DASM - New home and new releases!
Dionoid
DASM has moved to github!
The dasm-dillon repository has left SourceForge and moved over to GitHub here: https://dasm-assembler.github.io/
The new home on GitHub is the official single point where the latest version of DASM is maintained and distributed.
The DASM team
These are the people that currently maintain DASM and contribute to its development in one way or the other: The DASM team
Get the latest DASM version
Bugs? Feature requests?
Please report bugs or feature requests on https://github.com/dasm-assembler/dasm/issues.
All versions of DASM are written in C. If you want to contribute, we encourage you send us a pull request!
Building a better DASM together.
Edited by Dionoid
  • Like 15
  • 1 month later...
  • The topic was pinned
  • 4 weeks later...
Just a heads-up that we've put out the 2.20.13 release of dasm. Quoth the github release notes... (thanks Dionoid!)
Quote
This is version 2.20.13 of DASM. It is mainly a bugfix release.
Short summary of fixes:
  • Longstring segfault fix
  • Fix for non-symbol-compliant unquoted filenames
  • Address expression fix
  • Makefile portability fixes
  • Added atari 7800 header files
  • Allow labels to shift between multiple passes
  • Fix for silenced single pass non-abort errors
  • Adjust .byte and .word negative range check
  • Duplicate macro fix
  • Reduce gcc Wall option build warnings
  • Added 'strict' syntax check mode (+ added to docs)
  • Enable .word size check for strict-mode only
  • Dynamic buffers for pass-output update
Console-specific header files and common macros are included for:
  • Atari 2600 VCS
  • Atari 7800 (new!!)
  • Fairchild Channel F VES
  • Like 5
  • 3 weeks later...
  • Atari 2600 VCS
I have some old Atari 800 games I wrote in the 80s with Atari Macro Assembler... Would be nice if DASM could process those... I'm hoping that if I provide the system headers, that would work? Not ready to do that yet, but I could see doing it later this year.
  • 4 weeks later...
  • 3 weeks later...
Quotes works for me in Linux...
dasm "test space.asm" -f3 -o"test space.bin"
As does using \ to escape the space...
dasm test\ space.asm -f3 -otest\ space.bin
I believe that functionality is up to the command shell (bash in my case). What's the function call you're using to execute dasm?
Re-looking at the args now I wasn't quoting the list or symbol file names.  Played around with everything else as you have shown but missed those further down! Arrrrr ??
Thanks for replying Mike!
  • 4 months later...
I had a quick question about DASM just now and Googled up the documentation.
Holy moly! What a huge difference! The current documentation is AMAZING, especially compared to the charmingly scruffy, but not-so-up-to-date, text file of yore.
Kudos to whomever has been doing what must be quite a bit of work. (Andrew, maybe?)
Yep, that's my work. Thanks for the acknowledgement.
I'm working on the 6502 illegal opcodes support at the moment. I'm very much surprised how many there are, what addressing modes are available and how many of them dasm supports natively. I even found one that needs to be added.
More to come - I hope to make the manual quite comprehensive.
By the way, thanks for supporting Mac OS with pre-compiled versions!
I'm currently exploring the best path forward with a bunch of projects I'd done in the 80s with Atari Macro Assembler...
ie, compiling in an emulator with AMAC vs updating code-base to compile with DASM or ca65.
I picked one of my very small projects (5 pages source) and am trying each of those 3 paths before moving on to my much larger games.
