Can someone explain setting up Arrays?
eddhell
I've read nanochess' book over and over, and I am just not understanding how to fill an array with specified data from a DATA statement.  I know you can use a For...next loop as a counter to "fill" the array, but I don't understand how to point the array to the specific DATA statements I want to use.
ok, so basically, I'm trying to fill an array with 10 preset numbers.  Here's the only way I could get it to work so far:
   DIM sqx(10)
read_array:
    RESTORE sqx
    FOR x = 0 to 9
      READ sqx(x)
    NEXT x
sqx:
    DATA 24,24,96,144,144,80,24,32,24,32
.....and it SEEMS to work fine.  BUT -When I try to add another array, how do I point it to another section of DATA?  Here's what I tried and it didn't work:
    DIM sqx(10)
    DIM sqy(10)
read_array:
    RESTORE sqx
    RESTORE sqy
    FOR x = 0 to 9
      READ sqx(x)
      READ sqy(x)
    NEXT x
sqx:
sqy:
    DATA 64,16,32,24,80,72,56,64,24,16
there's something i'm just not getting with this...does the label before the DATA have to match the array name?  or is it all DATA statements read in sequential order?
I thought restore only pointed to one set of data statements, although it is not a command I typically use.
You could do something like this instead to store the contents of the two tables into two separate arrays:
  DIM sqx(10)
    DIM sqy(10)
read_array:
    FOR x = 0 to 9
      sqx(x) = table_x(x)
      sqy(x) = table_y(x)
    NEXT x
table_x:
table_y:
