+x=usr(1536) Posted November 8, 2020 Share Posted November 8, 2020 (edited) 37 minutes ago, tschak909 said: I am genuinely confused, and I think you are very much making things 50 times harder than you should be. You have a FujiNet, Why do you need the SIO2PC at all in this scenario? Just move the images over to the SD card. done. -Thom I'll be the first to admit that I may very well be overthinking the scenario - it wouldn't be the first time ? There are a couple of things that weren't mentioned in the original post: first, that the plan is to have one FujiNet per A8; second, that I'm planning on running TNFSD on the existing fileserver. In order to keep the software library synchronised between A8s, I'd prefer to run them without individual SD cards and just have them mount TNFS shares in order to access disk images, etc. This is effectively equivalent to how we use certain things already (e.g., emulators) in order to keep things sane across multiple machines. As for the SIO2PC, I'm not aware of a way to connect a non-SIO physical POTS modem to the FujiNet; the SIO2PC was going to effectively be the glue to make that happen. I'd be happy to be wrong in my understanding of this, however Edited November 8, 2020 by x=usr(1536) 1 Quote Link to comment Share on other sites More sharing options...
vazquezrick Posted November 8, 2020 Share Posted November 8, 2020 The FujiNet is a really device. The are some interesting images on various sites. I’ve managed to copy the modem software from one of the TNSF servers to a 5.25 floppy (why? just because) using DOS.However, there are other images that aren’t standard size (floppy disk) so not easily copied. Does anyone have a suggestion of how to copy these non-standard images to the local FujiNet SD card? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 8, 2020 Author Share Posted November 8, 2020 1 minute ago, vazquezrick said: The FujiNet is a really device. The are some interesting images on various sites. I’ve managed to copy the modem software from one of the TNSF servers to a 5.25 floppy (why? just because) using DOS. However, there are other images that aren’t standard size (floppy disk) so not easily copied. Does anyone have a suggestion of how to copy these non-standard images to the local FujiNet SD card? Use the tnfs_client.py program here to get the file, you can then copy to the card: https://github.com/FujiNetWIFI/spectranet-tnfs-fuse -Thom Quote Link to comment Share on other sites More sharing options...
mozzwald Posted November 8, 2020 Share Posted November 8, 2020 (edited) A new firmware update is available at https://fujinet.online/download. Notable new features: Ability to save application configuration information on SD card (Device $70, SIO commands $DB-$DE) for use by developers writing new Atari applications. Used by the latest weather app from @bocianu Modem Sniffer I have started a new thread where I will post this information from now on so that you may subscribe and get notifications when updates are available: Edited November 8, 2020 by mozzwald new thread info 3 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 8, 2020 Author Share Posted November 8, 2020 #Atari8bit With the latest firmware update, #FujiNet now allows you to log WiFi modem traffic to a file that can be picked up in the web admin, such could be used for protocol analysis. 4 Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted November 8, 2020 Share Posted November 8, 2020 23 minutes ago, tschak909 said: #Atari8bit With the latest firmware update, #FujiNet now allows you to log WiFi modem traffic to a file that can be picked up in the web admin, such could be used for protocol analysis. Nice! Just watched the video; it didn't mention if pcap format was also an option (or planned one). Is it / will it be supported? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 8, 2020 Author Share Posted November 8, 2020 pcap isn't really applicable for the wifi modem, so no. -Thom 1 Quote Link to comment Share on other sites More sharing options...
Colonel Llama Posted November 8, 2020 Share Posted November 8, 2020 Got my hands on a XEGS with keyboard last week and i just found out about this. Planning to get a Fujinet as soon as it comes back in stock. Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted November 8, 2020 Share Posted November 8, 2020 24 minutes ago, tschak909 said: pcap isn't really applicable for the wifi modem, so no. -Thom Yeah, my bad. I misinterpreted what was being captured. Appreciate the clarification, though. Quote Link to comment Share on other sites More sharing options...
gs80065xe Posted November 9, 2020 Share Posted November 9, 2020 8 hours ago, tschak909 said: The FCD tool is somewhat broken, and it's because I need to find a way to make it work that interacts cleanly with the existing firmware. I do not recommend using it at this time. The documentation got to be too big (approaching 64 file limit), so it was split off into its own ATR fnc-tools-doc.atr, which you can find on the atari-apps.irata.online TNFS server. Something to note, this entire project is evolving rapidly, so things like outdated documentation and some tools not working are a consequence. We are trying to get everything up to speed as best we can, and can always use some help. This is why everything is open source in this project. Also, yes, the time.com tool in fnc-tools.atr uses the APE TIME protocol to send a time-stamp to the Atari, synchronized from NTP. -Thom Thanks. APETIME works great. BTW, the doc atr only contained the com files when I mounted it. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted November 9, 2020 Share Posted November 9, 2020 Is it possible or would it be possible to disable key clicks? Thanks! Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 9, 2020 Author Share Posted November 9, 2020 4 minutes ago, Philsan said: Is it possible or would it be possible to disable key clicks? Thanks! key clicks where? -Thom Quote Link to comment Share on other sites More sharing options...
+Philsan Posted November 9, 2020 Share Posted November 9, 2020 2 minutes ago, tschak909 said: key clicks where? -Thom On FujiNet menu. The default sound when you press a key that can be disabled with POKE 731,255. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 9, 2020 Author Share Posted November 9, 2020 I'd rather not, that's valuable UI feedback. -Thom Quote Link to comment Share on other sites More sharing options...
gs80065xe Posted November 10, 2020 Share Posted November 10, 2020 I've noticed a quirk with FUJINET and SDX v4.49. I had the FNCTools ATR mounted to device slot 2. And copied them to my HD on D3:. I rebooted and ejected the ATR from Fujinet. But SDX DF still shows the D1: drive with a disk present. I DIR of that drive shows the FNC tools contents. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 10, 2020 Author Share Posted November 10, 2020 The D1: that is on the SPIFFS flash, contains both CONFIG and the fnc-tools together. This is by design. There IS a bug where if you don't mount something into D1, it won't eject the CONFIG disk in the SPIFFS, it's on our list to fix. -Thom Quote Link to comment Share on other sites More sharing options...
gs80065xe Posted November 10, 2020 Share Posted November 10, 2020 Good to know. Thought the TNFS was failing to unmount. Thanks. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 10, 2020 Author Share Posted November 10, 2020 #Atari8bit #FujiNet - Testing @jeffpiep's cassette support, one title at a time, most things work, still some outliers, we will analyze what doesn't work. 4 Quote Link to comment Share on other sites More sharing options...
manterola Posted November 10, 2020 Share Posted November 10, 2020 12 hours ago, tschak909 said: #Atari8bit #FujiNet - Testing @jeffpiep's cassette support, one title at a time, most things work, still some outliers, we will analyze what doesn't work Check the .cas files in fujinet.us.to I put some "exotic" cassette loaders there, most of them work with AVGCart cassette emulation. 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 10, 2020 Author Share Posted November 10, 2020 12 minutes ago, manterola said: Check the .cas files in fujinet.us.to I put some "exotic" cassette loaders there, most of them work with AVGCart cassette emulation. I'm afraid. -Thom Quote Link to comment Share on other sites More sharing options...
manterola Posted November 10, 2020 Share Posted November 10, 2020 7 minutes ago, tschak909 said: I'm afraid. -Thom ? ? 1 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted November 10, 2020 Share Posted November 10, 2020 On 11/9/2020 at 10:08 PM, tschak909 said: I'd rather not, that's valuable UI feedback. -Thom When browsing through dozens of files keyclick sound is annoying. For example, Side2/3 multicart lets you disable it, AVGCart doesn't have it. If possible, it would be nice to add an option to disable that sound. Please... Thank you! 3 Quote Link to comment Share on other sites More sharing options...
KLund1 Posted November 11, 2020 Share Posted November 11, 2020 I have been away for a while, and am just starting to learn about this incredible device. I have watched a couple vids about it. And really like its capabilities! My Atari daily driver is a Atarimax 1200XL with a 32-in-1 OS selector. Is the new device compatible with the 32-in-1? I did a few quick searchers and did not see any results about this particular topic. Though I may have missed something in my recent absence. (in the middle of a house remodel) Sorry for interrupting the above conversation. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 11, 2020 Author Share Posted November 11, 2020 @KLund1 yes, it's compatible. It is, at the end of the day, a device that simply speaks SIO protocol. 1 Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted November 14, 2020 Share Posted November 14, 2020 On 10/27/2020 at 7:51 PM, tschak909 said: @Mark Simonson where did you see that link? this is to the old TNFS server. We had to make a change to the TNFS protocol to improve performance, and you can get a copy of the tnfsd here: https://github.com/FujiNetWIFI/spectranet/releases/tag/TNFSD-2020-10-19 -Thom TNFS GitHub software for Windows7 32 bit doesn't work. My PC refuses to run it even as Administrator. Quote Link to comment Share on other sites More sharing options...
