+Andrew Davie Posted March 1, 2020 Share Posted March 1, 2020 I posted this elsewhere before remembering we have a group for this. I recently "discovered" a neat way to use macros to define tables of related items. For example, a LO/HI table can be defined like this... MAC POSTAB .byte {1}PositionalValue_PAWN .byte {1}PositionalValue_PAWN .byte {1}PositionalValue_KNIGHT .byte {1}PositionalValue_BISHOP .byte {1}PositionalValue_ROOK .byte {1}PositionalValue_QUEEN .byte {1}PositionalValue_KING_MIDGAME ENDM PosValVecLO POSTAB < PosValVecHI POSTAB > You can pass the name of a macro to a macro, and the macro you pass will be evaluated (eventually). This means you can do stuff like this... MAC LO .byte <{1} ENDM MAC HI .byte >{1} ENDM MAC SP .byte {2} ENDM MAC TAB {1} Func1, 10 {1} Func2, 20 {1} Func3, 2 ENDM LoTable TAB LO HiTable TAB HI SpeedTable TAB SP A walkthrough: LoTable defines a label. It calls the macro TAB, passing it the parameter "LO" The macro replaces all the {1} on each line with "LO", which the become calls to the macro "LO" with two parameters The LO macro puts the low byte of the 1st parameter. For all lines in the TAB macro. So, the last three lines define three separate tables, one for low bytes, one for high bytes, and one for "speed" just to show as an example. Perhaps we could document these "tricks" somehow in a DASM tips'n'tricks or addendum to the manual? Personally I think this one is pretty useful, as it prevents you getting the values in the different tables out of order - you only need to define the "contents" once inside the TAB macro, instead of three times, in three tables. 3 Link to comment Share on other sites More sharing options...
