Mallard Games Posted July 27, 2019 Share Posted July 27, 2019 Hi, I am working on getting the score to display, but am having an issue.? I just added the following code to my main loop: GameLoop jsr VerticalSync ; perform vertical sync jsr CheckJoystick ; check for joystick input jsr ClampObjects ; move and clamp objects jsr PositionObjects ; position the objects jsr GetDigitPointers ; New jsr DrawDigits ; New ; ******************************** ; Experimental (Is this correct?) ; ******************************** jmp Jump_Display_Bank Return_Display_Bank jsr OverScan ; (3 13) jump to OverScan Routine jmp GameLoop However when i test the game the score isn't being displayed at all. ? Here is the code for those 2 functions: GetDigitPointers ldx #0 ; leftmost bitmap ldy #2 ; start from most-sigificant BCD value .DigitPointerLoop lda Score,y ; get BCD value of players score and #$f0 ; isolate high nibble (* 16) lsr ; shift right 1 bit (* 8) sta Digit0,x ; store pointer lo byte lda #>DigitsFont sta Digit0+1,x ; store pointer hi byte inx inx ; next bitmap pointer lda Score,y ; get BCD value (again) and #$f ; isolate low nibble asl asl asl ; * 8 sta Digit0,x ; store pointer lo byte lda #>DigitsFont sta Digit0+1,x ; store pointer hi byte inx inx ; next bitmap pointer dey ; next BCD value bpl .DigitPointerLoop ; repeat until < 0 rts ; Display the resulting 48x8 bitmap ; using the Digit0-5 pointers. DrawDigits lda #%00000011 sta NUSIZ0 ; player0 three copies - close sta NUSIZ1 ; player1 three copies - close sta WSYNC ; wait for sync lda #7 sta DrawDigitsLoopCounter .DrawDigitsLoop ; Cycles Pixel GRP0 GRP0A GRP1 GRP1A ; -------------------------------------------------------------------- ldy DrawDigitsLoopCounter ; +3 64 192 lda (Digit0),y ; +5 69 207 sta GRP0 ; +3 72 216 D1 -- -- -- sta WSYNC ; +3 75 225 ; -------------------------------------------------------------------- lda (Digit0+2),y ; +5 5 15 sta GRP1 ; +3 8 24 D1 D1 D2 -- lda (Digit0+4),y ; +5 13 39 sta GRP0 ; +3 16 48 D3 D1 D2 D2 lda (Digit0+6),y ; +5 21 63 sta Temp ; +3 24 72 lda (Digit0+8),y ; +5 29 87 tax ; +2 31 93 lda (Digit0+10),y ; +5 36 108 tay ; +2 38 114 lda Temp ; +3 41 123 ! sta GRP1 ; +3 44 132 D3 D3 D4 D2! stx GRP0 ; +3 47 141 D5 D3! D4 D4 sty GRP1 ; +3 50 150 D5 D5 D6 D4! sta GRP0 ; +3 53 159 D4* D5! D6 D6 dec DrawDigitsLoopCounter ; +5 58 174 ! bpl .DrawDigitsLoop ; +3 61 183 ; -------------------------------------------------------------------- ; At the *, the value written to GRP0 does not matter. What does matter is ; that this write triggers GRP1A to receive new contents from GRP1. A "!" ; indicates that that register is being used for displaying at that moment. lda #0 ; clear the sprite registers sta GRP0 ; clear player0 sprite sta GRP1 ; clear player1 sprite sta GRP0 sta GRP1 lda #%00000000 sta NUSIZ0 ; player0 one copy sta NUSIZ1 ; player1 one copy rts Source: https://www.dropbox.com/s/3fgdex1wvhj183z/source.asm?dl=1 Binary: https://www.dropbox.com/s/vyakffargbdi8ap/duckgame.bin?dl=1 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 27, 2019 Share Posted July 27, 2019 Score is being drawn during vertical retrace...so it does not appear at all. You need to do your Vblank loop (currently at the start of the second bank) BEFORE you draw the score. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 27, 2019 Share Posted July 27, 2019 BTW the GFX for the score sprites also need to reside in the same bank that is drawing the score. Otherwise, you are printing the garble that exists at the same Rom locations in the alternate bank. Quote Link to comment Share on other sites More sharing options...
