MYARC HFDC V12 Eprom Source Code
9640News
There are two known bugs in V12 that were identified long ago by an astute user/programmer.  Alas, the text file containing the fixes is missing the crucial details, and there is no guarantee the surviving source code matches the version he fixed.   Tony's updates were based on the V11 EPROM image.
  • 2 years later...
Was the V11 source ever available?
I have another question as I am wanting to revisit an old project I once attempted.  Can someone show me a piece of assembly code with the CRU of the HFDC at >1000, that would turn on and show the RAM contents at >5400 for the first bank of a 32K memory block and the last bank of the 32K memory block?  I am not quite sure how to read the CRU relative address for 12-1A as defined below.
LDCR writes bits LSB first. It is saying that a 5 bit bank number begins with LSBit at 1012.
Since it’s less than 8 bits, LDCR takes from the MSB:
LI R12,>1012
LI R1,>1F00  set bank >1F
LDCR R1,5
The ROM page select bits appear to be in 2X format. Going MSB first. So these are equivalent:
LI R12,>1000
SBZ 3     MSBit in docs - zero
SBO 4     LSBit in docs - one
and
LI R12,>1006
LI R1,>0200   bit order reversed: one zero
LDCR R1,2
Edited by FarmerPotato
Not to my knowledge. The only version of the DSR source that I have seen is what I released from John Birdwell's MFM hard drive backup disks.  There may have been another release (same version) floating around, possibly from Mike, as I think I got the physical disks from him.  That was 30+years ago.. wow.
Unfortunately, there were many code changes between the stable V11 and the unproven V12/V13. It would not be easy to disassemble V11 and reconstitute the source based on V12.  Although I started to do just this, I quickly realized I wasn't interested in another S-Rank project.
LI R12,>1012
LDCR R1,5
LI R12,>1000
SBZ 3     MSBit in docs
SBO 4     LSBit in docs
and
LI R12,>1006
LDCR R1,2
Thanks for the feedback and example.
