+Larry Posted October 13, 2019 Share Posted October 13, 2019 There is a note about the BXL Toolkit in the Fall 1986 Newsletter (side A) under the New BXL Bugs. https://atariwiki.org/wiki/Wiki.jsp?page=Newsletters If you have an early BXL 1.02, you need one toolkit and if you have a later 1.02 or 1.03, then you need another. (So there were at least two carts and two toolkits). You also need the stock XL/XE OS for them to work correctly as opposed to some patched OS like hi-speed, reverse Basic, etc. which will cause lockup. My original Toolkit was for an Orange 1.02. AFAIK, all orange BXL carts are 1.02. I believe that some early black ones were also 1.02, although most all are 1.03. Of course, these toolkits were for an Atari-style dos. My original manual had a typed label inserted that says "MOVE $570,C4,4" so what you patch (or not) may be determined by what version you have. My original disk (unpatched, I believe) works only with the cart 1.02. It locks up with Black 1.03. My toolkit (patched) for 1.03 works with Panos' 5-in-1. It also works with another Black BXL cart V1.03. This cart also fails with the Toolkit 1.02. 2 1 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted October 13, 2019 Share Posted October 13, 2019 Thank you all so much! When reading the 1st post, I immediately recall the newsletters for that, then I saw post #26. Thank you Larry, again(!)... Further, you are right, we have to go through all(!) OSS newsletters and insert the found news into the Wiki. I have done some stuff regarding this for MAC/65, but OSS delivered much more... So, the to-to list ist getting bigger and bigger, instead of going down to zero... OMG... @Larry: we now have the Pascal Validation Suite, so we are able to test the ISO for Kyan... Will keep you up to date. Busy for PLATO and the general assembly for ABBUC now. Quote Link to comment Share on other sites More sharing options...
robdaemon Posted October 13, 2019 Author Share Posted October 13, 2019 5 hours ago, Larry said: My original manual had a typed label inserted that says "MOVE $570,C4,4" so what you patch (or not) may be determined by what version you have. My original disk (unpatched, I believe) works only with the cart 1.02. It locks up with Black 1.03. My toolkit (patched) for 1.03 works with Panos' 5-in-1. It also works with another Black BXL cart V1.03. This cart also fails with the Toolkit 1.02. It would be awesome to add this detail (and extra toolkit!) to AtariWiki! Quote Link to comment Share on other sites More sharing options...
robdaemon Posted October 13, 2019 Author Share Posted October 13, 2019 2 hours ago, luckybuck said: So, the to-to list ist getting bigger and bigger, instead of going down to zero... OMG... I'd love to help with getting some of this over to the wiki, is there a process I can apply for edit access? ? Quote Link to comment Share on other sites More sharing options...
luckybuck Posted October 13, 2019 Share Posted October 13, 2019 Hi robdaemon! Yes, of course, I can add you as an author to the Wiki. Any help of any kind is very much appreciated. ? -> PM Quote Link to comment Share on other sites More sharing options...
luckybuck Posted March 15, 2020 Share Posted March 15, 2020 Thanks Larry, that is of great help: OSS Newsletter Fall 1986 -------------- --------- BASIC XL Bugs and Fixes ----------------------- BUG: Version 1.03 doesn't seem to work with the extensions on the ToolKit. FIX: This is true only for early versions of the ToolKit. If you have Vers. 1.03 and the ToolKit extensions work, then don't apply this fix. 100 F$="D:EXTEND.COM":N=$02d6:Gosub 130 110 F$="D:AUTORUN.SYS":N=$039f:Gosub 130 120 End 130 Unprotect F$:Open #1,12,0,F$ 140 For I=1 To N:Get #1,C:Next I 150 Put #1,9:Close #1:Protect F$ 160 Return BUG: Any program reference to line number 0 (e.g. Goto 0, If X=1 Then 0) will not be RENUMbered. This applies even if a previous RENUM created the reference (i.e. you did a RENUM 0,xx). FIX: There is no practicable solution. Simply don't use a starting line number of 0 when you NUM or RENUM. BUG: You want to make sure that you're not in FAST mode. FIX: Make the following the first line in your program: 10 IF PEEK($B9)&$80 THEN DEL 0 $B9 is BASIC XL's FAST flag, and the DEL statement turns off FAST mode. You can't have a line 0 in your program if you want to use this fix. Quote Link to comment Share on other sites More sharing options...
luckybuck Posted March 15, 2020 Share Posted March 15, 2020 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted March 18, 2020 Share Posted March 18, 2020 Thank to the gigantic help from 'kind soul', we now seem to have a solution for the problems, please see: https://atariwiki.org/wiki/Wiki.jsp?page=Basic XL#section-Basic+XL-ATRImages Honestly, up to 2020, I even didn't know, there were 2 different toolkits! Great finding! Thank you so much robdaemon and 'kind soul', what a discovery! ? Great! Quote Link to comment Share on other sites More sharing options...
+Larry Posted April 6, 2020 Share Posted April 6, 2020 I've always had a soft spot in my heart for BXL and BXE! BXL was the first interpreter to provide significant improvements to Atari 8K BASIC. I can still remember getting that orange cartridge, and writing useful utilities, especially using the String Array feature. There have been quite a few programs and articles written about how to "work around" the lack of string arrays in Atari BASIC, but none are as elegant as the built-in solution in BXL and BXE. -Larry Quote Link to comment Share on other sites More sharing options...
