gpaJeb Posted January 3, 2020 Share Posted January 3, 2020 3 hours ago, senior_falcon said: Does anyone have any insight in how to accomplish what Wolfgang wants to do? Specifically take XBGEM_G.BIN and XBGEM_8.BIN and load them into the final grom. It looks like BINs for the final grom are all in one file. How do you load these into classic99 ? Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 3, 2020 Share Posted January 3, 2020 19 minutes ago, gpaJeb said: How do you load these into classic99 ? CARTRIDGE - USER - Select the G file.. Greg Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 3, 2020 Share Posted January 3, 2020 48 minutes ago, arcadeshopper said: Seems to work Sent from my LM-G820 using Tapatalk well it loads XB+ ok..but all the overlays don't seem to work.. screen doesn't turn yellow in T40 like it does in classic99 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 3, 2020 Author Share Posted January 3, 2020 You need 32K, which I assume you have. The loader determines if you don't have 32K and if it is not there it just defaults to XB+ (with no error message) 1 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 3, 2020 Share Posted January 3, 2020 Nope lemme turn that onSent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 3, 2020 Author Share Posted January 3, 2020 25 minutes ago, arcadeshopper said: CARTRIDGE - USER - Select the G file.. Greg Before you do that you must copy the two files into the CART folder. Then you click on "cartridge", then "user" and the files should be there. 1 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 3, 2020 Share Posted January 3, 2020 You need 32K, which I assume you have. The loader determines if you don't have 32K and if it is not there it just defaults to XB+ (with no error message) DUH turn on the pbox Greg Works! Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 3, 2020 Author Share Posted January 3, 2020 3 minutes ago, arcadeshopper said: DUH turn on the pbox Greg Works! These things happen... Only thing is, they seem to happen to me more and more these days. 1 Quote Link to comment Share on other sites More sharing options...
majestyx Posted January 3, 2020 Share Posted January 3, 2020 Quick question for Harry: If I want to autoload my program that is using T40XB, how would this be done, if at all? I know that I need to change T40XB to use the filename LOAD (as listed in your documentation), but then how would I load the next program file automatically? I want the next program to load to be the Title Screen which will either load instructions or run the main program. It doesn't look like I can add a line to T40XB that would run the title screen program since I believe it's compiled program code. Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 3, 2020 Share Posted January 3, 2020 19 minutes ago, majestyx said: Quick question for Harry: If I want to autoload my program that is using T40XB, how would this be done, if at all? I know that I need to change T40XB to use the filename LOAD (as listed in your documentation), but then how would I load the next program file automatically? I want the next program to load to be the Title Screen which will either load instructions or run the main program. It doesn't look like I can add a line to T40XB that would run the title screen program since I believe it's compiled program code. T40xb isn't compiled is it? autoload will run LOAD then add a RUN "DSKX.WHATEVER" to run the next bit 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 3, 2020 Author Share Posted January 3, 2020 30 minutes ago, majestyx said: Quick question for Harry: If I want to autoload my program that is using T40XB, how would this be done, if at all? I know that I need to change T40XB to use the filename LOAD (as listed in your documentation), but then how would I load the next program file automatically? I want the next program to load to be the Title Screen which will either load instructions or run the main program. It doesn't look like I can add a line to T40XB that would run the title screen program since I believe it's compiled program code. There are two answers to your question, depending on how you are using T40XB. 1 - If you are using T40XB from the G.E.M. cartridge, then you would select T40XB at the master title screen. Then if your menu program is named LOAD, it will load and run automatically 2 - If you want to use the disk based version of T40XB then you would rename T40XB to LOAD. Then you would add a line to the LOAD program (which is T40XB) so that your title screen program is loaded and from there you can select instructions or the main program. The T40XB program is simply a loader that copies the embedded T40 code into low memory and then starts it up. If I remember right, line 10 has something like CALL LINK("X") which copies the T40XB code to low memory, then CALL LINK("T40ON") will start it. I think you need to have RUN "DSK1.MYMENU" in line 10. 1 Quote Link to comment Share on other sites More sharing options...
majestyx Posted January 3, 2020 Share Posted January 3, 2020 Okay, I *was* using the disk based version with XB 2.7 Suite in Classic99. But now that I'm using the cartridge, this makes it a lot easier. Here was my thinking in regard to not being able to add lines: When I load your T40XB, I see only 2 lines (similar to my compiled Grail of the Gods), but the size on "diskette" is much larger than 2 lines, which is why I didn't think I could add any additional lines to it. I didn't think if I'd save it back to disk that it would include the embedded code, but apparently it does. Good to know! Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 3, 2020 Author Share Posted January 3, 2020 One thing to keep in mind is this: Don't - I repeat - DO NOT resequence the program. XB can get into the embedded code and make changes to it when it thinks it has found a line number. Quote Link to comment Share on other sites More sharing options...
gpaJeb Posted January 3, 2020 Share Posted January 3, 2020 4 hours ago, senior_falcon said: Before you do that you must copy the two files into the CART folder. Then you click on "cartridge", then "user" and the files should be there. [usercart88] ; *** XB GEM - works name="XB GEM" rom0=G|6000|A000|MODS\XBGEM_G.BIN rom1=C|6000|2000|MODS\VBGEM_8.BIN I did the above, it does put it on the menu, I select any one of the items and it loads but the xb * just blinks on and off. Quote Link to comment Share on other sites More sharing options...
DavidC Posted January 4, 2020 Share Posted January 4, 2020 (edited) 7 hours ago, gpaJeb said: How do you load these into classic99 ? Cartridge>User>Open>Navigate to the folder where you have the two .bin files stored>click on XBGEM_G.BIN . Thats what works for me. Edited January 4, 2020 by DavidC Quote Link to comment Share on other sites More sharing options...
DavidC Posted January 4, 2020 Share Posted January 4, 2020 (edited) 2 hours ago, gpaJeb said: [usercart88] ; *** XB GEM - works name="XB GEM" rom0=G|6000|A000|MODS\XBGEM_G.BIN rom1=C|6000|2000|MODS\VBGEM_8.BIN I did the above, it does put it on the menu, I select any one of the items and it loads but the xb * just blinks on and off. Also..you have typo on rom1..VBGEM..if that is a copy and paste into your message. Edit: I tried it this way, with the typo fixed and the cart crashed when I tried using it...but when I navigate to the files like I mentioned above it works fine. Edited January 4, 2020 by DavidC Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 4, 2020 Share Posted January 4, 2020 Also..you have typo on rom1..VBGEM..if that is a copy and paste into your message. Edit: I tried it this way, with the typo fixed and the cart crashed when I tried using it...but when I navigate to the files like I mentioned above it works fine.ROM is bigger than that I thinkSent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 4, 2020 Author Share Posted January 4, 2020 (edited) I have my cartridges in a folder named CARTS. Here XBGEM is shown. If you go to Cartridge>User>Open this will show up and you can click on either file and it should start up properly. Once it is in CARTS or another folder you have the option of adding it to Classic99's .ini file. Here is the entry for XBGEM [usercart1] (I have another cart which is usercart0) name=XB G.E.M rom0=G|6000|A000|CARTS\XB27GEM_G.BIN (load >A000 bytes to grom starting at >6000. Cartridge groms start at >6000 You know it is >A000 bytes because the length is 40KB) rom1=8|0000|4000|CARTS\XB27GEM_8.BIN (load >4000 bytes to cartridge rom starting at the beginning of bank 0. You know it is >4000 bytes because the length is 16KB) By adding this to the .ini file this automatically shows up when you click Cartridge>User. You don't have to open anything. Also, if it is in the .ini file you can close Classic99 and when you open it again the cartridge will already be loaded. (Edit) - Also, you may need to restart Classic99 for the .ini change to take effect. Edited January 4, 2020 by senior_falcon 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 4, 2020 Author Share Posted January 4, 2020 XB 2.8 G.E.M. is coming along nicely. The randomize bug is fixed. DM1000 is available from the menu screen and I will probably make a CALL DM1000 to start it up from XB. Adding some additional routines to The Missing Link is next on the agenda. This will take some time as I figure out how to do it. There are 30 fonts available using CALL FONT(N) and I think going beyond that would be excessive. 20 of them are from the TMLFONTS disk. I picked my favorites from the roughly 80 fonts on the disk. Still, many of them seem like filler to me, and most of them use small capital letters for lower case. If anyone has a favorite font they think should be included send it to me and I'll take a look. I am thinking of fancy fonts for games; there probably are enough standard fonts for everyday use. Still, if someone wanted the Apple2 font or C64 font, send it along too. 3 Quote Link to comment Share on other sites More sharing options...
Tursi Posted January 4, 2020 Share Posted January 4, 2020 On 1/3/2020 at 9:54 AM, arcadeshopper said: CARTRIDGE - USER - Select the G file.. Don't know if anyone noticed I added drag and drop a while ago - you can also just drag one of the files to the Classic99 window instead of using the menu 3 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 4, 2020 Share Posted January 4, 2020 Don't know if anyone noticed I added drag and drop a while ago - you can also just drag one of the files to the Classic99 window instead of using the menu Thanks!Sent from my LM-G820 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
gpaJeb Posted January 5, 2020 Share Posted January 5, 2020 [usercart1] (I have another cart which is usercart0) name=XB G.E.M rom0=G|6000|A000|CARTS\XB27GEM_G.BIN (load >A000 bytes to grom starting at >6000. Cartridge groms start at >6000 You know it is >A000 bytes because the length is 40KB) rom1=8|0000|4000|CARTS\XB27GEM_8.BIN (load >4000 bytes to cartridge rom starting at the beginning of bank 0. You know it is >4000 bytes because the length is 16KB) I did as shown above and it works, THANK YOU 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 5, 2020 Author Share Posted January 5, 2020 2 hours ago, gpaJeb said: [usercart1] (I have another cart which is usercart0) name=XB G.E.M rom0=G|6000|A000|CARTS\XB27GEM_G.BIN (load >A000 bytes to grom starting at >6000. Cartridge groms start at >6000 You know it is >A000 bytes because the length is 40KB) rom1=8|0000|4000|CARTS\XB27GEM_8.BIN (load >4000 bytes to cartridge rom starting at the beginning of bank 0. You know it is >4000 bytes because the length is 16KB) I did as shown above and it works, THANK YOU Just passing on what Tursi taught me a few weeks ago. Glad that it works for you. This can be pretty bewildering when you are getting started. 1 Quote Link to comment Share on other sites More sharing options...
+wolhess Posted January 5, 2020 Share Posted January 5, 2020 On 1/3/2020 at 4:07 PM, senior_falcon said: @Wolfgang: It sounds like you can make this work by simply changing XBGEM_8.BIN to XBGEM_C.BIN Give that a try and report the results. Just remember that Classic99 wants it to be _8. If you use _C then only one bank of rom is loaded. Hi Senior_Falcon, yes, it works on my real TI with changing it to _C. Thank you! Thank you too to arcadeshopper for testing it 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted January 5, 2020 Share Posted January 5, 2020 Hmmm! I wonder if I could load it into my HSGPL card? Quote Link to comment Share on other sites More sharing options...
