coreyr Posted July 31, 2019 Share Posted July 31, 2019 Hi, Sum up I need guidance on how to hook up a VGA converter to a JAMMA board (I will be using an LCD and not CRT). I have looked around but most the information I found is showing the device in action and not the setup part (maybe i'm not looking hard enough). The cables I had with the VGA converter is a 8pin (RED, GREEN, BLUE, GREY, YELLOW AND BLACK) & a 2pin ( RED & BLACK). I'm starting with a fresh CAB and not an existing CAB (If that is relevant) Thank you! Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted August 1, 2019 Share Posted August 1, 2019 This should help with the wire functions. Quote Link to comment Share on other sites More sharing options...
