emkay Posted October 1, 2019 Share Posted October 1, 2019 On 9/29/2019 at 12:19 AM, 777ismyname said: Nothing wrong with this tune, but “most advanced” is highly subjective. Yeah, thanks for supporting my position The Tunes isn't "most advanced" . It's a very lonely place there. There is a big space and then comes " how do you name your favorite tune" . On 9/30/2019 at 6:11 PM, Synthpopalooza said: Very good. If someone makes a Miami Vice game, there you go. Does this use a lot of hi pass filter? RMT Patch 8 has a real tuned row of different settings of the Sound Generators. Low and high notes fit well together . Also all channels were nicely tuned together. Main Clocking 15kHz, for Bass and Drums. 1.79MHz for the high FX. 16 Bit 2 Tone for one of the main Instruments. And a correct tuned gen 2 setting. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted October 1, 2019 Author Share Posted October 1, 2019 9 minutes ago, emkay said: RMT Patch 8 has a real tuned row of different settings of the Sound Generators. Low and high notes fit well together . Also all channels were nicely tuned together. Main Clocking 15kHz, for Bass and Drums. 1.79MHz for the high FX. 16 Bit 2 Tone for one of the main Instruments. And a correct tuned gen 2 setting. Wasn't aware you could do 16-bit with 2-tone. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 20, 2020 Author Share Posted March 20, 2020 Reviving this topic ... I am spending my quarantine time doing a frequency table for $4x distortion, 1.79 mhz, and reverse 16-bit mode (0 plays, 1 is silent). about 25% done. Going to need some help tuning it tho. This one produces warbling electric guitars, and the frequency value in the 2nd channel increases the vibrato. This is going to be cool when it's ready. 3 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 21, 2020 Author Share Posted March 21, 2020 Halfway done. I have half of the 65,536 settings documented for the $4x Reverse 16 setting. I have a rudimentary table ... note, these are not grouped by octave number, that will come later, but you can get from about c1 up to about c3 so far. Here's how it works: Put $50 in AUDCTL, silence the second channel, set first channel to $4x. Turns on 16-bit and sets first channel to1.79 mhz. There is some sort of averaging which goes on between the bit counters in the first two channels due to $4x bit counting, which creates the warbling guitar effects in the first channel. The tunings in some of these may be off ... I did them by ear. Also, the table is half done. I still need to get the settings where AUDF1 (2nd channel) > 128. Next, I will do up a frequency table, and sort these out by tuning, until finally we get a note table. Emkay: It'll be on you then ... hack this baby into RMT. Also, anyone who wants to dig into this, and make a tuned table out of what I got ... feel free! This is going to make some wicked guitars ... I am also going to experiment with the other clocks (64 khz, 15 khz) and see what happens as well. So far tho I think 1.79 mhz is the best bet. Then ... modulating this stuff with a hi pass filter on channel 3. AUDCTL=$50, AUDC0=$4x.txt 3 Quote Link to comment Share on other sites More sharing options...
rdefabri Posted March 22, 2020 Share Posted March 22, 2020 Good stuff! Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 22, 2020 Author Share Posted March 22, 2020 (edited) More developments! This time, we are dealing with Channel 0 using $4x distortion, AUDCTL=$40, and two tone mode engaged! I have managed to decode frequency tables for two out of three possible settings. This is huge ... So some explanations are in order ... those of you who know how to us the $Cx distortion will remember, that you have three frequency cases to deal with: (freq+1) mod 3 = 0 and (freq+1) mod 5 <> 0 ... smooth bass tones, aka RMT bass C (freq+1) mod 5 = 0 ... either silence, or an intermittent smooth bass tone (freq+1) mod 3 <>0 and (freq+1) mod 5 <> 0 ... rough bass tones, aka RMT bass E The same thing happens with this setting, but multiplied... and we have three possible cases here. For purposes of this post and the attached document, the following terminology is used: AUDC1 and AUDC2: Distortion settings of channel 0 and 1 AUDF1 and AUDF2: Frequency settings of channel 0 and 1 Set AUDC1=$4x, AUDC2=$00, AUDCTL=$40 (turns on 1.79 mhz for 0) and SKCTL=$8B (two tone mode) Case 1: AUDF1 where (freq+4) mod 5 = 0 This is a fairly easy setting, very similar to $Cx distortion. Two tables are here for AUDF2, one with a mod3 bass setting, and one without (with rough bass tones). By stepping AUDF1 through multiples of 5, modulations are introduced into the note played! This can be used to make a PWM or sample and hold type random timbre, or other interesting effects. The mod 3 bass behaves just like RMT C, random timbres are played depending on system timers. I have made a note table for this setting, but it differs from RMT C. For the second table, we use non mod 3 values, like RMT E. Also: Where AUDF1 has (freq+4) mod 15=0, those settings are exactly identical, and may be considered to be your base setting in this case. Case 2: AUDF1= (freq+4) mod3=0 and (freq+4) mod 5 <>0 This makes some interesting results. We have smooth bass tones, but they are interspersed into two tables for AUDF2, with an octave difference. By altering AUDF1 by multiples of 3, modulations are introduced into the notes played in the second channel. Case 3: AUDF1= (freq +4) mod 3<>0 and (freq+4) mod 5 <>0 Undocumented as of yet, but there are a lot of strange frequencies, some noises, and some vibrato distorted guitars, on the order of the previous $4x setting I was playing around with. I am attaching a document, and three Turbo BASIC programs: FTEST48B.TUR ... steps through all 65,536 settings, and lets you compare them to a standard $Ax square table on channel 2 F48BMOD3.TUR ... steps AUDF1 through multiples of 3 F48BMOD5.TUR ... steps AUDF1 through multiples of 5 These controls: + or - ... changes the $Ax channel through the standard values (C3 to C4) up and down arrow: changes AUDF1 left and right arrow: changes AUDF0 Now, let's get this modded for RMT. One more bit of info ... AUDF1=11 and AUDF2=14 generates silence for note rests F48BMOD3.TUR F48BMOD5.TUR FTEST48B.TUR AUDCTL=$40 SKCTL=$8B AUDC1=$4x AUDC2=$00.txt Edited March 22, 2020 by Synthpopalooza Quote Link to comment Share on other sites More sharing options...
R0ger Posted March 23, 2020 Share Posted March 23, 2020 Can you make something which is easy to run ? Like XEX or even a video or sound ? Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 23, 2020 Author Share Posted March 23, 2020 I will work up a demo tune with this soon. Meanwhile, get TurboBASIC to run the programs to test it out. 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 26, 2020 Author Share Posted March 26, 2020 OK, a demo tune ... Took a bit of experimenting, but I came up with some modulations that make some good distorted guitars ... Setup: AUDCTL=$60 (1.79 mhz on 0 and 2) SKCTL=$8B (two tone mode) 0 - $4x (2-tone modulation) 1 - silent (frequency carrier for 0) 2 - $Ax (standard square wave, no modulation) 3 - $Cx (1.79 mhz, high lead) The tune is the stickerbrush symphony from Donkey Kong Country 2. The bass starts off with an electric guitar modulation, then when the bass starts, various modulations are cycled. The note table used is the Case 1, mod 3 bass table. More experimentation is needed, but this is a very promising start! dkc-briarpatch.asm dkc-briarpatch.s dkc-briarpatch.xex 3 Quote Link to comment Share on other sites More sharing options...
emkay Posted March 26, 2020 Share Posted March 26, 2020 Not bad. In the end, it shows that we need a music tracker that allows all possible combinations that POKEY offers. To get the best possible music. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 26, 2020 Author Share Posted March 26, 2020 (edited) 17 minutes ago, emkay said: Not bad. In the end, it shows that we need a music tracker that allows all possible combinations that POKEY offers. To get the best possible music. We're a long way from that .. but ... maybe something customizable that let's you import your own note tables and AUDCTL/SKCTL settings. There is a LOT left to document. And most of it is gonna be donkey work of stepping through 65,536 settings each time. ? As an example ... the above setting, I haven't even added the hi pass filter to it yet. It will eat three channels, but might even make things more interesting. There's a lot unexplored. Edited March 26, 2020 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
R0ger Posted March 26, 2020 Share Posted March 26, 2020 Promising ! Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 27, 2020 Author Share Posted March 27, 2020 So a few tips in this mode: For Case 1 (both tables) ... AUDF1 values where (freq+4) mod 15 = 0 will produce the basic frequencies, but as the value is stepped up by 15 each time, the sound gets slightly fuzzier and distorted. It's actually a cool effect, like putting $Cx distortion through a fuzz box. For AUDF1 where (freq+4) mod 5=0 but not mod 3 ... certain modulations on each note in the table will make the distorted guitar modulations. If the AUDF2 note comes from the non mod3 table, then the modulated frequency played is a 4th interval up from the root note. So more documentation is needed. But now that I know the pattern, it's easier to decode frequency settings. 3 Quote Link to comment Share on other sites More sharing options...
+bhall408 Posted April 11, 2020 Share Posted April 11, 2020 On 9/7/2019 at 10:10 PM, Synthpopalooza said: I have started a thread over on the 7800 forums regarding experimental POKEY music using unusual settings, for purposes of improving 7800 emulation. By request, I am starting a thread here to port some of these examples to the XL platform. What is the status on the POKEY emulation code? Do you need help? We'll be working on POKEY emulation for Android in the near future (we're polishing 2600 audio at the moment, and plan to do 7800 in the future). Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted April 11, 2020 Author Share Posted April 11, 2020 (edited) For POKEY emulation ... the Altirra emulator is a good source to crib from ... http://virtualdub.org/altirra.html I use it to test all my POKEY code before it goes to a 7800 executable. On the 8-bit platform, it is simply top of the line. Edited April 11, 2020 by Synthpopalooza Quote Link to comment Share on other sites More sharing options...
+bhall408 Posted April 11, 2020 Share Posted April 11, 2020 1 hour ago, Synthpopalooza said: For POKEY emulation ... the Altirra emulator is a good source to crib from ... http://virtualdub.org/altirra.html I use it to test all my POKEY code before it goes to a 7800 executable. On the 8-bit platform, it is simply top of the line. Ah, so this was more for working on a game than working on an emulator? Altira is indeed nice, but we can't use it as it is GPL. We're looking to help with/contribute to a non-GPL implementation. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted April 11, 2020 Author Share Posted April 11, 2020 I do development on music for 7800 and 8-bit. The current emulation for 7800 is not quite POKEY accurate yet. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted April 13, 2020 Author Share Posted April 13, 2020 (edited) OK, I am 98% close on the $4x Reverse 16-bit table ... Which is: You set AUDCTL=$50, (16-bit plus 1.79 mhz) but silence the 2nd channel (AUDC1=$00) and set AUDC1=$4x This is a very complex setting, which involves 4 tables: The first three come into play when you set a 0 for the frequency in the second channel (AUDF1=$00) You have a mod 3, mod 5, and non mod 3 or 5 table, like in $Cx distortion. The mod 5 table will intermittently play a note or silence, dependent on system timers. The mod 3 table outputs random timbers, like its $Cx equivalent. The frequencies are subject to these forumlas: (AUDF+1) mod 3 =0 (AUDF+2) mod 5 =0 Where AUDF0=$08 and AUDF1=$00, silence is generated. This can be used for note rests. The 4th table is more complex. You can make distorted guitars with warbling vibratos. I haven't yet figured out a pattern to these yet, but they are laid out in the following format: (AUDF0, AUDF1, MOD). The MOD setting the maximum you can add or subtract from AUDF1 value, and it introduces a vibrato to the guitar modulation. When MOD is zero, in most cases, you get a steady tone, the timbre will vary depending on the current bitcounter sample. This gets some very warbly guitar type tones. I have attached a text file here with these settings. In the case of table 4: These have not been tuned yet, so are approximations. I will go back through these later, and tune them, and then we should have a stable note table for this setting. Then: Hack this baby into RMT. If anyone can find a pattern to these, I'd love to know ... I had to step through 65,536 settings to find all these! AUDCTL=$50, AUDC0=$4x by octave number.txt Edited April 13, 2020 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted April 14, 2020 Author Share Posted April 14, 2020 So another question: How does one go about patching RMT to work with new settings and note tables? Does the source code for RMT exist? It's a shame we don't have Raster or analmux to ask about it anymore ... Quote Link to comment Share on other sites More sharing options...
emkay Posted April 14, 2020 Share Posted April 14, 2020 RMT would be needed to be rewritten completely. The control bits have been used to the limit. What that means, only the Author could have explained that. Analmux (Bernard) found the tables and control switches and did the patches. So any new setting removed old settings. That's why patched RMT tunes don't sound really "finished" . And even worse, the Runtime would need to have the same changes, to have the replay of a tune correct. Quote Link to comment Share on other sites More sharing options...
R0ger Posted April 14, 2020 Share Posted April 14, 2020 Source codes do exist, but they are not public. And it wouldn't help you much anyway, as emkay said, all the limitations are hardwired through and through. Only solution would be new tracker. I can do the patches though, I do it often. RMT has 4 tone tables. A distortion, C distortion, E distortion and 16 bit. Each RMT distortion then has corresponding AUDCx value. If you want new tone table, you have to swap it for one of these. AUDCTL can be set bit by bit, so that's not an issue. If you need to set some other register or do some extra initialization, like pokey reset or some channel synchronization, you have to do it in your code outside RMT. Those tables are in RMT.exe on 3 places, once for the normal playback in the program, once for export into XEX, and who knows what for is the third one. I just patch them all and it works just fine. And yes, you also need to modify your ASM sources for rmtplayer in your code. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted April 14, 2020 Author Share Posted April 14, 2020 So I would then be swapping out the 16-bit table for this $4x setting, then setting the first channel to $4x and second one to $00. The other question is ... some of the frequencies in this new reverse $4x setting are set up in that if you change the frequency by a few steps on the second silent channel, a warbling vibrato effect is introduced into the sound. Does RMT have an allowance for this, like maybe a detuning effect on the silent channel? Quote Link to comment Share on other sites More sharing options...
R0ger Posted April 14, 2020 Share Posted April 14, 2020 (edited) 5 minutes ago, Synthpopalooza said: So I would then be swapping out the 16-bit table for this $4x setting, then setting the first channel to $4x and second one to $00. The other question is ... some of the frequencies in this new reverse $4x setting are set up in that if you change the frequency by a few steps on the second silent channel, a warbling vibrato effect is introduced into the sound. Does RMT have an allowance for this, like maybe a detuning effect on the silent channel? Send me the table and I can try it. I think second channel is set to 0. If it's not, ti might need further modification of the code, but should be doable. As for effect on 16bit modes, you're out of luck. RMT simply does not support them. It can't even do simple detune, though Filter does something like that. But it also forces the filter bits in AUDCTL and there is poor control over the detune amount. Edited April 14, 2020 by R0ger Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted April 14, 2020 Author Share Posted April 14, 2020 I should have it finished tonight ... in the process of tuning everything at the moment. Also ... might be a good idea to tune the AUDF1 values so that the warbling occurs, since we can't detune in the tracker. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted April 14, 2020 Author Share Posted April 14, 2020 17 minutes ago, R0ger said: Send me the table and I can try it. I think second channel is set to 0. If it's not, ti might need further modification of the code, but should be doable. As for effect on 16bit modes, you're out of luck. RMT simply does not support them. It can't even do simple detune, though Filter does something like that. But it also forces the filter bits in AUDCTL and there is poor control over the detune amount. Standard 16-bit usage silences the first channel and plays the second. In this instance, the second channel AUDC1 must be on 0 and AUDC0 set to $4x with 1.79 mhz engaged. Quote Link to comment Share on other sites More sharing options...
