BeefMan Posted July 6, 2020 Share Posted July 6, 2020 Sign me up for a pre-modded pro controller, thanks! 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4579920 Share on other sites More sharing options...
Sadmus Posted July 8, 2020 Share Posted July 8, 2020 Sign me up for the starwander pro controller pre installed. 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4581622 Share on other sites More sharing options...
+Saturn Posted July 9, 2020 Share Posted July 9, 2020 On 7/3/2020 at 1:14 AM, Machine said: I got a pro controller from Dave and just played Raiden. It is amazing. I can not stress enough how nice it is.....very professional, looks like it came from factory that way. The best part is how well it works. I have never been great at Raiden, barely getting into the 3rd level. The very first game I played with the controller, I beat the game!!! I was amazed at how well it worked and how much more fun it made Raiden. Seeing the rest of the levels was cool. Beating the game was amazing. Anyone on the fence, jump on this one! It is amazing! You will not be sorry!!!! Thanks Dave! Your work is top-notch!!! Exactly this ^ I've played Raiden tonight and although I didn't make it through the game, it's a blast with RF! Thanks again for this modded controller 2 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4582420 Share on other sites More sharing options...
+grips03 Posted July 12, 2020 Author Share Posted July 12, 2020 If you damage the Starwander Pro Controller ribbon cable order: Qty 2 1832785-1 from Digikey or Mouser. Cut to the correct number of contacts and solder in. This cable has the correct pitch, wire size and length. It is much stronger than what its replacing. 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4584244 Share on other sites More sharing options...
+grips03 Posted July 13, 2020 Author Share Posted July 13, 2020 I built two stock Jag black controllers today. It takes around an hour to install the mod from start to finish. This is the easiest to mod as the black controllers pcb and ribbon wire are very strong and there is a ton of room. The Starwander Pro Controllers take me twice as long (or more). Hopefully I can get faster installing the mod in that one. Production pcb ordered. Production parts ordered. Best guess is ~ 3 weeks away. 2 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4584381 Share on other sites More sharing options...
+grips03 Posted July 16, 2020 Author Share Posted July 16, 2020 I now have access to post 1 for edits. So I wrote up most of the details there. I also posted install instructions and photos. Let me know of corrections needed. 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4587208 Share on other sites More sharing options...
+grips03 Posted July 21, 2020 Author Share Posted July 21, 2020 Parts from Digikey arrived. Production PCBs should arrive on July 27th. If everything goes right I'll start shipping next week. 1 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4590132 Share on other sites More sharing options...
+Saturn Posted July 21, 2020 Share Posted July 21, 2020 Sweet! 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4590156 Share on other sites More sharing options...
+grips03 Posted July 23, 2020 Author Share Posted July 23, 2020 I highly recommend people test the Starwander Pro Controller before modding. I found one today with wire 12/left and wire 14/up with a short on the top pcb where the ribbon cable connects. The up/left issue sort of looked like the pcb leveling issue, however if you remove the pcbs from the controller and just press the rubber pad for up it would press up & left on the Jaguar joystick test program. Re-flowing the solder for these two wires cleared the short. There was also a small metal piece inside the controller. All very fixable, but much easier to do before modding. So far quite a few of the Starwander Pro Controllers have stripped internal screws. The one most at fault is the single screw holding the top pcb in. This does not matter as long as the screw can be placed in the hole and does not fall out, because the back of the controller case presses and prevents the top pcb from fall backwards into the controller. The same is true for the bottom pcb as well. Please understand this has nothing to do with the RF 2.0 kit, but since people will be opening these controllers and modding them I'm trying to provide as much details about them as possible. Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4591905 Share on other sites More sharing options...
+grips03 Posted July 28, 2020 Author Share Posted July 28, 2020 Production pcbs are here. I'm going to test them out tomorrow. If they look good I should be shipping controllers/kits out towards the end of the week. 3 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4595242 Share on other sites More sharing options...
+grips03 Posted July 28, 2020 Author Share Posted July 28, 2020 Production pcb works fine. Built one controller tonight. Will build up a bunch of pcbs tomorrow. 2 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4595909 Share on other sites More sharing options...
+Saturn Posted July 28, 2020 Share Posted July 28, 2020 Awesome 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4595919 Share on other sites More sharing options...
walter_J64bit Posted July 31, 2020 Share Posted July 31, 2020 (edited) I-War works with rapid fire! Edited July 31, 2020 by walter_J64bit 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4597717 Share on other sites More sharing options...
+grips03 Posted August 1, 2020 Author Share Posted August 1, 2020 I've modded 4 Starwander Pro Controllers (SPC) today. I'm going to re-write the installation instructions to perform the steps even better. I have 7 Pro Controllers left to sell, then I'm likely to switch to Twin Stick project. Once hockey starts (Sept) I'll most likely take a step back from projects until next summer. So if you want one this year I would recommend not waiting because hockey will get super busy and use up free time. I can now make it to stage 3 without losing a ship in Raiden, much more fun to play with rapid fire. 2 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4598296 Share on other sites More sharing options...
+grips03 Posted August 1, 2020 Author Share Posted August 1, 2020 I was making a Gray controller today and wow. I was really amazed how good Raiden felt with the dpad. Hitting the corners was not bad at all. I thought it was quite good. I can now make it past stage 3 with single life. This game was meant to have rapid fire. 2 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4598796 Share on other sites More sharing options...
+Saturn Posted August 5, 2020 Share Posted August 5, 2020 Got my 2nd rf controller in yesterday! Thanks again Which rev is the board on this one? 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4602127 Share on other sites More sharing options...
+grips03 Posted August 5, 2020 Author Share Posted August 5, 2020 38 minutes ago, Saturn said: Got my 2nd rf controller in yesterday! Thanks again Which rev is the board on this one? 3c. I moved a cap to the top and pushed some parts higher on the board. But its a really the same thing, just a slightly different layout. 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4602165 Share on other sites More sharing options...
+Saturn Posted August 5, 2020 Share Posted August 5, 2020 Ok, thanks. Shipping was fast btw! Will test it out later this evening on some Raiden. 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4602205 Share on other sites More sharing options...
K3V Posted August 5, 2020 Share Posted August 5, 2020 I got my kit in the mail the other day. Will likely be a bit before I get around to installing it on my joystick but it'll be a good project when I get to it. Thanks! 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4602222 Share on other sites More sharing options...
+Saturn Posted August 6, 2020 Share Posted August 6, 2020 Controller works great. Pressing the rf button on bottom twice is magic in Raiden 2 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4602341 Share on other sites More sharing options...
+grips03 Posted August 10, 2020 Author Share Posted August 10, 2020 Have power again, so started making a few more. I have one new gray button with rapid fire ready to ship. Ready to ship inventory is in the first post. Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4605414 Share on other sites More sharing options...
Machine Posted August 11, 2020 Share Posted August 11, 2020 You guys do not want to miss out on this controller! It works better than advertised! 2 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4605878 Share on other sites More sharing options...
+grips03 Posted August 13, 2020 Author Share Posted August 13, 2020 Updated install instructions in the first post. Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4607412 Share on other sites More sharing options...
SabertoothRetro Posted August 13, 2020 Share Posted August 13, 2020 I have spent just over a week with a pre-modded Starwander RF 2.0 controller and could not be more pleased. As has been said, the work is so clean it looks like it came from a factory. In fact, I like it so much that I put in an order for a second! Most of my time has been on Zero 5 and Raiden but the RF 2.0 even has me revisiting Trevor McFur. It's still a crap game but the RF 2.0 makes it a bit more tolerable. A spoonful of sugar I suppose... Anyway, if you're on the fence for a kit or pre-modded controller, I highly recommend getting this while it's available. Top work @grips03! 3 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4607689 Share on other sites More sharing options...
+grips03 Posted August 15, 2020 Author Share Posted August 15, 2020 I have made the pre-modded controllers I'm going to make in 2020. They are listed for sale in the first post. I don't mind making more kits, but I need to move on to other projects. 1 Quote Link to comment https://forums.atariage.com/topic/304243-rapid-fire-20/page/4/#findComment-4609412 Share on other sites More sharing options...
