EpikalPuppy Posted December 3, 2019 Share Posted December 3, 2019 I recently got my first 5200, and, as the case on it was cracked, ordered another that was "untested". The untested 5200 actually came with some games: Moon Patrol, Galaxian, Ms. Pacman, and Space Invaders. I already had a few games: Qix, Pacman, Super Breakout, Soccer, Baseball, and Centipede. When I put Moon Patrol and Galaxian in the 5200 I already owned, they both had weird glitches. Moon Patrol would have weird colors, purple on the title screen, and the rover was green instead of purple. Galaxian had random lines on the screen and would not start. Every other game I had worked perfectly on this system. When I tested these games on the untested 5200 that I had just gotten, they worked perfectly. I tried reseating all of the chips on the board of the original 5200, but the games still don't work correctly. If anybody recognizes these symptoms and could help me with this, I would greatly appreciate it. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/ Share on other sites More sharing options...
0078265317 Posted December 3, 2019 Share Posted December 3, 2019 Mountain King Pitfall 1 not 2 K-crazy Shoot-out Are know not to work on 2 port systems. The rest should be fine. it's weird they are not. There is a color pot adjustment wheel inside the 5200 you can try adjusting. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4402742 Share on other sites More sharing options...
Greg2600 Posted December 3, 2019 Share Posted December 3, 2019 Technically you could swap in a bios chip from a 4-port and get compatibility. Otherwise if you had an Atarimax flash cart, there are hacked versions of those games which do work on 2-ports. 2 Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4402747 Share on other sites More sharing options...
EpikalPuppy Posted December 3, 2019 Author Share Posted December 3, 2019 (edited) Well, these games work on one of my two ports, and don't work on the other. They are also not four port exclusive games, also, it's not just the colors that are wrong, Galaxian crashes at the title screen. Is there anything special about these games? Edited December 3, 2019 by EpikalPuppy Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4402748 Share on other sites More sharing options...
MIKE5200 Posted December 3, 2019 Share Posted December 3, 2019 19 hours ago, EpikalPuppy said: Well, these games work on one of my two ports, and don't work on the other. They are also not four port exclusive games, also, it's not just the colors that are wrong, Galaxian crashes at the title screen. Is there anything special about these games? Hi, Did you try cleaning the carts? Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403318 Share on other sites More sharing options...
EpikalPuppy Posted December 3, 2019 Author Share Posted December 3, 2019 Just now, MIKE5200 said: Hi, Did you try cleaning the carts? I did, with rubbing alcohol and an eraser. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403319 Share on other sites More sharing options...
MIKE5200 Posted December 3, 2019 Share Posted December 3, 2019 11 minutes ago, EpikalPuppy said: I did, with rubbing alcohol and an eraser. You said that the game work on one but not the other? Then open it up and check your RAM or swaping them out. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403329 Share on other sites More sharing options...
EpikalPuppy Posted December 3, 2019 Author Share Posted December 3, 2019 3 minutes ago, MIKE5200 said: You said that the game work on one but not the other? Then open it up and check your RAM or swaping them out. I think I'm going to try that. I'm really busy with finals right now, but I'll update some time. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403330 Share on other sites More sharing options...
SoundGammon Posted December 3, 2019 Share Posted December 3, 2019 I have a custom 4-port OS chip that changes the text / font to a computer style that I can make you a copy and put in yours! Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403346 Share on other sites More sharing options...
EpikalPuppy Posted December 4, 2019 Author Share Posted December 4, 2019 17 minutes ago, SoundGammon said: I have a custom 4-port OS chip that changes the text / font to a computer style that I can make you a copy and put in yours! That sounds cool, how do you install it? Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403352 Share on other sites More sharing options...
SoundGammon Posted December 4, 2019 Share Posted December 4, 2019 1 hour ago, EpikalPuppy said: That sounds cool, how do you install it? Very easy! It's the only 24 pin chip on the board, upper left. Remove the old one and replace with the one I made. 1 Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403412 Share on other sites More sharing options...
EpikalPuppy Posted December 4, 2019 Author Share Posted December 4, 2019 32 minutes ago, SoundGammon said: Very easy! It's the only 24 pin chip on the board, upper left. Remove the old one and replace with the one I made. Sounds pretty cool. This weekend, if I'm not too busy, I'll try swapping some chips around between my 5200's. What does the computer font look like? I've actually never used an Atari 8-bit, but I really want to get an 800 or 800XL. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403441 Share on other sites More sharing options...
BIGHMW Posted December 4, 2019 Share Posted December 4, 2019 On 12/2/2019 at 7:42 PM, Greg2600 said: Otherwise if you had an Atarimax flash cart, there are hacked versions of those games which do work on 2-ports. You took the words right outta my mouth, and yes, I DO have those hacks to Mountain King, K-razy Shoot-out, and Pitfall! Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403560 Share on other sites More sharing options...
+cjherr Posted December 4, 2019 Share Posted December 4, 2019 Could you please tell me where I can find those modified titles? K-Razy Shootout is one of my favorites. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4403719 Share on other sites More sharing options...
Greg2600 Posted December 4, 2019 Share Posted December 4, 2019 8 hours ago, cjherr said: Could you please tell me where I can find those modified titles? K-Razy Shootout is one of my favorites. Can't find a rom here but most fullsets out there have variants, and the hacks will usually read this way: [h1] (Two Port) 15 hours ago, BIGHMW said: You took the words right outta my mouth, and yes, I DO have those hacks to Mountain King, K-razy Shoot-out, and Pitfall! In re-reading the OP's issues, this was not his major problem. Sounds like something else (dirty or faulty). Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4404013 Share on other sites More sharing options...
+cjherr Posted December 4, 2019 Share Posted December 4, 2019 Thank you. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4404028 Share on other sites More sharing options...
Greg2600 Posted December 4, 2019 Share Posted December 4, 2019 Just now, cjherr said: Thank you. Another option is just get a "4-port" bios and slot that in. The chips are socketed so no soldering. https://console5.com/store/atari-5200-4-port-bios.html Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4404030 Share on other sites More sharing options...
EpikalPuppy Posted December 4, 2019 Author Share Posted December 4, 2019 17 minutes ago, Greg2600 said: Can't find a rom here but most fullsets out there have variants, and the hacks will usually read this way: [h1] (Two Port) In re-reading the OP's issues, this was not his major problem. Sounds like something else (dirty or faulty). I definitely agree that something is faulty. I cleaned the cartridge connector with a toothbrush and IPS, and same with the carts. They work on my other two port just fine. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4404031 Share on other sites More sharing options...
+cjherr Posted December 4, 2019 Share Posted December 4, 2019 1 hour ago, Greg2600 said: Another option is just get a "4-port" bios and slot that in. The chips are socketed so no soldering. https://console5.com/store/atari-5200-4-port-bios.html Excellent. Thank you. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4404103 Share on other sites More sharing options...
BIGHMW Posted December 5, 2019 Share Posted December 5, 2019 8 hours ago, Greg2600 said: Can't find a rom here but most fullsets out there have variants, and the hacks will usually read this way: [h1] (Two Port) In re-reading the OP's issues, this was not his major problem. Sounds like something else (dirty or faulty). It was simply made because I DO happen to have all 3 hacks (one for each game) and I was about to (at the time) bring that up, and maybe share with fellow 2-port 5200 owners with Atarimax Multicarts so they can play those three great titles too. ...and, yes, just now I read the quoted yes his problem was not related, thanks. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4404313 Share on other sites More sharing options...
0078265317 Posted December 11, 2019 Share Posted December 11, 2019 (edited) So I found a cheap copy of Pitfall 1 with box. One of the three that is not supposed to work. Did not boot in my 2 port. So what exactly is supposed to happen? Mine is just black screen. No audio or video. Is that how its supposed to be? Or does it boot and then glitches while playing? Or hangs while trying to boot? Shouldn't I at least get the atari logo trying to load? Edited December 11, 2019 by 0078265317 Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4408360 Share on other sites More sharing options...
SoundGammon Posted December 11, 2019 Share Posted December 11, 2019 Here's a before and after pic of the text change: Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4408388 Share on other sites More sharing options...
EpikalPuppy Posted December 11, 2019 Author Share Posted December 11, 2019 8 minutes ago, SoundGammon said: Here's a before and after pic of the text change: That’s really cool! Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-4408396 Share on other sites More sharing options...
+bent_pin Posted January 12 Share Posted January 12 On 12/3/2019 at 6:47 PM, SoundGammon said: I have a custom 4-port OS chip that changes the text / font to a computer style that I can make you a copy and put in yours! Can you share the rom file for this, please? I can burn it myself. Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-5386905 Share on other sites More sharing options...
baktra Posted January 12 Share Posted January 12 (edited) Is there an image of the 2-port BIOS ROM somewhere? I have been looking for a while, but all I found is the BIOS ROM for the 4-port models. Edited January 12 by baktra Quote Link to comment https://forums.atariage.com/topic/299147-certain-games-dont-work-on-two-port-5200/#findComment-5386926 Share on other sites More sharing options...
