RevEng Posted February 22, 2020 Share Posted February 22, 2020 I've released dmf2asm and the included xmym tracker at github. If you're planning on giving a try to composing music in DefleMask, check out one of the DefleMask tutorials on youtube, and then please give the dmf2asm README.txt a once-over first, because you need to construct the music with certain restrictions. I've included 7800basic-based and assembly-based tracker examples. The assembly one is less glitzy than my 7800basic version, purely as a function of my free time. If anyone wants a glitzy assembly example, feel free to contribute one. Please report any bugs encountered here or at github, and feel free to discuss technical details here. 7 3 Quote Link to comment Share on other sites More sharing options...
RevEng Posted February 22, 2020 Author Share Posted February 22, 2020 Just wanted to also put out that I'll be looking at more features in the coming weeks... Initial instrument loads being auto-split over a few frames. This should allow mid-game song changes without burning a lot of CPU. Support for tick1 different from tick2. Deflemask has two different note-row-timing delays; one for even rows, and one for odd rows. It's a bit weird, but I think I can support this without a lot of heartache. Mid-song instrument changes. This one is a lot more involved, but it would be cool to have up to 16 instruments at the ready. 7 Quote Link to comment Share on other sites More sharing options...
RevEng Posted February 23, 2020 Author Share Posted February 23, 2020 I figured I'd make this thread a bit of a dev log of sorts for the time being. I made the tick1!=tick2 update, though I wouldn't recommend using differing ticks generally. If you use a differing ticks, dmf2asm can't squeeze your pattern down by removing redundant odd rows, since the timing will be different between even and odd rows. I also added code to defer the final all-notes-off at the end of a song. In the previous version the all-notes-off was issued too quickly after the final notes in the song, which caused a bit of distortion. (e.g. that cool, but unplanned, whoosh ending at the end of the Zanac demo.) I've decided that mid-song instrument changes are going to be implemented as start-of-pattern instrument changes. Otherwise I'll wind up doubling the pattern data needed for songs. This may also bring some minimum speed requirements, though nothing too crazy. I just need some frames between I also had a neat idea. Presently the high bit of the note data is only used for the rest marker, when note=0xff. If a note value of >127 and <255 is seen by XMYM, the tracker could save state and jump to a custom user-defined subroutine, passing on the note # and channel #. That could trigger game-specific custom actions - TIA drums, AtariVox singing, pokey notes, or even non-sound-related stuff. The value could easily be embedded in the song data by setting one of the DefleMask note parameters that dmf2asm currently ignores. 3 Quote Link to comment Share on other sites More sharing options...
