Swami Posted January 29, 2020 Share Posted January 29, 2020 14 minutes ago, Ikrananka said: Nope, it's not the key mapping. In CoolCV the game accepts my asterisk press, using the mapped key, and does move the game from the menu screen to the actual game play screen. It's at this point where the game appears to lock up and white (engine) noise appears. No joystick fire button or keypad press has any effect at this point. CoolCV, ColEm and blueMSX all have the same issue. Can you move the CAT around? I just played a couple quick games and didn’t see the need for button presses after reaching the game screen. I’ll check the instructions tonight. Can you see if keyboard only works with CoolCV? Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted January 29, 2020 Share Posted January 29, 2020 2 minutes ago, Swami said: Can you move the CAT around? I just played a couple quick games and didn’t see the need for button presses after reaching the game screen. I’ll check the instructions tonight. Can you see if keyboard only works with CoolCV? Nope - can't move the CAT around - the game is totally frozen (screenshot attached). I get exactly the same with ColEm and blueMSX. No need to check the instructions, I can play the game fine on a real CV and on the Phoenix. It's just bizarre the way so far all emulators can't play the game (at least for me anyway). I've even dumped the cart to verify the ROM and it's good - can play using an AtariMax and Phoenix via SD with the ROM and it works perfectly. Quote Link to comment Share on other sites More sharing options...
H.E.R.O. Posted January 29, 2020 Share Posted January 29, 2020 3 hours ago, Ikrananka said: Nope, it's not the key mapping. In CoolCV the game accepts my asterisk press, using the mapped key, and does move the game from the menu screen to the actual game play screen. It's at this point where the game appears to lock up and white (engine) noise appears. No joystick fire button or keypad press has any effect at this point. CoolCV, ColEm and blueMSX all have the same issue. I'd like to add that vdmgr64 also has the same issue. Quote Link to comment Share on other sites More sharing options...
Swami Posted January 31, 2020 Share Posted January 31, 2020 On 1/29/2020 at 9:08 AM, Ikrananka said: Nope - can't move the CAT around - the game is totally frozen (screenshot attached). I get exactly the same with ColEm and blueMSX. No need to check the instructions, I can play the game fine on a real CV and on the Phoenix. It's just bizarre the way so far all emulators can't play the game (at least for me anyway). I've even dumped the cart to verify the ROM and it's good - can play using an AtariMax and Phoenix via SD with the ROM and it works perfectly. On 1/29/2020 at 12:07 PM, H.E.R.O. said: I'd like to add that vdmgr64 also has the same issue. I think I've found your problem. It works fine in CoolCV 6.2 and CoolCV 6.5 (didn't check in between), but not in CoolCV 6.6. Must be a bug in latest CoolCV version or something. I wonder if it affects other games. I was originally using 6.2 and it worked fine, but then updated to 6.6 and it was like you said. Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted January 31, 2020 Share Posted January 31, 2020 10 hours ago, Swami said: I think I've found your problem. It works fine in CoolCV 6.2 and CoolCV 6.5 (didn't check in between), but not in CoolCV 6.6. Must be a bug in latest CoolCV version or something. I wonder if it affects other games. I was originally using 6.2 and it worked fine, but then updated to 6.6 and it was like you said. Very interesting - thanks for narrowing this down. I'll contact nanochess to ask if he has an idea of what the problem is. Quote Link to comment Share on other sites More sharing options...
alekmaul Posted February 1, 2020 Share Posted February 1, 2020 (edited) The pb is the way the memory is init. I got same problem with EMulTwo. If you init all the Coleco memory with 0, it can't run, but if it is another value (0xFF is fine), it works (for memory between 0 and 0x8000). Perhaps Oscar changed the way he initializes memory in last version. Edited February 1, 2020 by alekmaul Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted February 1, 2020 Share Posted February 1, 2020 4 hours ago, alekmaul said: The pb is the way the memory is init. I got same problem with EMulTwo. If you init all the Coleco memory with 0, it can't run, but if it is another value (0xFF is fine), it works (for memory between 0 and 0x8000). Perhaps Oscar changed the way he initializes memory in last version. Thank you for identifying the problem. Oscar did say that he changed the pattern of memory initialisation in the last version of CoolCV so that is likely the culprit there. He's looking into it so I'm hoping he'll have time to release an updated version of CoolCV that fixes this. Quote Link to comment Share on other sites More sharing options...
ChuckH Posted February 5, 2020 Share Posted February 5, 2020 The game does work on Virtual Adam emulator. (ColEm) Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted February 5, 2020 Share Posted February 5, 2020 2 minutes ago, ChuckH said: The game does work on Virtual Adam emulator. (ColEm) Which one do you mean? Virtual ADAM or ColEm? Quote Link to comment Share on other sites More sharing options...
ChuckH Posted February 5, 2020 Share Posted February 5, 2020 15 minutes ago, Ikrananka said: Which one do you mean? Virtual ADAM or ColEm? oops, I meant to say AdamEm which is part of Virtual ADAM Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted February 5, 2020 Share Posted February 5, 2020 5 minutes ago, ChuckH said: oops, I meant to say AdamEm which is part of Virtual ADAM Good to know - thanks for the info. Quote Link to comment Share on other sites More sharing options...
ChuckH Posted February 5, 2020 Share Posted February 5, 2020 4 hours ago, Ikrananka said: Good to know - thanks for the info. Works in the emulator MESS as well. At least in the version that I have that is quite old. Quote Link to comment Share on other sites More sharing options...
MadZiontist Posted February 5, 2020 Share Posted February 5, 2020 Aww, too bad membership is closed. It's impossible to keep up with stuff like this. 1 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted February 14, 2020 Share Posted February 14, 2020 On 1/26/2020 at 11:40 PM, Swami said: Weren't we supposed to receive a ROM of the 2019 secret game? Is this true? Unless I missed it, this question didn’t get answered. ? Quote Link to comment Share on other sites More sharing options...
retroillucid Posted February 14, 2020 Author Share Posted February 14, 2020 2 minutes ago, sramirez2008 said: Is this true? Unless I missed it, this question didn’t get answered. ? Yes, the 2019 rom file should have been sent by now I would need to confirm with Toby 2 1 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted February 14, 2020 Share Posted February 14, 2020 Just now, retroillucid said: Yes, the 2019 rom file should have been sent by now I would need to confirm with Toby Thanks. Will it come to each of the 2020 members individually or be made available on-site? Quote Link to comment Share on other sites More sharing options...
retroillucid Posted February 14, 2020 Author Share Posted February 14, 2020 10 minutes ago, sramirez2008 said: Thanks. Will it come to each of the 2020 members individually or be made available on-site? I would say, individually 1 Quote Link to comment Share on other sites More sharing options...
MMarcoux66 Posted February 14, 2020 Share Posted February 14, 2020 25 minutes ago, retroillucid said: I would say, individually 37 minutes ago, retroillucid said: Yes, the 2019 rom file should have been sent by now I would need to confirm with Toby ...and if the 2019 members wish to share it they can? If so, I would be grateful if someone would share it with me :). Quote Link to comment Share on other sites More sharing options...
retroillucid Posted February 14, 2020 Author Share Posted February 14, 2020 2 minutes ago, MMarcoux66 said: ...and if the 2019 members wish to share it they can? If so, I would be grateful if someone would share it with me :). Yes, members are free to share the rom file All we ask is to keep it ''low profile'' 3 Quote Link to comment Share on other sites More sharing options...
H.E.R.O. Posted February 14, 2020 Share Posted February 14, 2020 8 hours ago, retroillucid said: Yes, the 2019 rom file should have been sent by now I would need to confirm with Toby I can confirm I have yet to receive it. Quote Link to comment Share on other sites More sharing options...
zyzzle Posted February 16, 2020 Share Posted February 16, 2020 I also have yet to receive the ROM file. Will it be sent to the same e-mail address as other club mailings? I would assume so. Quote Link to comment Share on other sites More sharing options...
H.E.R.O. Posted February 24, 2020 Share Posted February 24, 2020 So what's the status of this year's packages going out and will we receive the rom file a reasonable amount of time after shipment? Quote Link to comment Share on other sites More sharing options...
retroillucid Posted February 24, 2020 Author Share Posted February 24, 2020 1 hour ago, H.E.R.O. said: So what's the status of this year's packages going out We need to get the overlays printed Having the PCBs manufactured (some delay due to the coronavirus) 1 hour ago, H.E.R.O. said: will we receive the rom file a reasonable amount of time after shipment? Yes, definitely! You won't have to wait till the end of the year to get the rom file Quote Link to comment Share on other sites More sharing options...
H.E.R.O. Posted February 24, 2020 Share Posted February 24, 2020 3 minutes ago, retroillucid said: We need to get the overlays printed Having the PCBs manufactured (some delay due to the coronavirus) Yes, definitely! You won't have to wait till the end of the year to get the rom file Thanks for the update, retro! Looking forward to the new game arriving. Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted March 10, 2020 Share Posted March 10, 2020 (edited) Hey, Collectorvision, is the 2020 Secret Game still planned to be shipped this month? Edited March 10, 2020 by lucifershalo Quote Link to comment Share on other sites More sharing options...
