scotty Posted February 8, 2020 Share Posted February 8, 2020 Need advice. I Already have 2 X-Arcades, a Tank Stick and a 2-Player. Yes, i know the sticks and buttons suck, but that is a later project. For now I am looking at building a few dedicated controls for games that need them. I plan on a dedicated Defender/Stargate panel, a Tapper/Ice cold beer tapper and a few others. My first is going to be a combo Asteroids/Q*bert panel. Asteroids layout with a 45 degree 4way stick mounted for Qbert, Qberts Cubes, Congo Bongo etc....mounted in the middle, above the Asteroids layout. I am using leaf buttons for asteroids, and am looking for recommendations for a good stick with a SMALL ball that will mount in a 3/4" wood panel for the diagonal games. Something with a short throw just like the real machine. I am in the USA, so preferably US sellers, although i do like Iltimark. Suggestions? Quote Link to comment Share on other sites More sharing options...
doubledown Posted February 11, 2020 Share Posted February 11, 2020 (edited) It all kind of depends on how you want to mount the stick under the wood panel. A lot of old cabinets had the underside of the wood C.P. routed out for the joystick area so that it wasn't truly mounted through the full-depth (3/4") of wood...a lot of times simply through a steel panel/plate with minimal thickness. Basically all of the modern candy cabinet sticks (Sanwa, Seimitsu, and the likes), will only "work" height-wise, if this same concept is replicated, or you could use shaft extensions (assuming a threaded shaft top) which are available for 6mm threading. The original Rotterdam joystick used in Q*bert had a ball "approximately" 30mm (1-1/8" - 1-1/4") in diameter (and are currently worth about $200 to buy refurbished)...so if you end up with a stick with a replaceable ball knob, then just get whatever size ball you want. 25mm, 30mm, 35mm, 38mm, and 45mm are all pretty readily available sizes, at least in black/red/white colors. Here's a few pics of some of the controllers I've made: Defender, Mouse Trap, and Vanguard - VVG Experience Controllers for the ColecoVision: Here's a pic of the Q*bert - VVG Joystick Controller I made for the ColecoVision, with joystick rotated 45 degrees for Q*bert!, Q*Bert's Qubes, & Congo Bongo (with "smaller" 30mm ball knob): And here are the 2 Asteroids controllers I've made for Coleco/Atari and similar consoles (featuring leaf-switch push-buttons): Upright Edition: Cabaret Edition: I buy "new" arcade parts from the following vendors: Arcade Renovations Arcade Shop Arcade Shock Focus Attack Groovy Game Gear Paradise Arcade Ultimarc If you're looking for authentic/original vintage controls for any projects, best to check ebay or the arcade forums over at KLOV. That's where I sourced the original Atari joysticks for my Gauntlet Edition - VVG Experience Controllers: and the 2-way paddle/lever controller for my Space Invaders Cocktail - VVG Experience Controller: There is a lot of different hardware available (both new and vintage), but in the end a lot of it will come down to price and what you're comfortable with paying for something. I've paid anywhere between $15 - $125 for a single joystick, and $2.25 - $12.50 per push-button. If you need any other info, or looking for something specific that you can't find, let me know and maybe I can help you out. Edited February 11, 2020 by doubledown 1 Quote Link to comment Share on other sites More sharing options...
