Sempo Posted June 13 Share Posted June 13 @16kRAM - Can you double-check the atr that you provided? It's still misbehaving. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5485057 Share on other sites More sharing options...
16kRAM Posted June 13 Share Posted June 13 1 hour ago, Sempo said: @16kRAM - Can you double-check the atr that you provided? It's still misbehaving. @Sempo Apologies. Not sure where things went sideways, but after rebuilding, this image that I just tested has a different md5sum than the one I shared earlier. $ md5sum n-handler.atr 6e5a429517ea5bf9f19d14df7af861bd n-handler.atr n-handler.atr Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5485097 Share on other sites More sharing options...
Sempo Posted June 13 Share Posted June 13 15 hours ago, 16kRAM said: @Sempo Apologies. Not sure where things went sideways, but after rebuilding, this image that I just tested has a different md5sum than the one I shared earlier. First test with this one looks good. Thanks for the quick fix! 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5485435 Share on other sites More sharing options...
rdefabri Posted September 26 Share Posted September 26 Not sure if this is where I should be posting this, but I’m trying to create .atr files of my floppy disks, and when I go to boot DOS (mounted on Fujinet drive #1), it goes to memo pad. I don’t have a USB cable to externally power the device (and very few plugs since I have the Atari 800, 810, and monitor all plugged in). Is there a workaround that allows me to delay the 800 boot process so it lets the Fujinet drive load? Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5539464 Share on other sites More sharing options...
tschak909 Posted September 26 Author Share Posted September 26 14 minutes ago, rdefabri said: Not sure if this is where I should be posting this, but I’m trying to create .atr files of my floppy disks, and when I go to boot DOS (mounted on Fujinet drive #1), it goes to memo pad. I don’t have a USB cable to externally power the device (and very few plugs since I have the Atari 800, 810, and monitor all plugged in). Is there a workaround that allows me to delay the 800 boot process so it lets the Fujinet drive load? If you have version 1.4 of the firmware (you can see what version you have, inside CONFIG), your FujiNet should boot quickly enough to allow the 800 to power the FujiNet from the bus and have it ready for boot. do you? -Thom Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5539470 Share on other sites More sharing options...
rdefabri Posted September 27 Share Posted September 27 3 hours ago, tschak909 said: If you have version 1.4 of the firmware (you can see what version you have, inside CONFIG), your FujiNet should boot quickly enough to allow the 800 to power the FujiNet from the bus and have it ready for boot. do you? -Thom Nope I have version 1.2, so I’ll have to figure out how to upgrade :) Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5539556 Share on other sites More sharing options...
tschak909 Posted September 27 Author Share Posted September 27 2 minutes ago, rdefabri said: Nope I have version 1.2, so I’ll have to figure out how to upgrade * Grab FujiNet-Flasher for your platform, here: https://github.com/FujiNetWIFI/fujinet-flasher/releases/ * Ensure that you have a USB cable that you can plug into said PC running the flasher, that has all its pins (not just a power cable) * Run the program, select the appropriate port for the flasher, select Atari 8-bit, and select version 1.4.0 (The latest). Press Flash. It will erase, and re-flash the device. Once done, it can be used. -Thom Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5539557 Share on other sites More sharing options...
rdefabri Posted September 27 Share Posted September 27 18 hours ago, tschak909 said: * Grab FujiNet-Flasher for your platform, here: https://github.com/FujiNetWIFI/fujinet-flasher/releases/ * Ensure that you have a USB cable that you can plug into said PC running the flasher, that has all its pins (not just a power cable) * Run the program, select the appropriate port for the flasher, select Atari 8-bit, and select version 1.4.0 (The latest). Press Flash. It will erase, and re-flash the device. Once done, it can be used. -Thom Downloaded the flasher, but when I launch it, it wont let me select the port. I have the unit connected via USB, but when I go to flash, I get "no serial port found!" error. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5539993 Share on other sites More sharing options...
+DjayBee Posted September 27 Share Posted September 27 8 minutes ago, rdefabri said: Downloaded the flasher, but when I launch it, it wont let me select the port. I have the unit connected via USB, but when I go to flash, I get "no serial port found!" error. You probably miss the needed driver. Check https://fujinet.online/download/ for details. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540001 Share on other sites More sharing options...
16kRAM Posted September 27 Share Posted September 27 On 9/26/2024 at 5:16 PM, rdefabri said: Is there a workaround that allows me to delay the 800 boot process so it lets the Fujinet drive load? Until you get a cable, hold the START console while powering on the 800. You'll hear a beep. Then press RESET. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540036 Share on other sites More sharing options...
rdefabri Posted September 27 Share Posted September 27 1 hour ago, DjayBee said: You probably miss the needed driver. Check https://fujinet.online/download/ for details. Tried this - no dice. Still have a blank pick list for serial port and it still gives me the "no serial port" error. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540075 Share on other sites More sharing options...
rdefabri Posted September 27 Share Posted September 27 1 hour ago, 16kRAM said: Until you get a cable, hold the START console while powering on the 800. You'll hear a beep. Then press RESET. Yes, I was doing this. But once I mount a virtual disk and I press option to reboot, it goes to memo pad. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540077 Share on other sites More sharing options...
_The Doctor__ Posted September 28 Share Posted September 28 (edited) as stated before, you need to update the firmware. if windows is saying no serial port, you need the older driver and must disable windows updates for ch340 and ch341 devices, that's been an issue since sometime last year. Edited September 28 by _The Doctor__ Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540133 Share on other sites More sharing options...
rdefabri Posted September 28 Share Posted September 28 10 hours ago, _The Doctor__ said: as stated before, you need to update the firmware. if windows is saying no serial port, you need the older driver and must disable windows updates for ch340 and ch341 devices, that's been an issue since sometime last year. You'll have to bear with me - I'm not the most technically minded person I downloaded the flasher, then downloaded the older driver. Extracted all of it into a single folder, then ran the flasher. It didn't give me any options to pick anything from the serial port. As I read your post, there's an additional step where I have to disable Windows updates for ch340 and ch341 devices - how do I do that? I'm guessing somewhere in Device Manager? Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540279 Share on other sites More sharing options...
_The Doctor__ Posted September 28 Share Posted September 28 (edited) you need to install the older driver, there is a complete step by step on multiple windows forums on how to disable updates for specific items within each specific windows flavor. I set my windows to only download but not install updates, then I set it to ignore the updates I do not want. It is a clickable choice that way. Edited September 28 by _The Doctor__ Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540287 Share on other sites More sharing options...
+DjayBee Posted September 28 Share Posted September 28 Huh? I never did disable any updates. Just install the driver from the Silicon Labs website, reboot for safety and plug in your FujiNet. The only confusing part is that there is more than one driver pack for Windows. You need the "CP210x Universal Windows Driver". Most of the times Windows does not recognize the device, it is because the USB-cable has no or bad data lines. 1 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540399 Share on other sites More sharing options...
_The Doctor__ Posted September 28 Share Posted September 28 I may be thinking of the other driver for sdrive max or some other device if it isn't 340 0r 341. But he said he copied a driver to his folder, but did not mention installing the driver. I suggest installing the driver and once working, not allowing updates to screw it up. Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5540417 Share on other sites More sharing options...
rdefabri Posted September 30 Share Posted September 30 (edited) On 9/28/2024 at 2:56 PM, _The Doctor__ said: I may be thinking of the other driver for sdrive max or some other device if it isn't 340 0r 341. But he said he copied a driver to his folder, but did not mention installing the driver. I suggest installing the driver and once working, not allowing updates to screw it up. Looks like I didn't complete the install. I've now fixed that and updated the Fujinet device with the flasher. Testing to see if the firmware fixed the issue of going to memo pad on reboot. ****EDIT - looks like that worked! Thanks everyone for the help! Edited September 30 by rdefabri 5 Quote Link to comment https://forums.atariage.com/topic/298720-fujinet-a-wip-sio-network-adapter-for-the-atari-8-bit/page/95/#findComment-5541638 Share on other sites More sharing options...
