eor acumulator
Hi,
I'm getting the following error:
Quote
Illegal Addressing mode
here is the code i'm using:
GetRandomByte
	asl
	eor
	asl
	eor
	asl
	asl
	eor
	asl
	rol										; performs a series of shifts and bit operations
	rts
the error is specifically with eor which I am trying to eor the value of the accumulator with the value itself. Is there any way to do it or must i use a RAM location?
40 minutes ago, Mallard Games said:
Hi,
GetRandomByte
	asl
	eor
	asl
	eor
	asl
	asl
	eor
	asl
	rts
"eor" requires a value to use.  "eor #1", "eor variable", "eor (address),y" etc.
If you want to eor the accumulator with itself, the answer is of course zero so that's clearly not what you want.
4 minutes ago, Mallard Games said:
What do you mean by "zero"?
    eor #$00
Any value "exclusive-or"'d with itself... results in zero.
so when you write just "eor" I'm wondering what you're trying to do, and pointing out you need a value. If your intention was to "eor" the accumulator with itself, then you would end up with zero anyway, so clearly that's not what you're trying to do.
Portablize this modified bit of code:
;; Subroutine to generate a Linear-Feedback Shift Register random number
;; Generate a LFSR random number
GetRandomByte
    lda Random
    asl
    eor Random
    asl
    eor Random
    asl
    asl
    eor Random
    asl
    rol Random               ; performs a series of shifts and bit operations
    rts
So it works with any game out of the box, without requiring an extra RAM variable.
Edited by Mallard Games
That code is easily usable in any 6502 program/game but it will always require a single RAM variable.  The RAM variable is part of the "feedback".  A linear-feedback shift register works by using the LAST random number to generate the next one.
https://en.wikipedia.org/wiki/Linear-feedback_shift_register
If you don't want the "extra" ram variable, you'll have to find another way to generate a random number.
Also, here's a 6502 instruction/opcode reference guide:
http://www.6502.org/tutorials/6502opcodes.html
...via frame counter, delay between input, etc.  Seeding with INTIM on cold start is probably the only way to arrive at something truly random, tho.
Almost all games have some Ram which can be reclaimed (or that is unused) in order to store it.
BTW nothing works "out of the box".  Even your own subroutine implies enough Romspace and cycle time to execute (provided that the game even uses a stack).
