Efficient BCD to Binary routine?
Karl G
After much searching, I wasn't able to find an 8-bit BCD to binary routine that was both cycle-efficient and cycle-consistent. I made my own, posted below. I was wondering if others have a routine that is leaner than this one?  It uses A, X, and one byte of temporary RAM.
; BCD value $0 - $99 is in A. Returns binary number 0-99 in A
BCDtoBin
    sta Temp
    and #$0F
    tax
    lda Temp
    and #$F0
    lsr
    lsr
    lsr
    sta Temp
    asl
    asl
    clc
    adc Temp
    sta Temp
    txa
    clc
    adc Temp
    rts
Neat!
There might be a few different routines out there but I don't know of any.
You could also do this to compress your routine further:
BCDtoBin2:
    sta Temp
    and #$0F
    tax
    eor Temp
    lsr
    sta Temp
    lsr
    lsr
    adc Temp
    stx Temp
    adc Temp
    rts
I had a thought, and made a new routine. It is 2 cycles faster, and 2 bytes less than the previous.
    tax
    and #$F0
    lsr
    lsr
    sta Temp
    lsr
    adc Temp
    sta Temp
    txa
    sec
    sbc Temp
    rts
In one byte BCD number the high nibble is a base 10 value stored as a base 16. To convert subtract a value of 6 * (high nibble >> 4) from the original value.
I'll post a table version. It is 5 cycles faster than the last version, but uses 6 bytes more. It is only useful if you need the speed.
BCDtoBin5:
    tax
    lsr
    lsr
    lsr
    lsr
    tay
    txa
    sec
    sbc SixTable,Y
    rts
SixTable:
    .byte 6*0
    .byte 6*1
    .byte 6*2
    .byte 6*3
    .byte 6*4
    .byte 6*5
    .byte 6*6
    .byte 6*7
    .byte 6*8
    .byte 6*9
Went with 2 temps instead of a single temp and and an index register. This version saves 1 byte and 3 cycles over the BCDtoBin4 routine in post #5 above.
BCDtoBin6:
    sta Temp
    and #$F0
    lsr
    sta Temp2
    lsr
    lsr
    adc Temp
    sec
    sbc Temp2
    rts
BCDtoBin6:
    sta Temp
    and #$F0
    lsr
    sta Temp2
    lsr
    lsr
    adc Temp
    sec
    sbc Temp2
    rts
I like this, very clever.
To explain for others...
bcd format $XY = effectively 16X + Y (where X and Y are the decimal digits of the number)
we want decimal format XY = effectively 10X + Y
So we need to subtract 6X from the original number and we'll have our answer
The code first isolates X (and #$F0) and then divides by 2, giving us 8X stored in Temp2
Then divides by 4, giving 2X, adds it to the original number so that's now (16+2)X + Y
And finally subtracts 8X (in Temp2), giving (16+2-8)X + Y
--> 10X + Y
Lovely.
  • 3 weeks later...
I think the last solution might be optimal. I would love to see some other ideas though.
One thing I should mention is that I don't trust ASR anymore. I had problems with it before on an Jr. Otherwise it would be a quick way to save 2 cycles and 1 byte to just ASR #$F0. It is actually would be a very useful opcode if it was stable.
Others have also noted the same problems that I had with ASR.
