Mallard Games Posted July 22, 2019 Share Posted July 22, 2019 (edited) I am using this bit of code to decide if the velocity is going to be positive or negative when a new game is started. GetRandomByte lda Random asl eor Random asl eor Random asl asl eor Random asl rol Random ; performs a series of shifts and bit operations rts jsr GetRandomByte ; generate a random number lda #%10000000 ; 1 in most significant bit mean greater then 127 bit Random ; was it less then 127? bne RandomVX ; if it was then branch lda #$ff ; set the starting duck's x velocity to -1 jmp RandomVXDone ; and jump cause we're done RandomVX lda #$01 ; set the starting duck's x velocity to 1 RandomVXDone sta DuckVX ; store duck's initial x velocity jsr GetRandomByte ; generate a random number lda #%10000000 ; 1 in most significant bit mean greater then 127 bit Random ; was it less then 127? bne RandomVY ; if it was then branch lda #$ff ; set the starting duck's x velocity to -1 jmp RandomVYDone ; and jump cause we're done RandomVY lda #$01 ; set the starting duck's x velocity to 1 RandomVYDone sta DuckVY ; store duck's initial y velocity However no matter what the velocity always stays the same. Bin: https://www.dropbox.com/s/ikjnebg1moyn0k4/duckgame.bin?dl=1 Edited July 22, 2019 by Mallard Games Quote Link to comment https://forums.atariage.com/topic/293694-velocity-isnt-randomized/ Share on other sites More sharing options...
alex_79 Posted July 22, 2019 Share Posted July 22, 2019 I'm not an expert, but that GetRandomByte routine looks weird. The only effect that it has on the "Random" address is to perform a "rotate left" instruction ("rol Random"). Looks like the pseudo-random value here is the accumulator, and you're overwriting it right after you call the subroutine (with "lda #%10000000"). Moreover, bit Random will set the N and V flags to match bit 7 and 6 of the value in the address tested ("Random" in this case) so you can use bmi/bpl and bvs/bvc to branch depending on the value of those two bits (the value in the accumulator doesn't matter) So instead of lda #%10000000 bit Random bne RandomVX you can do bit Random bmi RandomVX ;branch if negative (most significant bit = 1) Quote Link to comment https://forums.atariage.com/topic/293694-velocity-isnt-randomized/#findComment-4314875 Share on other sites More sharing options...
Just Jeff Posted July 23, 2019 Share Posted July 23, 2019 Did you seed Random with a value? If not, it looks like its going to be zero every time. If you step through on the debugger, do you see new values on each frame? Quote Link to comment https://forums.atariage.com/topic/293694-velocity-isnt-randomized/#findComment-4315058 Share on other sites More sharing options...
bogax Posted July 23, 2019 Share Posted July 23, 2019 (edited) You're using a Fibonacci LFSR Here's the Galois LFSR from Batari BASIC randomize lda rand lsr bcc noeor eor #$B4 noeor sta rand rts Edited July 23, 2019 by bogax Quote Link to comment https://forums.atariage.com/topic/293694-velocity-isnt-randomized/#findComment-4315080 Share on other sites More sharing options...
NoLand Posted July 23, 2019 Share Posted July 23, 2019 (edited) Are you advancing the linear shift register on any random input? A linear shift register will produce the same series of values over and over again (which is, why it can be used in the TIA for storing/latching positional values). Another way to understand it is by looking at it as a way of hashing a series of sequentially incremented input values to another value space. (The series produced by the LFSR until it returns to its first value on encountering its "stop code" may be shorter than the 256 values of a byte.*) So, while we get some scrambling out of this, it's still deterministic and not random. We still need to introduce some source of random on our own, otherwise the LFSR will produce the same series of "random" numbers over and over again, starting from the initial reset value – and the gameplay will be always the same. However, we can't alter the sequence, but, what we may do, is skipping some values. E.g., we may run the LSFR for an extra step every frame a button is pressed or on any other input, by this using the user as a source of random. It may be preferable to do so even before the actual game is started, so that the game already starts in a "more random" state. Edit: *) This is also why having an overly complicated LFSR code isn't always preferable, as applying multiple shift and XOR operations may actually shorten the series (period) produced and we may end up with less random, as the series repeats after just 40 values or so. There's nothing wrong with keeping it simple, like in the Batari BASIC example above. Edited July 23, 2019 by NoLand Quote Link to comment https://forums.atariage.com/topic/293694-velocity-isnt-randomized/#findComment-4315113 Share on other sites More sharing options...
Sknarp Posted July 23, 2019 Share Posted July 23, 2019 (edited) Yeah I can see a couple of things, when you use lda you're undoing the prior randomization stored in the accumulator . Also, the jsr's all loop to one another. Even if your randomization works the program flow could theoretically end up looping forever. It would be better to have a routine with a predictable execution time, like any of the examples already posted. Edited July 23, 2019 by Sknarp edited for clarity Quote Link to comment https://forums.atariage.com/topic/293694-velocity-isnt-randomized/#findComment-4315153 Share on other sites More sharing options...
