The Historian Posted September 23, 2019 Share Posted September 23, 2019 (edited) An interesting article from the BBC on the maze generation of the game Entombed. It seems the researchers just don't understand how it works. Quote As I dug into this maze algorithm, it became clear that this was something that seemed to be fairly unique to this maze game – John Aycock I wonder if anyone here has looked into the code for this game? BBC Article here: http://www.bbc.com/future/story/20190919-the-maze-puzzle-hidden-within-an-early-video-game The publication from John Aycock and Tara Copplestone https://arxiv.org/ftp/arxiv/papers/1811/1811.02035.pdf Entombed - An archaeological examination of an Atari 2600 game.pdf Edited September 23, 2019 by The Historian Attchached publication. 1 Quote Link to comment Share on other sites More sharing options...
Tempest Posted September 24, 2019 Share Posted September 24, 2019 Yeah I just saw that article. Very cool. Quote Link to comment Share on other sites More sharing options...
+Psionic Posted September 25, 2019 Share Posted September 25, 2019 Also being discussed here... https://atariage.com/forums/topic/296385-atari-in-the-news-cool-bbc-article/ Quote Link to comment Share on other sites More sharing options...
Tensor Posted September 29, 2019 Share Posted September 29, 2019 Any idea where the code can be located? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 5, 2019 Share Posted October 5, 2019 lda ram_87 ;3 rnd sta ram_82 ;3 sta ram_84 ;3 ldx #$04 ;2 LB46C lsr ;2 rol ram_A0 ;5 lsr ram_82 ;5 rol ram_A0 ;5 asl ram_84 ;5 rol ram_90 ;5 asl ram_87 ;5 rol ram_90 ;5 dex ;2 bne LB46C ;2 ldx #$1F ;2 LB480 lda ram_8F,x ;4 sta ram_90,x ;4 dex ;2 bne LB480 ;2 $90-$9F = PF1 $A0-$AF = PF2 Simple, but effective. I wonder if this is the same method used in Diggerbonk? Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted October 5, 2019 Share Posted October 5, 2019 Nukey, what is the difference between using LSR and ROR, Or ASL and ROL? Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted October 5, 2019 Share Posted October 5, 2019 12 minutes ago, Cafeman said: Nukey, what is the difference between using LSR and ROR, Or ASL and ROL? I'm not Nukey, but... LSR and ASL shift a zero bit onto the "end" ROR and ROL shift the carry bit onto the "end" If you're shifting/rolling right, then the bit goes into D7. If you're shifting/rolling left, then the bit goes into D0. Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted October 5, 2019 Share Posted October 5, 2019 Ok, thanks. Do you know of an example where one is preferable to the other? Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted October 5, 2019 Share Posted October 5, 2019 3 hours ago, Andrew Davie said: I'm not Nukey, but... Hmmmm. I feel the conspiracy theories have already started Mr Davie, or should I say Andrew Shay! ??? 1 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted October 5, 2019 Share Posted October 5, 2019 1 hour ago, Cafeman said: Ok, thanks. Do you know of an example where one is preferable to the other? if you are bit-shifting for the purpose of multiplying or dividing by two, then you don't want to have carry shifted in, so you would prefer LSR and ASL. ROR and ROL can be used e.g. if you want to shift the bits from one variable to another, like for a scrolling playfield. The bit that falls off the end would go into carry, and would be shifted in for the second operation. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted October 5, 2019 Share Posted October 5, 2019 2 hours ago, Cafeman said: Ok, thanks. Do you know of an example where one is preferable to the other? double a 16-bit value uses both... asl value ; lo byte rol value+1 ; hi byte Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 5, 2019 Share Posted October 5, 2019 Without rol/ror, that would be 3x longer: lda value+1 asl asl value bcc NoCarry ora #$01 NoCarry sta value+1 Not getting how Entombed has these "archaeologists" stumped, tho. It's just using the separate nybbles of rnd for PF1 and PF2...each bit position corresponds to 2 bit positions of PF to make the passages wide enough for the player character to move though. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted October 6, 2019 Share Posted October 6, 2019 7 hours ago, Nukey Shay said: Without rol/ror, that would be 3x longer: Not quite! I think this would work... lda value+1 asl asl value adc #0 sta value+1 Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted October 6, 2019 Share Posted October 6, 2019 asl Value+1 asl Value bcc .finish inc Value+1 .finish: Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted October 6, 2019 Share Posted October 6, 2019 19 hours ago, Nukey Shay said: Not getting how Entombed has these "archaeologists" stumped, tho. It's just using the separate nybbles of rnd for PF1 and PF2...each bit position corresponds to 2 bit positions of PF to make the passages wide enough for the player character to move though. You're right. This part of the code looks straight forward. So really the magic is in the pattern of numbers from the pseudo random generator, and how that corresponds to D7 and D0. I have not looked at the rest of the code at all, but I am wondering if this random generator is only called for this routine? It would be more interesting if it wasn't. If it is not called only by this routine I would want to know if it is called every nth time, repeatedly. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted June 8, 2022 Share Posted June 8, 2022 The story continues: Still Entombed After All These Years: The continuing twists and turns of a maze game For this followup they were able to get ahold of one of the two inventors of the maze algorithm, Paul Allen Newell. Quote The logic behind how the 32-byte table mapped abcde values into X values was an open question. Why, for example, did 01101 produce 0, an empty passage, as opposed to a wall or a random selection between the two options? Aycock and Copplestone (2019, 4:11) took a conservative stance given all the available evidence, concluding that 'the table values were manually chosen, or manually tuned, by the maze algorithm designer', while others sought deeper meaning in the table (e.g., Brüning nd; colinbeveridge 2019; Mächler and Naccache 2021); it was an interesting puzzle. The table, as it turned out, was a red herring. Note the reverse engineering performed was not incorrect, but the use of the table reflected an intermediate step rather than the algorithm's true design; there would have been no way to non-speculatively infer the actual design from what remained in Entombed. However, since Newell extensively documented the algorithm when it was developed (Figure 4), we need not speculate. emphasis added. 4 Quote Link to comment Share on other sites More sharing options...
+Psionic Posted January 21 Share Posted January 21 Crazy how a mostly unknown game has suddenly attracted so much attention after all these years. Not a bad thing though, especially since the attention resulted in the programmer finally releasing a number of artifacts related to the game's development that he's had in his possession. https://www.atariprotos.com/2600/software/entombed/entombed.htm Quote Link to comment Share on other sites More sharing options...
