MemberAtarian Posted July 22, 2019 Share Posted July 22, 2019 (edited) My new game is under development. This took 3 days and a lot of stroke to create. The game will contain 4 mini-games with one specific scene of to series. As you can see, it has the song Sound of Silence and a wave sample of comrade Dyatlov. 2019.08.31. Added first game and you can try it! You have to decrase the nuclear fire by releasing graphite on it! If you fly to close or touch the ground, you die! After 500 points, you get an extra life. Abyss0.19NTSC.bas.bin 2019.11.04. The third game called "Suicide Squad" is near to be completed. It was quite a hard task, I thought I would give up. The first scene is always about the three plungers. Unfortunately, you can't control them at the same time, they represent the three life you have at the beginning. There is a little pause as the computer generates the next stage. The stage is pitch dark in the beginnin, you have your flashlight to light up parts of the screen. In the water, the whole area will light up as you turn on your flashlight. Your objective is to find the gear and sink the water so as the hot lava comes down the reactor it won't cause an explosion. At the same time, there is a nuclear particle that goes by in the water and even if your light is turned off, the geiger tells you where it is. If it is too close, the screen will flash in RED. TODO: -Using the gear and end the stage with opening the door. You have to reach the end door on the right before the water goes so down you cannot go up there, because in this game, you cannot jump. -As the nuclear particle gets too close, it melts you and you die. 2019.11.20.: The second game seems to be somewhat completed. Rotating the gears can be done by pressing up. If it is done, the water will go down slowly, thus will make the space you can move in shrink. You have to reach the door and leave to the next room. You can die in two ways: Touching the particle or wait for the counter to go deplete, so the lava will touch the water and explode. Abyss0.44NTSC.bas.bin 2020.01.06. New minigame of Chorniy Voron (Black Raven) added. You have to shooting dogs in a scrolling lowres town, while every touch of them or killing them incrases your madness level, draining you health and slowly killing you. As you go deeper, and you suffer, the background changes and the music gets more and more out of tune. To restore it, you have to kill the raven. After that, the game gets more difficult. Abyss0.52NTSC.bas.bin 2020.01.12.: Added the game 90 seconds. You have to throw the graphite down from the floor. You can only use every soldier once in every stage. After 1000 points, you get an extra life. But beware, you can get stack and then, you will have to wait for inevitable death. Abyss0.58NTSC.bas.bin 2020.02.20.: You can handle and blow up the reactor, use boron to kill fire, go underwater and turn the gears, kill the animals in the surroundings and get rid of the graphite on the roof, all in one game. Gonna do the manual soon. Abyss0.79NTSC.bas.bin 2020.03.31.: Final ROM (hope so!) and real hw recording: Abyss0.81PAL.bas.bin Abyss0.81NTSC.bas.bin Edited March 21, 2020 by MemberAtarian 7 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted July 22, 2019 Author Share Posted July 22, 2019 I made another song for title, please vote about which one should I use! https://www.facebook.com/groups/Atari2600homebrew/permalink/698322200588949/ 3 Quote Link to comment Share on other sites More sharing options...
easmith Posted July 25, 2019 Share Posted July 25, 2019 Second song . Also , where are final versions of your games? Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted July 25, 2019 Author Share Posted July 25, 2019 (edited) 8 hours ago, easmith said: Second song . Also , where are final versions of your games? This one is definately in the early stage. Unfortunately, there is no physical release yet, only ROMS. They can be found in their own topics in the homebrew discussion. Releases for AtariAge: Plague Releases for Retronics: Apollyon, BeeWare, Fear of the Dark, Choplifter!, Dystopia, Death Match, Silver Bride (music cartridge) Edited July 25, 2019 by MemberAtarian 1 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted August 21, 2019 Author Share Posted August 21, 2019 (edited) I have worked nearly two days creating that damn scoretable on the bottom, its horrible to do the timing on the VCS. Anyway, as you can see, the chopter is a flickered P0, I tried to make the movement physics as realistic as it could be. You will swing a rope with a create of boron, so you can drop it on the burning reactor. Edited August 21, 2019 by MemberAtarian YT link did not work 2 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted August 21, 2019 Author Share Posted August 21, 2019 Another little improvement. I added the rope and the cargo, it's movement depends on how you drive, and sometimes a little drop of boron falls. In the game, one some levels (Hellsgate, Suicide Squad, 90 Seconds) you will listen to drone permanently to give a disturbing atmosphere, of course you will be able to turn it off with the left difficulty switch. There will be a sound effect telling you how close you high the radiation level is, I will add it later. Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted August 31, 2019 Author Share Posted August 31, 2019 Yeah. I done stage game 2 before game 1! You have to decrase the nuclear fire by releasing graphite on it! If you fly to close or touch the ground, you die! After 500 points, you get an extra life. Abyss0.19NTSC.bas.bin Quote Link to comment Share on other sites More sharing options...
+TrekMD Posted August 31, 2019 Share Posted August 31, 2019 Just downloaded this to give it a try. Thanks! Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted September 8, 2019 Author Share Posted September 8, 2019 I wrote a new minikernel that will be used in Chernobyl's "Suicide Mission" game, also in my PyTari compiler. You can create a 16x8 pixels icon that can be changed on fly and have a 31 pixels long indicator bar. I made this a flashlight bar, it depletes battery, but restores itself if not used. Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted September 11, 2019 Share Posted September 11, 2019 (edited) We'll be featuring Abyss of Chernobyl LIVE on tomorrow's (Wednesday) ZeroPage Homebrew stream on Twitch at 11AM PT | 2PM ET | 6PM GMT! Hope everyone can watch! Twitch Stream: https://www.twitch.tv/zeropagehomebrew/ Games: - Deimos Lander (2017 WIP) by jbanes - Abyss of Chernobyl (2019 WIP) by Fehér János Zoltán aka MemberAtarian - Beast (2019 WIP) by Dylldophlo - Boulder Dash (2012) by Andrew Davie & Thomas Jentzsch EDIT: Archive Video of Stream (SET VIDEO TO 1080P60 FOR FULL QUALITY) Edited September 12, 2019 by ZeroPage Homebrew Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted November 4, 2019 Author Share Posted November 4, 2019 This is the third game of Abyss of Chernobyl. It was quite a hard task, I thought I would give up. The first scene is always about the three plungers. Unfortunately, you can't control them at the same time, they represent the three life you have at the beginning. There is a little pause as the computer generates the next stage. The stage is pitch dark in the beginnin, you have your flashlight to light up parts of the screen. In the water, the whole area will light up as you turn on your flashlight. Your objective is to find the gear and sink the water so as the hot lava comes down the reactor it won't cause an explosion. At the same time, there is a nuclear particle that goes by in the water and even if your light is turned off, the geiger tells you where it is. If it is too close, the screen will flash in RED. TODO: -Using the gear and end the stage with opening the door. You have to reach the end door on the right before the water goes so down you cannot go up there, because in this game, you cannot jump. -As the nuclear particle gets too close, it melts you and you die. Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted November 18, 2019 Author Share Posted November 18, 2019 The second game seems to be somewhat completed. Rotating the gears can be done by pressing up. If it is done, the water will go down slowly, thus will make the space you can move in shrink. You have to reach the door and leave to the next room. You can die in two ways: Touching the particle or wait for the counter to go deplete, so the lava will touch the water and explode. Abyss0.44NTSC.bas.bin Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted December 13, 2019 Author Share Posted December 13, 2019 If your favorite hardware can't do scrolling, do it on your own. Complately done in ASM. Unfortunately, I won't be able to use this after I will work with my own engine because it will store the playfield in ROM, instead of RAM, but since this one will be finished in bB, I tried to do something new. But I learnt something important, how to use 2bit variables and have a great idea how I will use nibbles with really a few CPU cycles. Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted December 14, 2019 Author Share Posted December 14, 2019 Added the boy walking and scrolling the screen. 1 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted December 26, 2019 Author Share Posted December 26, 2019 Added some elements to the Black Raven minigame in Abyss of Chernobyl. You can shoot while ducking, while standing and you can shoot straight up. I added the dogs as well. If they touch you, the madness level raises slowly and if you kill them, it will rise as well, but add some points. As madness rises, colors and music will be dissorted more and more, so if you don't kill the Raven, the main character of the folk song and reset the madness meter, you die. Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 6, 2020 Author Share Posted January 6, 2020 2020.01.06. New minigame of Chorniy Voron (Black Raven) added. You have to shooting dogs in a scrolling lowres town, while every touch of them or killing them incrases your madness level, draining you health and slowly killing you. As you go deeper, and you suffer, the background changes and the music gets more and more out of tune. To restore it, you have to kill the raven. After that, the game gets more difficult. Abyss0.52NTSC.bas.bin Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 7, 2020 Author Share Posted January 7, 2020 Quote Link to comment Share on other sites More sharing options...
mhodgeshvs Posted January 10, 2020 Share Posted January 10, 2020 Which is the first game? I seem to have missed it; 2 is Hellgate, 3 is Suicide squad and 4 is Black Raven, but which is #1, and is there a rom too?? Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 11, 2020 Author Share Posted January 11, 2020 On 1/10/2020 at 3:21 PM, mhodgeshvs said: Which is the first game? I seem to have missed it; 2 is Hellgate, 3 is Suicide squad and 4 is Black Raven, but which is #1, and is there a rom too?? I will do the first for the last. It will about blowing up the reactor. 1 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 11, 2020 Author Share Posted January 11, 2020 Fifth minigame is under constuction. You have to clean the roof and throw down the graphite. After 90 seconds, the soldier dies, but you can switch them. You lose if all the soldier dies or you don't have enough of them to clean the roof. Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 12, 2020 Author Share Posted January 12, 2020 -Added indicator to show how many soldiers are left for the current level. -Added death and extra life. -Counter changes under 11 seconds. -Bug to feature: You can get stack, just like in the episode. Abyss0.58NTSC.bas.bin 1 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 24, 2020 Author Share Posted January 24, 2020 First look at the reactior level. And no, you won't have to use any controllers, just the switches on the console. 1 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 29, 2020 Author Share Posted January 29, 2020 What you can do right now: -Turn the reactor of and reach the bottom of performance (30 MW) or make it reach the top of performance, depending on the number of rods -Turn on stabilizer of water flow speed or let it reach top speed. -Make rods go up or down. TODO: Add temperature change and add bubbles to hot water. 1 Quote Link to comment Share on other sites More sharing options...
+cjherr Posted January 29, 2020 Share Posted January 29, 2020 Very cool. Quote Link to comment Share on other sites More sharing options...
mhodgeshvs Posted February 12, 2020 Share Posted February 12, 2020 On 1/11/2020 at 9:59 PM, MemberAtarian said: I will do the first for the last. It will about blowing up the reactor. Quote Link to comment Share on other sites More sharing options...
