IntyBASIC Horizontal Text Scrolling using GRAM?
First Spear
Please help me think through this idea.
A very long text string like this "Pack my box with five dozten liquor jugs. Please understand that this is fairly long!     "
Put black blocks in all GRAM locations.
Assign write GRAM 43 to Bitmap location 220, 44 to 221, 45 to 222, 46 to 223, 47 to 224...239.
I want to scroll that string from right to left on a single line, nothing taller than 8 px high.
Put that text into a long bitmap graphic, use IntyColor to convert it to a graphic.
Read the data that makes up the first 8x8 block, write it to GRAM 43, second 8x8 to GRAM 44, third 8x8 to GRAM 45, etc. up to GRAM 62 going to Backtab #239
Loop reads second block and writes it to GRAM 43, third block to 44, etc.
In a loop that should show a scrolling effect.
Am I way off here inmy thinking?
Thanks.
include "constants.bas"
for i = 0 to 19
    #backtab(220+i) = text(i) * 8 + 7
next
i = 18
i2 = 7
start:
    scroll i2
    wait
    i2 = i2 - 1
    if i2 = 255 then
        i2 = 7
        scroll ,,2
        i = i + 1
        if i >  84 then i = 0
        #backtab(239) = text(i) * 8 + 7
    end if
goto start
text:
data "Pack my box with five dozen liquor jugs. Please understand that this is fairly long! "
Edited by skywaffle
If you are looking for a title screen and not use any scrolling, your method would work the same, just not smooth:
start:
    wait
    delay = delay + 1
    if delay > 10 then
        delay = 0
        i2 = i2 + 1
        if i2 > 84 then i2 = 0
    end if
    for i = 0 to 19
        i3 = i + i2: if i3 > 84 then i3 = i3 - 85
        #backtab(220+i) = text(i3) * 8 + 7
    next
goto start
text:
Edited by skywaffle
11 hours ago, skywaffle said:
That would work, however you could also use the scroll command to shift 8 pixels, and just update the rightmost block.   I am not sure which uses more resources, but with that, you could also incorporate smooth scrolling
Thanks Mr. Waffle. What I was thinking of was a hybrid between both of your awesome examples. I like the smooth scroll, but there is no way to only scroll the bottom row of tiles and leave the rest of the screen static, as far as I know. #learning
If you want an actual smooth-scrolling bitmap, scrolling at something less than 8px granularity, and not scroll the rest of the screen, then you'll need to recompute bitmaps shifted over by however many pixels.  I've written assembly code to do that in the past.
You probably can't get a full 20 tiles across, but you could probably manage 16.
