HammR25 Posted March 15, 2020 Share Posted March 15, 2020 If I use 144RPK with Bentley Bear and the Donkey Kong XM demo they crash. If I use 144RP with them I have no sound. I have a pokey inside my CC2. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted March 16, 2020 Author Share Posted March 16, 2020 What startup file are you using? Mitch Quote Link to comment Share on other sites More sharing options...
HammR25 Posted March 16, 2020 Share Posted March 16, 2020 I tried both 78BIOS and 78QUICK earlier. Apparently I didn't have the right versions of Bentley Bear and Donkey Kong XM because now I have them working with 144RPK and sound. Quote Link to comment Share on other sites More sharing options...
phattyboombatty Posted April 6, 2020 Share Posted April 6, 2020 On 2/29/2020 at 2:31 PM, Mitch said: So what other games don't work on the CC2 currently? Anything else I am missing? Mitch I finally got around to dumping my ©2012 DK XM (non-POKEY) cart. I performed the dump 6 times, and each comparison aligned perfectly. Not withstanding the possibility of a bad dump, I can't get my DK XM 144k BIN file to load on the CC2 using the 144RPK or 144PK banking files. It executes a blank, violet background only. Have you tried, or do you have any input on what might be going wrong? (The dump was made using the AtariMax MaxFlash Programmer with the latest MaxFlash software, firmware and 7800 adapter). Has anyone else had this experience, or has anyone discovered a workaround to load the DK XM binary? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted April 6, 2020 Author Share Posted April 6, 2020 I'll have to check that one. What checksum does your dump have. Also, what startup and banking settings are you using? Mitch Quote Link to comment Share on other sites More sharing options...
phattyboombatty Posted April 7, 2020 Share Posted April 7, 2020 Thank you. I analyzed with HxD and checksummed the BIN using the MD5 algorithm. MD-5: 09F9D392301C085CC278AD556A06BCF8 I have tried using: 7800: Donkey Kong XM DKXM78 144PK HSC 7800: Donkey Kong XM DKXM78 144RPK HSC 7800: Donkey Kong XM DKXM78 144PK 78BIOS 7800: Donkey Kong XM DKXM78 144RPK 78BIOS 7800: Donkey Kong XM DKXM78 144PK 78QUICK 7800: Donkey Kong XM DKXM78 144RPK 78QUICK Quote Link to comment Share on other sites More sharing options...
+Mitch Posted April 7, 2020 Author Share Posted April 7, 2020 Hmm, that checksum doesn't match mine. Maybe a bad dump? I get these. 88F714A5F0DCFBC2464920B157A2A3D1 or with the bank reversed 60976BDFB51F40BC1D9D9B16B1234307 I am pretty sure I dumped this BIN off my cart. Mitch Quote Link to comment Share on other sites More sharing options...
+Mitch Posted April 7, 2020 Author Share Posted April 7, 2020 Just updated the first post with banking files to use with A78 files. I did not have a chance to test all of them personally but they should all work. If you find a problem please post it. Mitch 1 Quote Link to comment Share on other sites More sharing options...
phattyboombatty Posted April 7, 2020 Share Posted April 7, 2020 16 minutes ago, Mitch said: Hmm, that checksum doesn't match mine. Maybe a bad dump? I get these. 88F714A5F0DCFBC2464920B157A2A3D1 or with the bank reversed 60976BDFB51F40BC1D9D9B16B1234307 I am pretty sure I dumped this BIN off my cart. Mitch I've certainly encountered many hurdles in historical attempts to get good dumps using the MaxFlash. I may need a small clamp to ensure all the contacts firmly align. I will try those new banking files ASAP, thank you!! Quote Link to comment Share on other sites More sharing options...
phattyboombatty Posted April 7, 2020 Share Posted April 7, 2020 (edited) 1 hour ago, Mitch said: Just updated the first post with banking files to use with A78 files. I did not have a chance to test all of them personally but they should all work. If you find a problem please post it. Mitch I just copied a few .A78 files to my CC2 and created the correct entries in the TXT and flat files. The problem I'm encountering is that the CC2 natively seeks .BIN files, so when I tell it to look for a filename with the .A78 extension, it can't seek it. Wouldn't the CC2 need a firmware update to address that? EDIT: I see the Python file. I'm not entirely familiar with how to execute the .py code, but I'm sure I can figure it out with a little coaching. Edited April 7, 2020 by phattyboombatty Quote Link to comment Share on other sites More sharing options...
+Mitch Posted April 7, 2020 Author Share Posted April 7, 2020 What firmware are you on? Ignore the python file. Mitch Quote Link to comment Share on other sites More sharing options...
+Mitch Posted April 7, 2020 Author Share Posted April 7, 2020 I temporarily removed the new banking files until I can test some more. Mitch Quote Link to comment Share on other sites More sharing options...
phattyboombatty Posted April 7, 2020 Share Posted April 7, 2020 15 hours ago, Mitch said: What firmware are you on? I’m using the last one that was released by Chad Schell (2.01). Quote Link to comment Share on other sites More sharing options...
+Mitch Posted August 7, 2020 Author Share Posted August 7, 2020 Just re-uploaded the last set of banking files to the first post. I forgot to do that earlier. The python file is for scanning the .a78 file and it outputs the correct banking and startup files to use to the screen. You still need to use the bin file to play the game. Below is a listing of the files. Mitch Enclosed is a set of CC2 Bankswitching files to implement every sane combination of .a78 header flags the CC2 is capable of emulating. ROMs from 4K - 512K 16K or 32K of RAM (32K is banked like SuperCart via bit 5, 0 relative even in non-banked ROMs) High score cart (HSC) POKEY at $4000-$7FFF POKEY at $0450 Activision and Absolute Banking The tools to create these are awful, so there are quite possibly mistakes. You can try the older CC2 Banking files if there is an equivalent if these don't seem to work. 7004 4K Standard ROM ($F000-$FFFF) 7004P4 4K Standard ROM ($F000-$FFFF), POKEY at $4000-$7FFF 7004P 4K Standard ROM ($F000-$FFFF), POKEY at $0450 7004R16 4K Standard ROM ($F000-$FFFF), 16K RAM ($4000-$7FFF) 7004R16P 4K Standard ROM ($F000-$FFFF), 16K RAM ($4000-$7FFF), POKEY at $0450 7004R32 4K Standard ROM ($F000-$FFFF), 32K Banked RAM ($4000-$7FFF) 7004R32P 4K Standard ROM ($F000-$FFFF), 32K Banked RAM ($4000-$7FFF), POKEY at $0450 H004 4K Standard ROM ($F000-$FFFF), HSC H004P4 4K Standard ROM ($F000-$FFFF), POKEY at $4000-$7FFF, HSC H004P 4K Standard ROM ($F000-$FFFF), POKEY at $0450, HSC H004R16 4K Standard ROM ($F000-$FFFF), 16K RAM ($4000-$7FFF), HSC H004R16P 4K Standard ROM ($F000-$FFFF), 16K RAM ($4000-$7FFF), POKEY at $0450, HSC H004R32 4K Standard ROM ($F000-$FFFF), 32K Banked RAM ($4000-$7FFF), HSC H004R32P 4K Standard ROM ($F000-$FFFF), 32K Banked RAM ($4000-$7FFF), POKEY at $0450, HSC 7008 8K Standard ROM ($E000-$FFFF) 7008P4 8K Standard ROM ($E000-$FFFF), POKEY at $4000-$7FFF 7008P 8K Standard ROM ($E000-$FFFF), POKEY at $0450 7008R16 8K Standard ROM ($E000-$FFFF), 16K RAM ($4000-$7FFF) 7008R16P 8K Standard ROM ($E000-$FFFF), 16K RAM ($4000-$7FFF), POKEY at $0450 7008R32 8K Standard ROM ($E000-$FFFF), 32K Banked RAM ($4000-$7FFF) 7008R32P 8K Standard ROM ($E000-$FFFF), 32K Banked RAM ($4000-$7FFF), POKEY at $0450 H008 8K Standard ROM ($E000-$FFFF), HSC H008P4 8K Standard ROM ($E000-$FFFF), POKEY at $4000-$7FFF, HSC H008P 8K Standard ROM ($E000-$FFFF), POKEY at $0450, HSC H008R16 8K Standard ROM ($E000-$FFFF), 16K RAM ($4000-$7FFF), HSC H008R16P 8K Standard ROM ($E000-$FFFF), 16K RAM ($4000-$7FFF), POKEY at $0450, HSC H008R32 8K Standard ROM ($E000-$FFFF), 32K Banked RAM ($4000-$7FFF), HSC H008R32P 8K Standard ROM ($E000-$FFFF), 32K Banked RAM ($4000-$7FFF), POKEY at $0450, HSC 7016 16K Standard ROM ($C000-$FFFF) 7016P4 16K Standard ROM ($C000-$FFFF), POKEY at $4000-$7FFF 7016P 16K Standard ROM ($C000-$FFFF), POKEY at $0450 7016R16 16K Standard ROM ($C000-$FFFF), 16K RAM ($4000-$7FFF) 7016R16P 16K Standard ROM ($C000-$FFFF), 16K RAM ($4000-$7FFF), POKEY at $0450 7016R32 16K Standard ROM ($C000-$FFFF), 32K Banked RAM ($4000-$7FFF) 7016R32P 16K Standard ROM ($C000-$FFFF), 32K Banked RAM ($4000-$7FFF), POKEY at $0450 H016 16K Standard ROM ($C000-$FFFF), HSC H016P4 16K Standard ROM ($C000-$FFFF), POKEY at $4000-$7FFF, HSC H016P 16K Standard ROM ($C000-$FFFF), POKEY at $0450, HSC H016R16 16K Standard ROM ($C000-$FFFF), 16K RAM ($4000-$7FFF), HSC H016R16P 16K Standard ROM ($C000-$FFFF), 16K RAM ($4000-$7FFF), POKEY at $0450, HSC H016R32 16K Standard ROM ($C000-$FFFF), 32K Banked RAM ($4000-$7FFF), HSC H016R32P 16K Standard ROM ($C000-$FFFF), 32K Banked RAM ($4000-$7FFF), POKEY at $0450, HSC 7032 32K Standard ROM ($8000-$FFFF) 7032P4 32K Standard ROM ($8000-$FFFF), POKEY at $4000-$7FFF 7032P 32K Standard ROM ($8000-$FFFF), POKEY at $0450 7032R16 32K Standard ROM ($8000-$FFFF), 16K RAM ($4000-$7FFF) 7032R16P 32K Standard ROM ($8000-$FFFF), 16K RAM ($4000-$7FFF), POKEY at $0450 7032R32 32K Standard ROM ($8000-$FFFF), 32K Banked RAM ($4000-$7FFF) 7032R32P 32K Standard ROM ($8000-$FFFF), 32K Banked RAM ($4000-$7FFF), POKEY at $0450 H032 32K Standard ROM ($8000-$FFFF), HSC H032P4 32K Standard ROM ($8000-$FFFF), POKEY at $4000-$7FFF, HSC H032P 32K Standard ROM ($8000-$FFFF), POKEY at $0450, HSC H032R16 32K Standard ROM ($8000-$FFFF), 16K RAM ($4000-$7FFF), HSC H032R16P 32K Standard ROM ($8000-$FFFF), 16K RAM ($4000-$7FFF), POKEY at $0450, HSC H032R32 32K Standard ROM ($8000-$FFFF), 32K Banked RAM ($4000-$7FFF), HSC H032R32P 32K Standard ROM ($8000-$FFFF), 32K Banked RAM ($4000-$7FFF), POKEY at $0450, HSC 7048 48K Standard ROM ($4000-$FFFF) 7048P 48K Standard ROM ($4000-$FFFF), POKEY at $0450 H048 48K Standard ROM ($4000-$FFFF), HSC H048P 48K Standard ROM ($4000-$FFFF), POKEY at $0450, HSC 7064 64K SuperCart 7064L 64K SuperCart, Bank 6 at $4000-$7FFF 7064LP 64K SuperCart, Bank 6 at $4000-$7FFF, POKEY at $0450 7064P4 64K SuperCart, POKEY at $4000-$7FFF 7064P 64K SuperCart, POKEY at $0450 7064R16 64K SuperCart, 16K RAM ($4000-$7FFF) 7064R16P 64K SuperCart, 16K RAM ($4000-$7FFF), POKEY at $0450 7064R32 64K SuperCart, 32K Banked RAM ($4000-$7FFF) 7064R32P 64K SuperCart, 32K Banked RAM ($4000-$7FFF), POKEY at $0450 H064 64K SuperCart, HSC H064L 64K SuperCart, Bank 6 at $4000-$7FFF, HSC H064LP 64K SuperCart, Bank 6 at $4000-$7FFF, POKEY at $0450, HSC H064P4 64K SuperCart, POKEY at $4000-$7FFF, HSC H064P 64K SuperCart, POKEY at $0450, HSC H064R16 64K SuperCart, 16K RAM ($4000-$7FFF), HSC H064R16P 64K SuperCart, 16K RAM ($4000-$7FFF), POKEY at $0450, HSC H064R32 64K SuperCart, 32K Banked RAM ($4000-$7FFF), HSC H064R32P 64K SuperCart, 32K Banked RAM ($4000-$7FFF), POKEY at $0450, HSC 7128 128K SuperCart 7128L 128K SuperCart, Bank 6 at $4000-$7FFF 7128LP 128K SuperCart, Bank 6 at $4000-$7FFF, POKEY at $0450 7128P4 128K SuperCart, POKEY at $4000-$7FFF 7128P 128K SuperCart, POKEY at $0450 7128R16 128K SuperCart, 16K RAM ($4000-$7FFF) 7128R16P 128K SuperCart, 16K RAM ($4000-$7FFF), POKEY at $0450 7128R32 128K SuperCart, 32K Banked RAM ($4000-$7FFF) 7128R32P 128K SuperCart, 32K Banked RAM ($4000-$7FFF), POKEY at $0450 H128 128K SuperCart, HSC H128L 128K SuperCart, Bank 6 at $4000-$7FFF, HSC H128LP 128K SuperCart, Bank 6 at $4000-$7FFF, POKEY at $0450, HSC H128P4 128K SuperCart, POKEY at $4000-$7FFF, HSC H128P 128K SuperCart, POKEY at $0450, HSC H128R16 128K SuperCart, 16K RAM ($4000-$7FFF), HSC H128R16P 128K SuperCart, 16K RAM ($4000-$7FFF), POKEY at $0450, HSC H128R32 128K SuperCart, 32K Banked RAM ($4000-$7FFF), HSC H128R32P 128K SuperCart, 32K Banked RAM ($4000-$7FFF), POKEY at $0450, HSC 7144 144K SuperCart 7144P 144K SuperCart, POKEY at $0450 H144 144K SuperCart, HSC H144P 144K SuperCart, POKEY at $0450, HSC 7256 256K SuperCart 7256L 256K SuperCart, Bank 6 at $4000-$7FFF 7256LP 256K SuperCart, Bank 6 at $4000-$7FFF, POKEY at $0450 7256P4 256K SuperCart, POKEY at $4000-$7FFF 7256P 256K SuperCart, POKEY at $0450 7256R16 256K SuperCart, 16K RAM ($4000-$7FFF) 7256R16P 256K SuperCart, 16K RAM ($4000-$7FFF), POKEY at $0450 7256R32 256K SuperCart, 32K Banked RAM ($4000-$7FFF) 7256R32P 256K SuperCart, 32K Banked RAM ($4000-$7FFF), POKEY at $0450 H256 256K SuperCart, HSC H256L 256K SuperCart, Bank 6 at $4000-$7FFF, HSC H256LP 256K SuperCart, Bank 6 at $4000-$7FFF, POKEY at $0450, HSC H256P4 256K SuperCart, POKEY at $4000-$7FFF, HSC H256P 256K SuperCart, POKEY at $0450, HSC H256R16 256K SuperCart, 16K RAM ($4000-$7FFF), HSC H256R16P 256K SuperCart, 16K RAM ($4000-$7FFF), POKEY at $0450, HSC H256R32 256K SuperCart, 32K Banked RAM ($4000-$7FFF), HSC H256R32P 256K SuperCart, 32K Banked RAM ($4000-$7FFF), POKEY at $0450, HSC 7512 512K SuperCart 7512L 512K SuperCart, Bank 6 at $4000-$7FFF 7512LP 512K SuperCart, Bank 6 at $4000-$7FFF, POKEY at $0450 7512P4 512K SuperCart, POKEY at $4000-$7FFF 7512P 512K SuperCart, POKEY at $0450 ABS78 Absolute Cart ACT78 Activision Cart 7800_ROF ROF Cart ("Mirror RAM") 3 1 Quote Link to comment Share on other sites More sharing options...
desiv Posted August 29, 2020 Share Posted August 29, 2020 Thanx for this. Got BBCQ and DK78XM running with Pokey sound/music last night for the first time. The trickiest part for me was finding the BBCQ bin file that was the XM version. That thread is REALLY LONG.... For BBCQ, I used the 144PK bank file and for DK78XM, I used the 144RPK bank file. 1 Quote Link to comment Share on other sites More sharing options...
