 173 (c) 172 (d#) 170 (a#) 163 (g) 160 (c#) 155 (c#) 152 (f) 149 (a) 148 (g#) 140 (b) 139 (e) 135 (d#) 130 (g#) 127 (c#) 122 (f#) 119 (c#) 114 (c) 113 (c) 112 (a#) 110 (a) 107 (c) 103 (c) 100 (e) 98 (a) 93 (D) 92 (b) 88 (e) 87 (c) 85 (d) 84 (e) 82 (d#) 78 (c#) 77 (d#) 72 (g#) 69 (b) 68 (b) 60 (b) 55 (b) 53 (g#) 49 (c#) 44 (b) 37 (c#) 34 (g#) 33 (c) 28 (b) 20 (b) 15 (g#) 12 (b) 8 (b) 4 (b) 2 (b) 0 (b) 254 251 (silence) 243 (b) 231 (c) 230 (c) 229 (d) 228 (A#) 227 (b) 226 (b) 216 (d) AUDCTL=$40 SKCTLS=$8B $AUDC1=$4x AUDC2=$00 255 246 (a) 233 (f#) 232 (a#) 230 (f#) 227 (f#) 224 (f#) 211 (g#) 200 (e) 189 (c) 184 (c#) 179 (e) 175 (g#) 170 (f#) 154 (c) 145 (c) 139 (a) 132 (b) 126 (a) 121 (a) 113 (f) 112 (f#) 110 (f) 98 (e) 96 (g#) 85 (c) 82 (g) 81 (g) 79 (c) 75 (c) 74 (f) 73 (f) 72 (f) 67 (c) 64 (b) 63 (b) 60 (b) 59 (f) 53 (f) 52 (c#) 50 (f) 44(f) 43 (c#) 35 (f) 34 (f) 31 (g#) 30 (b) 28 (b) 24 (c#) 23 (f) 15 (f) 13 (b) 12 (b) 10 (c#) 4 (b) 3 (c#) 0 (b) 254 254 (g#) 251 (silence) 203 (g) 200 (b) 188 (f#) 170 (f) 143 (b) 128 (c#) 118 (e) 102 (c#) 98 (a#) 95 (f) 92 (f) 87 (e) 83 (e) 82 (a) 80 (c#) 64 (a#) 62 (c#) 60 (f#) 49 (c#) 47 (a#) 45 (b) 40 (c) 38 (d) 34 (g#) 33 (b) 30 (a#) 29 (c) 25 (f) 24 (c#) 18 (c) 17 (c#) 16 (b) 13 (a#) 10 (c#) 8 (b) 7 (c) 3 (c#) 2 (b) 0 (b) 253 243 (d) 242 (e) 241 (g) 231 (g) 226 (g#) 216 (g#) 215 (f#) 214 (d) 204 (a#) 203 (e) 187 (c) 170 (e) 169 (f) 168 (c#) 163 (f) 162 (c) 160 (b) 157 (e) 145 (f#) 142 (f#) 139 (f#) 138 (g#) 133 (c) 119 (e) 117 (c) 115 (f#) 113 (f#) 111 (a) 106 (a) 105 (d) 104 (f) 95 (f) 82 (c#) 79 (c) 78 (b) 73 (c) 69 (f) 67 (g#) 66 (g#) 57 (a#) 55 (b) 52 (c#) 51 (g#) 50 (f) 47 (f) 45 (g#) 40 (g#) 37 (b) 32 (f) 31 (g#) 24 (d) 23 (f) 14 (f) 10 (c#) 5 (f) 4 (b) 3 (c#) 0 (b) Edited August 17, 2019 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted August 17, 2019 Share Posted August 17, 2019 @Synthpopalooza Once you get your table sorted you have a crack at the Game Over sound for Wizball on the c64 ? Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 17, 2019 Author Share Posted August 17, 2019 (edited) I could do that a bit sooner. That one uses a different kind of sound similar to one of my other settings. On the $4x table, there are lots of sounds with the same tonal frequency but different vibrato pulse widths. Still getting those all sorted. Edited August 17, 2019 by Synthpopalooza 2 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 17, 2019 Author Share Posted August 17, 2019 The other possibility is slapping a hi-pass filter on top of this setup to further modulate the sound as well. The tradeoff is you are basically using 3 channels to generate one sound, which leaves one channel free. But, for purposes of that wizball game over sound, it may be all that is needed. The last channel can then play a standard $Ax square wave frequency to tie it together. 2 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 18, 2019 Author Share Posted August 18, 2019 I have been tasked to do music for an NES game based on the TV show Stranger Things, and will be doing 7800 music for this as well. One of these is going to use some of these experimental techniques ... in particular the above $4x SKCTLS setting coupled with 15khz mode. I will post this up when I have a test ready. 3 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted August 19, 2019 Share Posted August 19, 2019 On 8/14/2019 at 11:50 PM, Synthpopalooza said: OK, new builds ... These should be correct. Please check ... thanks. RealHW_Super Mario World Opening Melody (v2).wav 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 19, 2019 Author Share Posted August 19, 2019 Sounds great! Does your cart have an actual POKEY, or the more recent POKEYOne? I am not sure if the POKEYOne supports the SKCTLS 2-tone mode, so I was curious. Quote Link to comment Share on other sites More sharing options...
+Trebor Posted August 19, 2019 Share Posted August 19, 2019 It's a true POKEY. It was built way before POKEYOne was a thing. I have the MCP DevCart for well over five years, thanks to CPUWIZ. 2 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 19, 2019 Author Share Posted August 19, 2019 That is cool. I would be curious to know how well the PokeyOne handles all these special AUDCTL and SKCTLS settings. 1 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted August 19, 2019 Share Posted August 19, 2019 7 minutes ago, Synthpopalooza said: I would be curious to know how well the PokeyOne handles all these special AUDCTL and SKCTLS settings. Me too. Still too pricey at $40 a pop, but if it covers all audio features at least it is a possible, if not a financially sound, alternative for 7800 homebrews. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 19, 2019 Author Share Posted August 19, 2019 The thing is, SKCTLS was originally intended for use as an aid to cassette drive and floppy disk I/O or for generating modem carrier, dial tones, or touch tones. I don't think it was expected that this would be used for music, so the POKEYOne creators may have left this functionality out. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 19, 2019 Author Share Posted August 19, 2019 Also I am hopeful that with time, the price of POKEYOne will drop. We can't keep cannibalizing Ballblazer carts. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 19, 2019 Author Share Posted August 19, 2019 So that's a no on the 2-tone mode. The other AUDCTL settings should work as normal, but I think they'd need to be tested. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 19, 2019 Author Share Posted August 19, 2019 (edited) Trebor: I went and recompiled the earlier Bubble Bobble and Mega Man examples for POKEY@450 ... here they are. They both fail on emulation but should work in real hardware. Bubble Bobble actually works correctly in Prosystem but won't play notes above a certain frequency on the lead. bubblebobble-pokey450.A78 bubblebobble-pokey450.asm bubblebobble-pokey450.bin megaman-pokey450.A78 megaman-pokey450.asm megaman-pokey450.bin Edited August 19, 2019 by Synthpopalooza Quote Link to comment Share on other sites More sharing options...
+Trebor Posted August 25, 2019 Share Posted August 25, 2019 They sound GREAT! The Bubble Bobble demo is extra sweet. While the entire converted melody is excellent, between 0:16 thru 0:24 and again 0:34 thru 0:42 are my favorite parts. Real_hw_Mega Man 2 (Start Level Music Demo).wavReal_hw_Bubble Bobble Theme Sound Demo.wav 1 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 25, 2019 Author Share Posted August 25, 2019 (edited) Good news ... means I have a workaround through Altirra for developing these on real hardware. Next up: A stranger things theme which uses 15khz mode. This basically lets you transpose your $Ax square wave channels down 2 octaves and use the bass setting. This can be combined with $2x and the 1.79 mhz clock on 1 or 3 to get your lead sounds. The bass will work in emulation, I think. There is also a reverse 16-bit filter using $Cx on channel 0, which makes for some strange sounding wood instrument timbres. This will require a new note table. Edited August 25, 2019 by Synthpopalooza Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 25, 2019 Author Share Posted August 25, 2019 (edited) Also: going to rework the Rolling Thunder music for @450 tonight. Very keen on hearing this one in real HW. Also, this one: It uses a very high G5 note at the start. In 8 bit mode, this turns the POKEY to mush. But in the SKCTLS 2-tone mode ... no problems. I will work this up soon. I'd love to see this on our 7800. Edited August 25, 2019 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted August 25, 2019 Share Posted August 25, 2019 On a role @Synthpopalooza ? Bubble Bobble sounds great! Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 25, 2019 Author Share Posted August 25, 2019 I am a big fan of that game. If anyone ever decides to make it we've got a head start on the music. 1 Quote Link to comment Share on other sites More sharing options...
