HW-Detect
14 hours ago, x=usr(1536) said:
Here's a shot from my 600XL, if it helps.  It has been upgraded to 64K of internal RAM and Rev. C BASIC, so those items are correct.
thanks for the feedback ?
6 hours ago, mikesk8 said:
Here is my test on stock PAL 600XL. The OS ROM is not detected correctly ;( ps. thanks for sending a test version and please let me know if more tests are needed:)
thank you very much for the test at least no longer detects it as 400/800, just the same thing happens to me in the emulator does not detect me well when it is 600XL of 16k. I will continue investigating the case ....?
when I have something I'll let you know for another test.?
4 hours ago, tmp said:
a cosmetic issue, it says "RAM : 1088 KBtari" here
thanks for taking the time to report it. ?
  • 2 weeks later...
On 10/7/2021 at 1:36 PM, bf2k+ said:
Here's a strange one...  this 800XL has a 256k Rambo upgrade in it.  HWD is reporting 40kb Ram.  Sorry for all the reflected lights in the image.  Also it should be a stock Basic ROM probably rev B.
thank you very much for the report?, it seems to think it's a 400/800 that's why I detected 40kb.
can you run the following line in basic to see if I am correct.
? PEEK(64728)
  • 2 weeks later...
On 10/11/2021 at 9:06 PM, bf2k+ said:
peek(64728) = 76
Both of my Rambo 256k machines are exhibiting the same behavior.
Thank you very much, with that I rule out problems in the OS-A or OS-B detection.?
Now I did some tests and I was able to replicate the symptom in the emulator, when you have some time try this version.
hw-detect_b.xex
  • 2 weeks later...
5 hours ago, bf2k+ said:
Looks the same here...
thanks for the test, for some reason I don't know on your 800XL it doesn't disable basic as the RAM detection routine needs it disabled. can you load the program from DOS 2.5 with OPTION pressed and load the program?
6 minutes ago, bf2k+ said:
Yes my tests ae done with SpartaDOS X.
Use the X command to run the program. The "unknown BASIC ROM" is in fact the SDX Library ROM.
