debugging CC65 C code with altirra for *.rom files
Hi All,
when you create an app that resides on cartridge (for example my game I am currently developing resides on mega cart 1MB) , the output file name is *.rom (instead of the normal xex or car)
To debug your code you need to add debug info , so to command line you add:
Quote
cl65 --debug-info -Wl --dbgfile,./bin/myfile.dbg
The Wl is to let the linker know you're passing an input file as a parameter. see my cc65 tutorial on how to debug your code with altirra for more refernce.
that dbg file should reside next to your executable file. in our case next to the myfile.rom file.
when you run altirra and break, and type "lm" to see the symbols it will not show you the symbols from your executables.
I've confirm this with @phaeron and altirra code does support dbg but not when it resides next to a *.rom file.
till this will be resolved in next versions of altirra(?) the workaround suggested is to rename the dbg file to *.lab
so you should change your command line to :
Quote
cl65 --debug-info -Wl --dbgfile,./bin/myfile.lab
now that the lab file will reside next to the rom file, altirra will load the symobls properly.
hope this helps anyone
  • 2 years later...
