+SpiceWare Posted March 5, 2020 Share Posted March 5, 2020 Answer to this question: byte is used for data. It's actually an alias for DC.B. From dasm's manual*: [label] DC[.BWL] exp,exp,exp ... Declare data in the current segment. No output is generated if within a .U segment. Note that the byte ordering for the selected processor is used for each entry. The default size extension is a byte. #if OlafByte BYTE, WORD and LONG are synonyms for DC.B, DC.W and DC.L. #endif .byte is equivalent to byte. Before deciding to write Medieval Mayhem from scratch I was originally going to hack Warlords. That's covered in these blog entries: Updating 2600 Warlords Found a bug that can kill you Warlords Status Update Warlords Status Update 3 Medieval Mayhem I used DiStella to turn the ROM for Warlords into source code, and it outputs .byte instead of byte. I've been using .byte ever since. Example usage from Warlords: ColorBrickColors: .byte $47,$47,$45,$45,$43,$43,$41,$41 This would output two $47, two $45, two $43, and two $41 in the ROM. ds is used to define a chunk of space. [label] DS[.BWL] exp[,filler] declare space (default filler is 0). Data is not generated if within an uninitialized segment. Note that the number of bytes generated is exp * entrysize (1,2, or 4) The default size extension is a byte. Note that the default filler is always 0 (has nothing to do with the ORG default filler). When doing so for RAM nothing actually gets stored in it. When doing it for ROM it fills the entire space with 0, though you can override the fill value such as: ds 10, 255 which would output ten 255s in the ROM. * file to look for is dasm.txt. It should have been included with dasm, but you can get it from here if you can't find it - look for the section titled Code & Documentation then click Documentation. 4 Link to comment Share on other sites More sharing options...
