Giles N Posted May 15, 2020 Author Share Posted May 15, 2020 On 5/10/2020 at 9:19 AM, KevinMos3 said: I've got this with running, jumping, and throwing so far. However, there are 5 running frames and only 2 drawn so far, so I just repeated the 2. There needs to be some more horizontal adjustment with some of the running frames to match head. I've had to trim down some of the sprites because they are only 12 pixels wide in the run. If you make the other 3, you might want to keep them at 11 pixels wide to allow for room for the horizontal adjustment that might be needed. The jump is slightly wider as well as the throw, but both had to be trimmed to fit as well. There are 2 head frames which are used for running, jumping, and throwing, so I had to do slight adjustments to them to match the heads. What's missing right now are 3 additional running frames (unless you only want 2), and the sprites of Louie (Scraps) with his back turned to the player as he answer the phone and knocks on doors (there are quite a few as seen below). Awesome! Thanks ! I’ll get on with the remaining frames! 1 Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 16, 2020 Author Share Posted May 16, 2020 On 5/10/2020 at 9:19 AM, KevinMos3 said: I've got this with running, jumping, and throwing so far. However, there are 5 running frames and only 2 drawn so far, so I just repeated the 2. There needs to be some more horizontal adjustment with some of the running frames to match head. I've had to trim down some of the sprites because they are only 12 pixels wide in the run. If you make the other 3, you might want to keep them at 11 pixels wide to allow for room for the horizontal adjustment that might be needed. The jump is slightly wider as well as the throw, but both had to be trimmed to fit as well. There are 2 head frames which are used for running, jumping, and throwing, so I had to do slight adjustments to them to match the heads. What's missing right now are 3 additional running frames (unless you only want 2), and the sprites of Louie (Scraps) with his back turned to the player as he answer the phone and knocks on doors (there are quite a few as seen below). Ok, so running: Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 16, 2020 Author Share Posted May 16, 2020 @KevinMos3 Do you need it posted in individual frames? Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted May 16, 2020 Share Posted May 16, 2020 Individual frames is easier. Saves me from having to separate them in Imageready. Also, there’s all the “back turned to the screen” sprites in my last post. Looks good so far. Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 16, 2020 Author Share Posted May 16, 2020 ?? Jump: squeezed to 12 in width. Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 16, 2020 Author Share Posted May 16, 2020 Scraps 1 Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 16, 2020 Author Share Posted May 16, 2020 (edited) 20 minutes ago, KevinMos3 said: Individual frames is easier. Saves me from having to separate them in Imageready. Also, there’s all the “back turned to the screen” sprites in my last post. Looks good so far. Ahem, it seems pixcel for ios hates me; I deleted frames of the dog to separate one frame; even though I choose ‘edit as new’. Would it be possible for you to extract the frames; goodness I can send you/invoice you 10 bucks for the trouble... Edited May 16, 2020 by Giles N Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 16, 2020 Author Share Posted May 16, 2020 Gimme some time people, I need to go and scream in a corner ... Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted May 17, 2020 Share Posted May 17, 2020 57 minutes ago, Giles N said: Would it be possible for you to extract the frames... No worries. They're extracted now. 46 minutes ago, Giles N said: Gimme some time people, I need to go and scream in a corner... 1 Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 17, 2020 Author Share Posted May 17, 2020 17 minutes ago, KevinMos3 said: No worries. They're extracted now. Thanks, appreciated man!! How I wanted to just so not (!!!) give these ios-apps 5-star-rating ... to put it mildly... Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 18, 2020 Author Share Posted May 18, 2020 Ok. I think the above ‘Scraps’ jump was 13 pixels wide: here is 12: Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 18, 2020 Author Share Posted May 18, 2020 Scraps throw item 12 pixel wide: Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted May 19, 2020 Share Posted May 19, 2020 Thanks, but all the sprites were already implemented except the ones requested above. The ones I needed were the remaining running and back-toward-screen for knocking and answering phone. The running sprites can be no more than 12 pixels wide, but there may be some misalignment with the head at that width, which is why I suggested keeping them to 11 pixels wide just in case. It's hard to tell until I get the other 3 running sprites implemented. The reason I didn't state exactly how wide jumping & throwing sprites can be is because they're already done. I just don't want you having to do extra work because of miscommunication. The original back-toward-screen sprites are included in my post above, in case you didn't notice them. They are right below the screenshot. Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 20, 2020 Author Share Posted May 20, 2020 (edited) 8 hours ago, KevinMos3 said: Thanks, but all the sprites were already implemented except the ones requested above. The ones I needed were the remaining running and back-toward-screen for knocking and answering phone. The running sprites can be no more than 12 pixels wide, but there may be some misalignment with the head at that width, which is why I suggested keeping them to 11 pixels wide just in case. It's hard to tell until I get the other 3 running sprites implemented. The reason I didn't state exactly how wide jumping & throwing sprites can be is because they're already done. I just don't want you having to do extra work because of miscommunication. The original back-toward-screen sprites are included in my post above, in case you didn't notice them. They are right below the screenshot. Thanks!! I got them, just need to actually do them (the frames). I just wanted to re-do the Scraps ‘jump’ and ‘throwing’, before I do the knock & enter-frames. They’re up next. — I also plan to do grfx for ‘Louie’ as being the abducted ‘owner’. Don’t know how many things can be replaced... Edited May 20, 2020 by Giles N Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 23, 2020 Author Share Posted May 23, 2020 I’m a bit slow getting back to 8-bit-modes... Here is Scraps seen front: (more to come) Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 23, 2020 Author Share Posted May 23, 2020 Constructive criticism is (gulp) welcome... Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 23, 2020 Author Share Posted May 23, 2020 On 5/19/2020 at 5:43 PM, KevinMos3 said: Thanks, but all the sprites were already implemented except the ones requested above. The ones I needed were the remaining running and back-toward-screen for knocking and answering phone. The running sprites can be no more than 12 pixels wide, but there may be some misalignment with the head at that width, which is why I suggested keeping them to 11 pixels wide just in case. It's hard to tell until I get the other 3 running sprites implemented. The reason I didn't state exactly how wide jumping & throwing sprites can be is because they're already done. I just don't want you having to do extra work because of miscommunication. The original back-toward-screen sprites are included in my post above, in case you didn't notice them. They are right below the screenshot. Hm, I really tried to keep all frames within 12 pixels wide, including the new ‘dog-throwing-sprites’. I’m working on the ‘knock-on-door’ + ‘pick up phone’ sprites; I just need a little time. If my new ‘throw’ and ‘jump’-sprites could be inserted it would be really cool... I also plan an image for start-scene ‘we’ve got your owner...’ etc Don’t know if that can work; I have zero knowledge as to programming/hacking; only try to do some grfx-stuff... — all good to everyone here... Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 23, 2020 Author Share Posted May 23, 2020 ‘Scraps’ Front (update) Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 23, 2020 Author Share Posted May 23, 2020 Scraps ‘back’ Frame 1 Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 23, 2020 Author Share Posted May 23, 2020 Enter Scraps ! Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 23, 2020 Author Share Posted May 23, 2020 Next up: «The Knocking of Scraps» Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 23, 2020 Author Share Posted May 23, 2020 Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 24, 2020 Author Share Posted May 24, 2020 SCRAPS knocking on the door 11/12 wide Quote Link to comment Share on other sites More sharing options...
Giles N Posted May 24, 2020 Author Share Posted May 24, 2020 Enter SCRAPs - the DOG Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted May 24, 2020 Share Posted May 24, 2020 I've got pretty much everything put in and lined up. The text and images were changed to refer to Louie being kidnapped instead of Scraps. Louie is tied up at the end, but I've not been able to test it to see how it looks. It may need tweaked for alignment or color, but I don't plan to play through to the end anytime soon to see it. I've only played up to the first sewer. If anyone wants to do more editing on it, feel free. I'm not happy with the way the sprites are used for knocking and walking into doors/tunnels, but I've had enough for now. There's a regular sprite hacked version and an infinite lives sprite hacked version to help with the difficulty. If you want to play them in Prosystem, you'll need to add the below md5 to your Prosystem.dat file. MAME/MESS should work fine. They've also been re-signed. [01d88a3023606a1a002eeaf8e51a9745] title=Scrapyard Dog (Scraps Hack Infinite) type=4 pokey=false controller1=1 controller2=1 region=0 flags=0 [6a00eb356245fc24df4bed7f5a3d4b74] title=Scrapyard Dog (Scraps Hack) type=4 pokey=false controller1=1 controller2=1 region=0 flags=0 ScrapYard_(Scraps Hack).a78 ScrapYard_(Scraps Hack)_[Inf_Lives].a78 The tied up Louie will probably need his colors changed. I'm guessing he'll look like this, but don't know for sure. If someone wants to share a save-state for the end, I'll follow up with a color change. 2 Quote Link to comment Share on other sites More sharing options...
