FreddieBear Posted October 24, 2020 Share Posted October 24, 2020 17 hours ago, tschak909 said: You can see the [N]ew option, here, after you've selected a host slot: Thank you. Now I know where it is. Much appreciated. Long live Atari. 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4661919 Share on other sites More sharing options...
FreddieBear Posted October 24, 2020 Share Posted October 24, 2020 2 hours ago, 8bitguy1 said: Just a random thought, are you using an SDM that doesn't play nice with other things on the SIO chain? or does yours have the mod? Yes it has the little purple add on board that lets it play well with others. 19 hours ago, tschak909 said: You can see the [N]ew option, here, after you've selected a host slot: Thank you. Now I know where it is. Much appreciated. Long live Atari. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4661997 Share on other sites More sharing options...
tschak909 Posted October 25, 2020 Author Share Posted October 25, 2020 For those who want/need it. A friend of mine (Radu Cristescu aka uplink), had written both a python TNFS client, and a FUSE filesystem adapter. This program is very simple, you can list directory, get, put single files, etc. This is useful for example for pulling files off of public servers. It is in our repo, here: https://github.com/FujiNetWIFI/spectranet-tnfs-fuse Hopefully somebody can take this as a start for a better client. -Thom 4 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4662008 Share on other sites More sharing options...
Kyle22 Posted October 26, 2020 Share Posted October 26, 2020 Could problems with other SIO devices be caused by the VERY short pins on the pass through SIO connector? Longer pins or about 1/4" trimmed off the plastic would help. Nothing will stay plugged into mine. Plug SIO2BT in and shake it... it falls out. If you even TOUCH an SIO cable plugged in to it, it falls out. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4662758 Share on other sites More sharing options...
mozzwald Posted October 26, 2020 Share Posted October 26, 2020 9 minutes ago, Kyle22 said: Could problems with other SIO devices be caused by the VERY short pins on the pass through SIO connector? Not likely. 9 minutes ago, Kyle22 said: Longer pins or about 1/4" trimmed off the plastic would help. Nothing will stay plugged into mine. Plug SIO2BT in and shake it... it falls out. If you even TOUCH an SIO cable plugged in to it, it falls out. You got an early unit before I was aware of this issue. The fix is a slightly shorter plastic connector. PM me and we can work something out to get it fixed. 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4662773 Share on other sites More sharing options...
manterola Posted October 26, 2020 Share Posted October 26, 2020 The issues with other devices in the SIOchain is not that easy to solve (I guess) since it works sometimes, and it does not work 10 seconds later. I did multiples test yesterday and the results were weird. The only consistent observation so far it that when normal speed is used there is no problems (I tried stock 1050 and AVGcart thru SIO). Some examples of weirdness: - I used a 800XL patched rom with Hias high speed code and unmodified 1050, everything works as expected. But if I used the speedy 1050, the speedy boot the first time. Then I do cold reset, and this time FujiNet boots up. Cold reset again, Speedy 1050 start to boot, cold reset, now the FujiNet boots. Sometimes I killed the booting process with another cold reset so the boot did not finish, but that the sequence still happened... very weird. -I did the same test, but now with a U1M installed computer. Using Atari XL OS it works as expected. Switching to QMEG OS (which supports HS) it is very different behavior. The first boot you can hear a very short SIO noise, then nothing for about 10 seconds or a bit less: 1050 static, computer displaying the cursor, zero SIO noises, and after that the speedy 1050 starts the booting process. I cold reset the computer, and this time I got a bunch of "boot error"s in the screen pretty fast. I turn the computer off and I got the same boot errors (unless I turn off the FujiNet). Notice that in this case FujiNet never takes control of the booting, it only prevents the speedy 1050 to boot. If I wait enough or try enough times I can get the 1050 speedy to boot again, but still when it works It goes thru that 10 second waiting period. More testing is necessary, but I guess I need to test checking the debug console. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4663119 Share on other sites More sharing options...
Mr Robot Posted October 26, 2020 Share Posted October 26, 2020 Now that more public TNFS servers are coming on line and clients for platforms other than the Atari are starting to appear, I have decided to return my TNFS server back into a private server. Please remove Fujinet.Atari8bit.net from your server lists. Thanks! Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4663254 Share on other sites More sharing options...
JohnPolka Posted October 26, 2020 Share Posted October 26, 2020 44 minutes ago, Mr Robot said: Now that more public TNFS servers are coming on line and clients for platforms other than the Atari are starting to appear, I have decided to return my TNFS server back into a private server. Please remove Fujinet.Atari8bit.net from your server lists. Thanks! Are the public servers posted somewhere, like on the Fujinet website? It would be nice to have a regularly updated list of public servers documented somewhere. -JP 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4663294 Share on other sites More sharing options...
dl7ukk Posted October 26, 2020 Share Posted October 26, 2020 Hello, one question please, are there any concerns about the security of the server (tnfsd) for the (my) home network? Greeting Andreas Hallo, eine Frage bitte, gibt es Bedenken wegen der Sicherheit des Servers (tnfsd) für das (mein) Heimnetz? Gruß Andreas Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4663507 Share on other sites More sharing options...
tschak909 Posted October 26, 2020 Author Share Posted October 26, 2020 4 hours ago, JohnPolka said: Are the public servers posted somewhere, like on the Fujinet website? It would be nice to have a regularly updated list of public servers documented somewhere. -JP I will make one on the Wiki, shortly, in the mean time, there is a list at http://fujinet.pl/ 4 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4663508 Share on other sites More sharing options...
tschak909 Posted October 26, 2020 Author Share Posted October 26, 2020 2 minutes ago, dl7ukk said: Hello, one question please, are there any concerns about the security of the server (tnfsd) for the (my) home network? Greeting Andreas Hallo, eine Frage bitte, gibt es Bedenken wegen der Sicherheit des Servers (tnfsd) für das (mein) Heimnetz? Gruß Andreas Hi! TNFS uses one UDP port, 16384, and there aren't any known buffer overflow issues. While there are fields for username and password, they currently are not used in the current iteration of the protocol. If you have a server on your local network, unless you want to publically expose it, just keep it on your local network. -Thom 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4663509 Share on other sites More sharing options...
Mr Robot Posted October 27, 2020 Share Posted October 27, 2020 On 10/23/2020 at 2:00 PM, Mr Robot said: I only suggested it 3 hours ago! I thought I'd leave it for a couple of days to see how popular the idea is and if it seems like a wanted thing I was going to ask @Albert I tried to message @Albert last night but I wasn't allowed to message him so I messaged the Admin team and requested a Fujinet subforum. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4663891 Share on other sites More sharing options...
tschak909 Posted October 27, 2020 Author Share Posted October 27, 2020 2 minutes ago, Mr Robot said: I tried to message @Albert last night but I wasn't allowed to message him so I messaged the Admin team and requested a Fujinet subforum. Thanks, Steve! -Thom Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4663892 Share on other sites More sharing options...
Mark Simonson Posted October 28, 2020 Share Posted October 28, 2020 I just received my FujiNet device today. I'd like to set up a local (private) tnfs server on my Mac to use with it. I downloaded one from http://spectrum.alioth.net/doc/index.php/TNFS_server and got it installed and running, pointed to a folder on my system. But when I try to access it as a host on the FujiNet, I get "ERROR MOUNTING HOST SLOTS". I've had no luck so far finding information on how to get this working on a Mac, other than the read me file accompanying the tnfsd daemon. Has anyone been able to get a tnfs server working on a Mac with FujiNet? Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664380 Share on other sites More sharing options...
tschak909 Posted October 28, 2020 Author Share Posted October 28, 2020 @Mark Simonson where did you see that link? this is to the old TNFS server. We had to make a change to the TNFS protocol to improve performance, and you can get a copy of the tnfsd here: https://github.com/FujiNetWIFI/spectranet/releases/tag/TNFSD-2020-10-19 -Thom 1 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664400 Share on other sites More sharing options...
Albert Posted October 28, 2020 Share Posted October 28, 2020 11 hours ago, Mr Robot said: I tried to message @Albert last night but I wasn't allowed to message him so I messaged the Admin team and requested a Fujinet subforum. Been pretty busy, I will look at creating this tomorrow. ..Al 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664406 Share on other sites More sharing options...
Mark Simonson Posted October 28, 2020 Share Posted October 28, 2020 Quote where did you see that link? It was on the first post in this topic. Awesome--it works now! Thanks for the link, Thom! Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664418 Share on other sites More sharing options...
tschak909 Posted October 28, 2020 Author Share Posted October 28, 2020 2 minutes ago, Mark Simonson said: It was on the first post in this topic. Awesome--it works now! Thanks for the link, Thom! Ok, I'll see if I can change that. Thanks! -Thom Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664421 Share on other sites More sharing options...
Mr Robot Posted October 28, 2020 Share Posted October 28, 2020 9 hours ago, Albert said: Been pretty busy, I will look at creating this tomorrow. ..Al Great! thanks Al! Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664592 Share on other sites More sharing options...
fenrock Posted October 28, 2020 Share Posted October 28, 2020 (edited) it's alive! Just got my shiny red FujiNet. Thanks to @zaxon for making and sending it out! Edited October 28, 2020 by fenrock 5 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664617 Share on other sites More sharing options...
Albert Posted October 28, 2020 Share Posted October 28, 2020 I have created the #FujiNet Forum and moved any recent FujiNet threads into it. If someone wants to make a list of additional threads that should be moved, you can either post them here or send them to me in a PM and I will get those moved as well. Enjoy! ..Al 4 3 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664719 Share on other sites More sharing options...
tschak909 Posted October 28, 2020 Author Share Posted October 28, 2020 Thanks, @Albert *HUG* -Thom 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664720 Share on other sites More sharing options...
Albert Posted October 28, 2020 Share Posted October 28, 2020 You're welcome! Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4664721 Share on other sites More sharing options...
phigan Posted October 29, 2020 Share Posted October 29, 2020 Is there any writeup or demo of "SIO2BT mode" yet? If it's on, are any of the other Fujinet features still on? Mounted disk, etc? Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4665163 Share on other sites More sharing options...
tschak909 Posted October 29, 2020 Author Share Posted October 29, 2020 @TheMontezuma did a demo here: But basically, You long press button A, blue light comes on, at this point, you can pair with the SIO2BT app. Once done, the phone can mount/unmount disks into slots. As of right now, the bluetooth mode takes over the device, until you long press A again to go back into normal mode. It also must be understood that you need an SIO2BT modified OS ROM, the easiest way to get this is via the Ultimate 1MB, and enabling SIO2BT mode in the PBI menu. -Thom 2 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/76/#findComment-4665170 Share on other sites More sharing options...
