Ice Cream Jonsey Posted August 19, 2019 Share Posted August 19, 2019 I have an Atari 520ST. I also have a Satandisk that I bought a long time ago. The card that the Satandisk has is the one that came with it, a 2GB one with three partitions. I have never been able to get it to work. I was wondering if anyone knew if I was obviously doing something wrong. I am new to the ST but not old systems in general. I have a 9 volt power supply going to the Satandisk, what I have read is that that's in the range where it should be ok. I have it connected to the HD port of the ST. When I give power to the Satandisk a green LED flashes briefly and then a red LED goes on and stays on. It stays on throughout all that follows. When I turn the ST on it boots, but I don't see anything on my screen that indicates that the Satandisk is being accessed and then I get the green desktop. What I think should be happening based on some videos I have looked at is that some text should appear on the monitor indicating that the Satandisk is active and there should be some folders on the ST's desktop that I could click into. I have never seen that. I can attach a video of the boot process in case I am doing something wrong. (I have read that sometimes you need to hold the Alternate button down when doing a warm boot, I've tried that as well to no avail.) Any advice on what I could do next? Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted August 19, 2019 Share Posted August 19, 2019 Red LED should be on for short - about 1 sec, then off. First thing what you should to try is other power supply. With little higher voltage. And question is, is current one can provide enough voltage under load ? Other problem may be SD card, or even Satandisk self. Holding Alt. key during boot is for prevent driver autoboot. Boot process normally does not need any special action. And this thread belongs in general Atari ST section, not programming one. Quote Link to comment Share on other sites More sharing options...
Ice Cream Jonsey Posted August 19, 2019 Author Share Posted August 19, 2019 Thanks! Do you recall what the red and green LEDs are meant to indicate? Quote Link to comment Share on other sites More sharing options...
Ice Cream Jonsey Posted October 17, 2020 Author Share Posted October 17, 2020 Does anyone know what the red and green lights are supposed to indicate for the Satandisk? Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted October 18, 2020 Share Posted October 18, 2020 Green means that it gets power. Red is on when card is accessed. Normal operation is like: After power on green must work immediately, and after 1-2 secs red is on for short (under 1 sec if I remember correct) . It's because adapter firmware reads SD card parameters. And red will be on when computer performs 'hard disk' access - SD card, of course - in most cases will see it blinking for shorter/longer time. Quote Link to comment Share on other sites More sharing options...
Ice Cream Jonsey Posted October 18, 2020 Author Share Posted October 18, 2020 9 hours ago, ParanoidLittleMan said: Green means that it gets power. Red is on when card is accessed. Normal operation is like: After power on green must work immediately, and after 1-2 secs red is on for short (under 1 sec if I remember correct) . It's because adapter firmware reads SD card parameters. And red will be on when computer performs 'hard disk' access - SD card, of course - in most cases will see it blinking for shorter/longer time. Cool - thank you very much. Quote Link to comment Share on other sites More sharing options...
