Shawn Posted January 24, 2020 Share Posted January 24, 2020 Hey Guys, I've been looking all over the internet and have had a hard time finding any rectangular momentary push buttons in the 22x30mm size range. Anyone have a source or link to buy some please? I only need a pair of them. Hoping for low profile but beggars can't be choosers obviously. Something like this pictured below would be perfect in single or double pole with a single momentary throw with normally open contacts. A few mm wider and longer in size would be ok too. Thanks, Shawn Quote Link to comment https://forums.atariage.com/topic/301036-spst-or-dpst-22x30mm-momentary-push-button/ Share on other sites More sharing options...
emerson Posted January 25, 2020 Share Posted January 25, 2020 This is the closest I could find: https://www.mouser.com/ProductDetail/Marquardt-Switches/16653102?qs=fgTiLP%2BNGFvgj%2BQmHnPNbg%3D%3D It recommends a 22mm x 30mm panel cutout. The actuator cap is illuminated green but you don't need to illuminate it. Don't know if that will be an issue or not. 1 Quote Link to comment https://forums.atariage.com/topic/301036-spst-or-dpst-22x30mm-momentary-push-button/#findComment-4440751 Share on other sites More sharing options...
emerson Posted January 25, 2020 Share Posted January 25, 2020 I believe this is the same but non-illuminated: https://www.alliedelec.com/product/marquardt-switches/1663-0101/70458884/ 1 Quote Link to comment https://forums.atariage.com/topic/301036-spst-or-dpst-22x30mm-momentary-push-button/#findComment-4440755 Share on other sites More sharing options...
Shawn Posted January 25, 2020 Author Share Posted January 25, 2020 56 minutes ago, emerson said: I believe this is the same but non-illuminated: https://www.alliedelec.com/product/marquardt-switches/1663-0101/70458884/ Thanks for looking. That is almost exact to what I want. Now if I could find some that are not $10 each that would be even better Quote Link to comment https://forums.atariage.com/topic/301036-spst-or-dpst-22x30mm-momentary-push-button/#findComment-4440826 Share on other sites More sharing options...
ChildOfCv Posted January 25, 2020 Share Posted January 25, 2020 Panel mount switches tend to be expensive, unfortunately. They're built to survive environmental ravages. If a board mount switch is feasible, you could buy one that has a long cap, so that it can stick through the hole enough to be a pushable button. 1 Quote Link to comment https://forums.atariage.com/topic/301036-spst-or-dpst-22x30mm-momentary-push-button/#findComment-4440909 Share on other sites More sharing options...
Shawn Posted January 25, 2020 Author Share Posted January 25, 2020 3 hours ago, ChildOfCv said: Panel mount switches tend to be expensive, unfortunately. They're built to survive environmental ravages. If a board mount switch is feasible, you could buy one that has a long cap, so that it can stick through the hole enough to be a pushable button. Nah, wouldn't match with the rest of what I have going on this project. Thanks for the suggestion. Quote Link to comment https://forums.atariage.com/topic/301036-spst-or-dpst-22x30mm-momentary-push-button/#findComment-4441098 Share on other sites More sharing options...
Bratwurst Posted January 26, 2020 Share Posted January 26, 2020 In desperation I usually will cobble a switch with plastic facia/misc pieces to achieve the look I want. In my case I needed a momentary square pushbutton normally-closed. Those things are impossible to find. Had to make them. Is this project going to be a one-off or will you need multiples? Maybe look at a product that's already out there you could rob the push piece from and then mount the SPST/DPST you want behind it. Quote Link to comment https://forums.atariage.com/topic/301036-spst-or-dpst-22x30mm-momentary-push-button/#findComment-4441195 Share on other sites More sharing options...
Shawn Posted January 26, 2020 Author Share Posted January 26, 2020 4 hours ago, Bratwurst said: In desperation I usually will cobble a switch with plastic facia/misc pieces to achieve the look I want. In my case I needed a momentary square pushbutton normally-closed. Those things are impossible to find. Had to make them. Is this project going to be a one-off or will you need multiples? Maybe look at a product that's already out there you could rob the push piece from and then mount the SPST/DPST you want behind it. I'm considering that. Using a rocker and making a push top for it with a momentary NO under it. Quote Link to comment https://forums.atariage.com/topic/301036-spst-or-dpst-22x30mm-momentary-push-button/#findComment-4441344 Share on other sites More sharing options...
