bluejay Posted December 27, 2019 Share Posted December 27, 2019 I've been using AA batteries for my Tandy cassette recorder, just because AAs fit and Cs are expensive and I don't have any laying around. Now, I've got a Hanimex 777 pong clone console that requires 6 C batteries. Anyways, is it okay to use AAs instead of Cs? Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted December 27, 2019 Share Posted December 27, 2019 Yes, they just won't last as long. 1 Quote Link to comment Share on other sites More sharing options...
bluejay Posted December 27, 2019 Author Share Posted December 27, 2019 So the only difference is size and how long it lasts? Quote Link to comment Share on other sites More sharing options...
doubledown Posted December 27, 2019 Share Posted December 27, 2019 Correct, all standard alkaline batteries D, C, AA, AAA are 1.5VDC (nominal), but the larger the battery physically, the more mAh of current it has, thus the longer it will last. The only potential problem you would see would be with re-chargable cells (NiCad, NiMh) as these are only 1.2VDC (nominal). So if a device took 6 batteries...6 alkalines would provide 9VDC, whereas the rechargables would only provide 7.2VDC. Depends how sensitive the device is, and how much power it really needs internally to whether or not it would work properly with rechargables or not. Quote Link to comment Share on other sites More sharing options...
Deteacher Posted December 28, 2019 Share Posted December 28, 2019 I was in my local Rite Aid just yesterday, buying some C batteries and they have D size adapters so you can use AA batteries in devices that normally use D size batteries. Million dollar idea! Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted December 28, 2019 Share Posted December 28, 2019 (edited) 2 hours ago, Deteacher said: I was in my local Rite Aid just yesterday, buying some C batteries and they have D size adapters so you can use AA batteries in devices that normally use D size batteries. Million dollar idea! I had those adapter shells back in the 70s and they were probably being sold long before that. AA to D is next to worthless since most anything using D cells will be high current drain...the mAh difference is too great. The C to D adapters were ok and I wish I could still find them, as someone gave me boxes and boxes of Duracell Procell C batteries made for medical equipment. Edited December 28, 2019 by Turbo-Torch 1 Quote Link to comment Share on other sites More sharing options...
Deteacher Posted December 28, 2019 Share Posted December 28, 2019 20 minutes ago, Turbo-Torch said: I had those adapter shells back in the 70s and they were probably being sold long before that. AA to D is next to worthless since most anything using D cells will be high current drain...the mAh difference is too great. The C to D adapters were ok and I wish I could still find them, as someone gave me boxes and boxes of Duracell Procell C batteries made for medical equipment. That's funny that they've been around since then. I had never seen one until yesterday, and I was born in 1970. LOL! I knew about the trick to using AAA batteries where AA was required by using tin foil, though. Quote Link to comment Share on other sites More sharing options...
doubledown Posted December 28, 2019 Share Posted December 28, 2019 Take it for what's it worth, but Wikipedia lists these as the typical mAh values for the following Alkaline battery sizes: AAA - 1,200 AA - 2,700 C - 8,000 D - 12,000 Remember old "portable" boomboxes that use to take up to 12 D batteries for power. The good old days. 2 Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted December 28, 2019 Share Posted December 28, 2019 I suspect that battery size has something to do with max current draw too. Also, batteries lose max capacity at larger draws, and larger batteries are likely more resistant to that. 1 Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted December 28, 2019 Share Posted December 28, 2019 Sanyo Eneloops, which were (and may well still be) considered the best rechargeable batteries, come with C and D cell adapters to hold their standard AA size batteries. I think they're just spacers, not doing anything with current. So as others have said, I think the answer is yes that's fine, and if you wanted to be more economical about it, I recommend these brand of batteries. 2 Quote Link to comment Share on other sites More sharing options...
doubledown Posted December 28, 2019 Share Posted December 28, 2019 1 hour ago, Flojomojo said: Sanyo Eneloops, which were (and may well still be) considered the best rechargeable batteries, come with C and D cell adapters to hold their standard AA size batteries. I think they're just spacers, not doing anything with current. So as others have said, I think the answer is yes that's fine, and if you wanted to be more economical about it, I recommend these brand of batteries. I got a set of those (AAs) to try and they work pretty well. I would just note that I remember they have at least 2 different series of these batteries. I believe the white ones have a lower mAh rating, but are supposedly good for 1500+ charging cycles, but the black ones, while they have a higher mAh rating (made for high current draw digital cameras/flashes and the likes) are only rated for something like 500+ charging cycles. So trade off between capacity and lifespan. I chose the white ones for my purposes. Pretty good deals of these can be found on Amazon. 2 Quote Link to comment Share on other sites More sharing options...
