RevEng Posted September 29, 2019 Share Posted September 29, 2019 Sounds like phasing. TIA can do the same as well, which isn't surprising I guess. 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted September 29, 2019 Author Share Posted September 29, 2019 (edited) It's kind of a cancellation through phasing. A subtractive filter. For example, if both squares play at the same period and frequency: ___|"""|___ """""|__|"""" They cancel each other out and you get near silence. But delay one by a cycle: ___|"""|___ """"|__|""""| The duty cycle pulse wave is created, and the more cycles apart the waves are, the wider the pulse. This emulates the NES function. By stepping either frequency up or down a step, makes a swirling tone because of the differing wavelengths. The trick is in maintaining the cycle. In my music routine, the oscillators tend to drift. It may require a timer reset each time a note is played. Edited September 30, 2019 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted September 30, 2019 Author Share Posted September 30, 2019 I believe the Phasing done by TIA is of an additive sort. POKEY can do this too, for example, playing two square notes an octave apart creates a 50% duty cycle pulse, via additive phasing. If you listen to the Bentley Bear music you will hear this effect in the lead sound halfway through the tune. What the hi pass filter does, is in a subtractive capacity. The cycle of the third channel filters out elements of the first one. 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted September 30, 2019 Share Posted September 30, 2019 Got ya - yep missed the filter bit in your post! Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted October 23, 2019 Author Share Posted October 23, 2019 (edited) OK, more tests ... using new settings. First up, is a rendition of the Stranger Things theme. This one uses the following settings: AUDCTL=$F1 (16 bit mode on 0 and 1, main clock 15 khz, clock 0 and 2 at 1.79 mhz, 9-bit polycounter) 0: $8x - 9-bit polycounter at 1.79 mhz, 16-bit mode reversed, distorted guitar sound 1: silenced - modulates the vibrato of channel 0 2: $2x triangle wave- at 1.79 mhz. melody sequence. 3: $Ax square wave- at 15 khz. Bass sequence. An explanation of these settings: 15 khz mode basically transposes all four channels down two octaves, allowing $Ax square wave to be used as a bass instrument without requiring 16-bit mode. The standard $Ax square wave 8-bit note table is used, but transposed down two octaves. 15 khz mode will not affect any channels clocked with 1.79 mhz, which means you can use $2x clocked at 1.79 mhz to play your higher leads here. Channels 0 and 1 are the new feature here. It is a reversed 16-bit setting using the $8x on 9-bit polycounter at 1.79 mhz, same as the Rolling Thunder demo, but with an entirely new note table shown below: c1 142 212 c# 148 201 d 154 189 d# 159 178 e 164 168 f 169 160 f# 173 152 g 178 141 g# 182 133 a 185 127 a# 189 119 b 192 113 c2 195 107 c# 198 101 d 201 95 d# 204 89 e 206 85 f2 209 79 f#2 211 75 g 213 71 g# 215 67 a 217 63 a# 219 59 b 221 55 c3 222 53 c# 223 51 d 225 47 d# 227 43 e 228 41 f 229 39 f# 230 37 g 231 35 g# 232 33 a 233 31 a# 234 29 b 235 27 c4 236 25 Basically, channel 0 carries the frequency, but channel 1, when varied by a few steps above or below the indicated value, will introduce a warbling vibrato effect to the guitar! A note: I have not yet figured out how to silence the zero frequencies (meant to be note rests), so they will unfortunately play. If anyone can look at the code, i'd appreciate it. I know @RevEng gave me some modifications for this, but they destroyed the timing of the track. More work needed I guess. Emulation notes: This time it is a mixed bag. Prosystem plays the tune ok but won't do the 9-bit poly, so you hear white noise. A7800 actually plays this well too, except the 2nd $2x channel is played an octave too high, and the $8x 9-bit poly is actually done, but sounds more out of tune than on real hardware. However, the 15 khz clock works correctly in both emulators! Yaay Binaries below, @$4000 and @$450 for POKEY. Test these out please. Also a .wav recording from Altirra. strangerthings-450.A78 strangerthings-450.asm strangerthings-450.bin strangerthings.A78 strangerthings.asm strangerthings.bin strangerthings.wav Edited October 23, 2019 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted October 24, 2019 Author Share Posted October 24, 2019 (edited) Now, for the second test: Also from Stranger Things, the very eerie "Upside Down" theme music. These are the settings used: AUDCTL=$23 - 15 khz master clock, 1.79 clock on channel 2, hi pass modulation of channel 1 from channel 3. Channel 0: $Ax square at 15 khz - bass hit. Channel 1: $Ax square wave sequence hit at 15 khz - modulated from channel 3 Channel 2: $Cx sawtooth at 1.79 mhz Channel 3: Silenced. Frequency modulator for channel 1 So, to explain: 15 khz again sets all the standard $Ax square channels down two octaves, enabling bass frequencies to be played. On channels 1 and 3, we get a good demonstration of the mis-named hi-pass filter. In this case, we get an emulation of the NES duty cycle. Here's how it works ... You play the identical frequency on both 1 and 3. By delaying the start of the frequency on channel 3, you put the oscillators out of sync and generate a duty cycle pulse sound. The further the delay, the further the width of the pulse wave. If you use the setting where the frequencies are the same, but you set the second frequency to a step above or below the first, you get a swilrling synth tone. This method is used part way into the tune. Further in, the tune switches to a very low bass sequence, which is achieved by setting channel 3 to play 5 semitones above the first channel, with frequencies taken from this table below, a slight modification of the standard $Ax 8-bit note table: AUDCTL=$04 AUDC1=$Ax AUDC2=$00 Uses these intervals. AUDF1=AUDF2 AUDF1=AUDF2+4 semitones AUDF1=AUDF2+7 semitones AUDf1=AUDF2+12 semitones (one octave) ... pulse wave AUDF2=AUDF1+5 semitones AUDF2=AUDF1+7 semitones AUDF2=AUDF1 + octave These are the best settings to produce musical tones. Other settings will produce noise. In this case, the pulse width gradually and randomly changes as the tune progresses. It is possible to set the pulse width at will, by playing a zero frequency a set number of cycles and then re synch-ing the oscillators. Channel #2 is $Cx set to 1.79 mhz ... high frequency notes, which are used for a high arpeggio in the middle of the tune. Again, I haven't solved the zero frequency whine problem ... still working on that unfortunately. Emulators: Surprisingly, A7800 plays this nearly flawless! The pulse width varies a bit more than actual hardware, but everything else is spot on. Prosystem in this case completely botches the modulation, you just hear a constant square wave throughout. Binaries and sources for both $450 and $4000. Tests on real hardware are always appreciated ... as are tips on how to kill those zero frequencies! upsidedown.A78 upsidedown.asm upsidedown.bin upsidedown-450.A78 upsidedown-450.asm upsidedown-450.bin upsidedown.wav Edited October 24, 2019 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted October 27, 2019 Share Posted October 27, 2019 On 10/23/2019 at 3:36 PM, Synthpopalooza said: First up, is a rendition of the Stranger Things theme. Real hardware... Stranger Things Main Theme Music - Real HW.mp3 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted October 27, 2019 Share Posted October 27, 2019 On 10/23/2019 at 8:14 PM, Synthpopalooza said: Now, for the second test: Also from Stranger Things, the very eerie "Upside Down" theme music. Tests on real hardware are always appreciated ... Found something interesting when recording this one - unsure if it is intentional or not. Every time I pressed 'Reset' to start the demo it began in a different key/frequency. I've attached two mp3s. Part 1 is running the demo with me pressing reset every 2-3 seconds. Part 2 is just a straight playback of the demo after the console was powered off for ~5 minutes: Stranger Things Upside Down Theme Music - Real HW PT 2.mp3Stranger Things Upside Down Theme Music - Real HW PT 1.mp3 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted October 27, 2019 Author Share Posted October 27, 2019 3 hours ago, Trebor said: Found something interesting when recording this one - unsure if it is intentional or not. Every time I pressed 'Reset' to start the demo it began in a different key/frequency. I've attached to mp3. Part 1 is running the demo with me pressing reset every 2-3 seconds. Part 2 is just a straight playback of the demo after the console was powered off for ~5 minutes: Stranger Things Upside Down Theme Music - Real HW PT 2.mp3 5.18 MB · 3 downloads Stranger Things Upside Down Theme Music - Real HW PT 1.mp3 1004.51 kB · 3 downloads Yes. That is because the phasing of the oscillators (channels 1 and 3) is not constant. Looking for a way to stabilize this. 1 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted October 27, 2019 Share Posted October 27, 2019 4 hours ago, Synthpopalooza said: Yes. That is because the phasing of the oscillators (channels 1 and 3) is not constant. Looking for a way to stabilize this. Ah...Thank you for the explanation. Quote Link to comment Share on other sites More sharing options...
emkay Posted October 27, 2019 Share Posted October 27, 2019 6 hours ago, Synthpopalooza said: Yes. That is because the phasing of the oscillators (channels 1 and 3) is not constant. Looking for a way to stabilize this. If you play the depending channels for some cycles at the highest tone, the result gets 99% stable . in 15khz and in 64kHz Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted October 27, 2019 Author Share Posted October 27, 2019 Listening to the reset version of the tune, what you are hearing are the different duty cycles generated by varying phases of the oscillators... both play the same frequency, but the different phasing of the third oscillator is what generates the varying duty cycles. Going to try some tricks on it to improve it. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted October 27, 2019 Author Share Posted October 27, 2019 4 hours ago, emkay said: If you play the depending channels for some cycles at the highest tone, the result gets 99% stable . in 15khz and in 64kHz So to clarify ... I play the zero frequency on the 2nd channel, not the 4th? For about a cycle, then switch to the tone? Quote Link to comment Share on other sites More sharing options...
emkay Posted October 27, 2019 Share Posted October 27, 2019 Both channels put together for (filter) , then play the highest pitch on both . If you write your own code, you have to assure that POKEY is really playing the high peak. If you use channel 0 and 2 , you could set them to 1.79MHz for speeding up things. Using 15kHz it may need a quarter frame. In RMT it is always a full VBI Cycle, as the editor doesn't support it. You can also speed things up there, if the engine runs at 2 ,3 or 4 times VBI speed. In the later tunes I'm doing the "reset" in low volume parts or when short pauses allow it. 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 13, 2020 Author Share Posted March 13, 2020 Resuming the experiments ... I am now playing around with $4x distortions in 1.79 mhz settings. This creates some harsh bass sounds. Like $Cx, there are two modes in $4x ... when using frequencies divisible by 3, a less harsh tone can be had, although again you get three random timbres. This setting can be used in 16-bit mode, but the only advantage is three extra notes on the low end. Demo coming soon. ? 3 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 17, 2020 Author Share Posted March 17, 2020 (edited) Demo complete ... This is a rendition of the Deep Purple song "Smoke On The Water" The following settings were used: AUDCTL=$F0 - 16 bit filter on 0 and 1, clocked at 1.79 mhz, 9 bit poly counter, channel 2 clocked at 1.79 mhz 0 and 1: $8x, reverse 16-bit filter, 1.79 mhz clock, 9-bit polycounter - distorted guitar 2: $4x, clocked at 1.79 mhz - bass 3: $Ax, no special settings - standard square wave This is my first experiment with the $4x distortion. Normally this is not used musically, but with a 1.79 mhz clock, bass frequencies become usable. Like in the $Cx distortions, 2 frequency tables are in use: Distortion 4a: Frequencies where (freq+1) mod 3 <> 0. These frequencies produce harsh bass sounds. The timbre sounds close to the snarling sound Donkey Kong makes in the Atari 8-bit port of Donkey Kong Distortion 4b: Frequencies where (freq+1) mod 3 = 0 and (freq+1) mod 5 <>0. This produces a less harsh bass timbre. Like in 12b, random timbres are produced, depending on system timers. Also, like in the $Cx distortions, a $0E frequency produces silence. Some thoughts: This can be used in either 8-bit or 16-bit mode, but 16-bit mode does not confer any special advantages, apart from six extra notes on the low end for Distortion 4b. You have an effective frequency range in 4b from about F#1 up to about the 3rd octave before tuning errors set in. 4a lets you go down to C1, but has a lower top range, up to about A2. Notes for this channel are taken from my POKEY note table, distortion 4b, 8-bit mode. Because this setting will not play below F#1, the F1 note used comes from the 4a table. On channels 0 and 1, $8x with 9-bit poly is used, in reverse 16-bit mode, where channel 0 plays, and 1 is silenced. The note table used here is the same as for the Stranger Things demos. This creates the distorted guitar sound. Channel 3 plays a stardard $Ax square wave which makes the lead sound. Emulators: Emulators are a mixed bag. Both fail at this. Prosystem comes closest, the bass and lead channel play properly, but the 9-bit poly is not done on the $8x channel, so white noise is heard. On A7800, noise is heard on the bass channel, except for the F1 note, and the $8x channel notes are played very noticeably out of tune. Binaries are below (for POKEY @$450 and @$4000), in addition a .wav file recorded from Altirra, which of course does the music flawlessly. Tests on real hardware, as always, are appreciated. Next steps: Doing some revisions to the POKEY note table, to add in the new reverse 16 and SKCTLS settings. These will be added on seperate pages. smokewater-450.A78 smokewater-450.asm smokewater-450.bin smokewater-4000.A78 smokewater-4000.asm smokewater-4000.bin smokewater.wav Edited March 17, 2020 by Synthpopalooza 3 1 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted March 17, 2020 Share Posted March 17, 2020 Nice job Bobby ? Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 17, 2020 Author Share Posted March 17, 2020 My next project here is documenting the $4x reverse 16-bit setting. This produces warbling distorted guitar sounds. In this case, the second frequency acts as a low frequency oscillator (LFO) on the first channel to make the vibrato effects. Quote Link to comment Share on other sites More sharing options...
+Trebor Posted March 18, 2020 Share Posted March 18, 2020 22 hours ago, Synthpopalooza said: Tests on real hardware, as always, are appreciated. Deep Purple - Smoke On The Water.mp3 ? 2 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 18, 2020 Author Share Posted March 18, 2020 Thanks ... sounds great!!! I will add ... the bass tunings in this mode are more reliable than in the $Cx modes. So this might be a good alternative for those who don't want to sacrifice a channel to 16-bit modes. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 20, 2020 Author Share Posted March 20, 2020 Update: 1/4 of the way through documenting $4x 1.79 mhz Reverse 16. It's very complex ... once finished, I will need some help comparing the timings, so we get the best fine-tune scale we have. I am having to step through the 65,536 note settings one at a time. ? Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 21, 2020 Author Share Posted March 21, 2020 Halfway done: Here's how I spent my virus quarantine. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 22, 2020 Author Share Posted March 22, 2020 (edited) Documented another setting ... at least partially. AUDCTL=$40 (1.79 mhz on 0) SKCTLS=$8B (two tone mode) Channel 0 :$4x distortion, modulation of frequency for 1 Channel 1: Silent, frequency carrier for 0 This is a lot to go into here, but I made an extensive post here: We are dealing with which I call "$Cx distortion squared" ... three different cases, each one with two note tables. I haven't documented the third case yet, but I do have note tables, so the next step is demo tunes. In short, you get the same notes as in $Cx (both rough bass, and smooth mod 3 bass), but with additional modulation from the first channel ... which can be done in a mod 5, mod 3, or non mod fashion. Attaching a frequency table here. Also: AUDF1=11 and AUDF2=14 generates silence for note rests AUDCTL=$40 SKCTL=$8B AUDC1=$4x AUDC2=$00.txt Edited March 22, 2020 by Synthpopalooza Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 24, 2020 Author Share Posted March 24, 2020 Demo song almost done ... New discoveries... some notes in the $4x SKCTLS mode have very good distorted guitar timbres! Very close to a note table on this ... Those who play Donkey Kong Country will know the tune ... 3 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 26, 2020 Author Share Posted March 26, 2020 OK, demo complete. This is a rendition of the Stickerbrush Symphony from Donkey Kong Country 2 Settings used: AUDCTL=$60 (1.79 mhz clock on 0 and 1) SKCTLS=$8B (Two tone modulation on 0 and 1) 0 - $4x (1.79 mhz, modulation) 1 - Silent (frequency carrier for 0) 2 - $Ax (standard square wave) 3 - $Cx (1.79 mhz, sawtooth wave, high lead) So, a host of explanations are in order ... When you set two-tone modulation on 0 and 1, with 0 as the $4x distortion, it creates a similar note table as $Cx ... you get a number of frequency tables, a couple of them are based on a mod 3 table, and a non mod 3 table, like in standard $Cx basses. When using mod3, you choose frequencies where (freq+4) mod 3 = 0. This makes for smooth bass tones. If you choose (freq+4) mod3 <>0 and <>5, rough bass tones are had. This is exactly like $Cx, but with different note tables. These are played on channel 1, the frequency carrier, which is always silenced. Now in channel 0, we do modulations. For mod 3 bass tones, we always do our modulations based on (mod+4) mod 5 = 0. This takes the frequency, and adds a bitwise modulation to it. Certain settings will morph the tone into a vibrato electric guitar. On settings where (mod+4) mod 5 =0 and (Mod+4) mod 3=0, you get the standard frequencies, but the higher you go in these, the fuzzier they sound ... which can be a desirable effect, like putting them through a fuzzbox that adds a slight distortion to the tones. The tune starts out with an electric guitar in the bass hit, then when the sequenced bass kicks in, it cycles through various modulations on the same note. I am attaching a rough note table, it is by no means complete, but is a very good beginning! Emulation notes: Prosystem and A7800, as expected, cannot do the two tone modulation correctly. In addition, Prosystem will play the $Cx channel correctly, but A7800 drops notes in that channel. Recording attached from Altirra emulator, which does this as it should sound on real hardware. Again, a test on real hardware will tell the true tale. dkc-stickerbrush.A78 dkc-stickerbrush.asm dkc-stickerbrush.bin dkc-stickerbrush-450.A78 dkc-stickerbrush-450.asm dkc-stickerbrush-450.bin dkc-stickerbrush.wav 5 Quote Link to comment Share on other sites More sharing options...
