Going into Action! - A noob perspective
6 hours ago, svhovater said:
so, funkheld, I realize this is an old topic, but I'm learning action! too.
I note that somewhere I read that in order to produce a standalone binary, the statement
BYTE RTS=[$60]
had to be before I include the runtime.act.
My question is.. why?
thanks
Steve
The reason for the BYTE rts=[$60] statement is due to the fact that the Action! cartridge writes the binary file and then appends the INIT vector ($02E2/$02E3] as the run address for the file. The problem arises that some DOS versions (Sparta for one, and I think DOS XL) do a JSR to the first segment loaded if there is no RUN [$02E0/$02E1] address supplied. This usually is a JSR into data rather than code, and bad things often happen in those cases. So by coding the rts statement you ensure that a call to the loading address simply returns to the caller, rather than maybe formatting your hard disk partition.
  • Thanks 2
@Alfred I don't notice that problem, if your explanation it's true why BYTE rts=[$60] is required not only [$60]?
Can you give code example where RTS helps in practice? Any piece of code that works on Sparta with this declaration but doesn't work without?
Edited by zbyti
code example
I checked this out. Works fine on SpartaDOS.
SET $E=$2000
SET $491=$2000
BYTE ARRAY
  DL=[$70$70$70$56$C$20$41$1$20],
  TEXT="NNNNNNNNNNNNNNNNNNNNNNwithout@rtsNNNNNNNNNNNNNNNNNNNNNN"
BYTE
  RTCLOCK=$14,
  CH=$2FC,
  HSCROL=$D404
CARD SDLSTL=$230
INCLUDE "H6:RUNTIME.ACT"
PROC WAIT(BYTE FRAMES)
  FRAMES==+RTCLOCK
  WHILE FRAMES#RTCLOCK DO OD
RETURN
PROC MAIN()
  BYTE I=$CA
  SDLSTL=DL
  WHILE CH=$FF DO
    I=8
    WHILE I DO
      I==-1
      HSCROL=I
      WAIT(1)
    OD
    DL(4)==+1
    IF DL(4)=$23+$C THEN DL(4)=$C FI
  OD
  GRAPHICS(0)
RETURN
MAIN.ACT RUNTIME.ACT test.atr
Jump in the end of the DL to $2001 is my mistake (my first attempts) but it doesn't matter.
Edited by zbyti
screenshot
[$60] is not a valid statement. Byte rts=[$60] is a short way to put the $60 opcode at the start of the file. You tested with Sparta 2.3 or 3.2D, right?
Yes you right, out of the proc body [$60] will not produce RTS this must be some variable declaration.
with x hscroll.com and without x, in my Action! project I use Exomizer - works with SpartaDOS
SCRAMBLE.XEX
Edited by zbyti
Exomizer
@Alfred you refer to this https://atariwiki.org/wiki/Wiki.jsp?page=Action Bugsheet#section-Action+Bugsheet-20..COMPROGRAMS
Quote
Running compiled ACTION! programs as .COM files under OS/A+ causes those programs to execute twice.
Affects: All versions, but only when using a version of OS/A+. DOS XL is not affected.
Fix: Insert the following as the first global variable you declare:
    BYTE RTS=[$60]
    ; This MUST be the first line in your program,
    ; aside from comments and SET commands.
I'll check it. This states that only OS/A+ have this issue.
Edited by zbyti
OS/A+
On 7/17/2020 at 4:22 PM, zbyti said:
@pedgarcia If you are interested in it and it will be useful in your tutorial I included some tricks in my code that I saw or discovered on my own https://github.com/zbyti/a8-action-scramble
Hey @zbyti, thanks! That is a very organized code (compared to mine so far!) . I noticed that you have a module with low-level routines and some of them are part of Action! standard library (not sure if that is the correct term). Why did you do that? Was to have more efficient code, or simply to have only what you would need?
I haven't had a chance to run it yet, but I will dig deeper tomorrow. That will be very useful.
Cheers
For 3 reasons:
1. to save memory by picking exactly what I need from runtime
2. to make binary (xex file) working without cartridge
3. speed
I use one of those runtimes (I belie von Jeff Reister was the one) but noticed what SETBLOCK procedure is 3x slower then PROC on Action! cartridge, I'll fix this later.
Edited by zbyti
SETBLOCK info
@pedgarcia I only compile code using Atari800 but I'm writing the code outside Action! env. It's looks (early version) this way:
I think this way I can use more variables on ZERO PAGE (>= $80) because I don't have to worry about the correct work of the Action! editor after running my own code.
Edited by zbyti
>= $80
Hey @zbyti, it looks great! I've been using Action! editor (full immersion :) ) and I found it excellent, even for today's standards, but the Atari's 40 columns display doesn't help much to visualize the code. I will try to get going something similar you showed in your video using an external editor.
Another point I wasn't thinking is the amount of memory the editor and the code would take. My current game is very small so that's ok, but at some point I can see things will start to get more complicated to manage.
Thanks!
  • 1 month later...
  • 2 weeks later...
17 hours ago, DocSavage2001 said:
Yes, good stuff. I will need to pull that image for Action! in your first tutorial. I just picked up an 800 with Basic, Logo and Mac/65 and I need to have Action! too! :)
Dave
Thanks. The first article contains a link to an image I created for the series. It is nothing fancy but this way I can point to folders or specific things without thinking on different types of images, etc.
Cheers
