NinjaWarrior Posted February 4, 2020 Share Posted February 4, 2020 I had a Intellivision II with the Original PSU I bought it back, But I don't have any PSU's to Test I heard the TurboGrafx PSU will work, But it doesn't fit Quote Link to comment Share on other sites More sharing options...
mr_me Posted February 4, 2020 Share Posted February 4, 2020 AC or DC doesn't matter, voltage doesn't matter so much but should be around 16VAC to 9VDC. Amp supply has to be enough to deliver about 10 watt or more. See what you have around the house. I've heard of computer laptop power supplies, atari 5200, atari jaguar, sega genesis power supplies working. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted February 4, 2020 Share Posted February 4, 2020 I can confirm a 5200 supply works as I've used those in the past to power my Intellivision model 2. 2 Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted February 4, 2020 Share Posted February 4, 2020 12 hours ago, -^CrossBow^- said: I can confirm a 5200 supply works as I've used those in the past to power my Intellivision model 2. I can also confirm that. It's the only power supply I've ever used with my Inty 2. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted February 4, 2020 Share Posted February 4, 2020 Yeap, although the Genesis/Jaguar supplies have the right voltage and amperage, the plug itself isn't wide enough in the center to physically fit the Intelly 2 power port. A very interesting thing to note is that I feel using a DC supply is better than the AC ones even through the console is designed to take an AC supply. I had two intelly 2 units to use for testing. On both of them, when using the actual Mattel power supply for the Intellivision 2, the transformers inside the Intelly 2 would buzz quite a bit. One did this more than the other, but they both had a very audible buzz to them. Using a 5200 or similar DC PSU in them, did NOT cause this buzzing to occur. So it would seem that using a DC supply puts less stress on the system as well. Makes you wonder why Mattel even when with an AC output supply for this model in the first place? Quote Link to comment Share on other sites More sharing options...
NinjaWarrior Posted February 4, 2020 Author Share Posted February 4, 2020 I found my Toshiba Laptop PSU Input: 100-240V 1.5A Output- 15V 4A - C + Quote Link to comment Share on other sites More sharing options...
mr_me Posted February 6, 2020 Share Posted February 6, 2020 I'm not sure how 15v dc compares to 16v ac. You might want to check that as you don't want the voltage to be too high. Quote Link to comment Share on other sites More sharing options...
